timbak
Posted: Wed May 26, 2021 7:15 pm Post subject: |
O-Family hello again!
Still try to work with OLED 0.66" 64x48 and Atxmega32A4. Some strange behavior with display increment values.
This code works perfect:
Code: | Do
Setfont Font6x8
Lcdat 1 , 1 , "1234567890"
Loop |
i can see the whole string on display 1234567890
But these examples don't work as expected:
Code: | Do
Setfont Font6x8
Lcdat 1 , 1 , Increment
Incr Increment
Waitms 500
Loop | or Code: | Do
Tempstr = Str(increment)
Setfont Font6x8
Lcdat 1 , 1 , Tempstr
Incr Increment
Waitms 500
Loop | I see only one last digit.
Actually if value is SINGLE, i can see incrementation on screen - after 9.0 i got 10.0.. 11.0.. 12.00 and ect. |
O-Family
Posted: Sat May 29, 2021 1:48 am Post subject: |
I tried to test with ATXmega128A1, but the display itself does not work properly.
There may be a problem with the original "SSD1306-I2C" library.
Please show your source code. |
timbak
Posted: Sat May 29, 2021 11:14 am Post subject: |
Code: | $regfile = "xm32a4udef.dat"
$crystal = 32000000
$hwstack = 180
$swstack = 180
$framesize = 180
'$noramclear
Config Submode = New
'''******************************** SYS CLOCK CONFIG *****************************
Config Single = Scientific , Digits = 1
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled , Hi = Enabled
'********************************* CONFIG TWI ************************************
Dim Twi_start As Byte
Open "twic" For Binary As #2
Config Twic = 100000
I2cinit #2
'************************* CONFIG OLED 0.66 SSD1306 64x48 ***********************
Config Portd.0 = Output : Oled_rst Alias Portd.0 : Oled_rst = 1 'OLED RESET
'$lib "glcdSSD1306-I2C_V2.lib"
$lib "glcdSSD1306-I2C_V2_0R66_64x48.lib"
Dim _contrast As Byte ' Contrast value of OLED. [0-255]
Const Ssd1306_rotate = 1
Config Graphlcd = Custom , Cols = 64 , Rows = 48 , Lcdname = "SSD1306"
Cls
'Glcdcmd &HA7 'Inversion
Glcdcmd &HAF 'Display ON
Dim Increment As Byte , Tempval As Single , Tempstr As String * 8 , Strlen As Byte
Setfont Font6x8
Waitms 500
Incr Increment
'__________________________________________________________________________________
'This is what i want to do: increment the value "Increment" and show it on display.
'It doen't works - i see only last digit. I.e if Increment = 123 on display i see only "3"
'It works if Increment value dimensioned as a single: "Dim Increment As Single"
'But in this case i see on display 123.0
Lcdat 1 , 1 , Increment ; " "
'This is my workaround: Tempval(single) get value of Increment(byte)
'Represent Tempval as a string
'and then i delete from the string fractional part with point and send it to the screen
Tempval = Increment
Tempstr = Str(tempval)
Strlen = Len(tempstr) - 2
Tempstr = Left(tempstr , Strlen )
Lcdat 1 , 1 , Tempstr ; " "
$include "Font6x8.font"
$include "font12x16.font" |
O-Family
Posted: Sat May 29, 2021 3:14 pm Post subject: |
Certainly my ATXmega128A1 had the same symptoms.
It is only the last digit when displaying a variable with the LCDAT instruction using Xmega.
It works fine with normal AVR.
I tried to save all the registers in the [_gwrite_lcdchar] routine of the library, but the symptom does not change.
This may be a problem with BASCOM's internal processing, so please check with Mark. |
O-Family
Posted: Sun May 30, 2021 1:18 am Post subject: |
A remedy was found.
Code: | 'The following behaves abnormally.
$hwstack = 180
$swstack = 180
$framesize = 180
'Of the three stack settings, setting one or more to something other than 180 will be normal.
$hwstack = 181
$swstack = 180
$framesize = 180 |
This is a very strange behaviour, and it seems that setting the stack to 180 for all three will corrupt the contents of the registers or the data passed by the stack.
There seems to be a strange and fatal bug in the operation of the stack.
Nothing more can be solved by me.
It can be verified with the following simple program.
(You can also check it in the simulator)
Code: | $regfile = "xm128A1def.dat"
$crystal = 32000000
$hwstack = 180 'An abnormality occurs.
'$hwstack = 181 'It works normally.
$swstack = 180
$framesize = 180
Config Com1 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Dim Temp1 As Byte
Print Temp1
Incr Temp1
Waitms 300
End |
Posted: Tue Jun 01, 2021 9:47 am Post subject: |
and what happens ? it seems to run normal in the sim. I also see no problem with the stacks.
i do not know which version you use? or the TS ?
also, to use xmega with ssd1306 there is the lib for xmega named : glcdSSD1306-I2C-TWI.lib _________________ Mark |
O-Family
Posted: Tue Jun 01, 2021 1:35 pm Post subject: |
Check the difference in the simulator results.
Compiler version :2.0.8.3
Compiler build :2.0.8.3.005
IDE version :2.0.8.3.003
"glcdSSD1306-I2C-TWI.lib" is a version with added support for Xtiny, and I think "glcdSSD1306-I2C.lib" also supports Xmega's TWIC. |
timbak
Posted: Sun Jun 06, 2021 7:41 pm Post subject: |
albertsm wrote: | and what happens ? it seems to run normal in the sim. I also see no problem with the stacks.
also, to use xmega with ssd1306 there is the lib for xmega named : glcdSSD1306-I2C-TWI.lib |
IDE version :2.0.8.3.003 |
bifi
Posted: Wed Sep 29, 2021 1:23 pm Post subject: |
Is it possible to make the lib "glcdSSD1306-I2C_V2.lib" working with "i2cv2.lib" ?
I get no output when using hardware I2C. The I2C bus hangs.
Michael |
O-Family
Posted: Thu Sep 30, 2021 12:21 am Post subject: |
The "glcdSSD1306-I2C_V2.lib" is TWI (hardware I2C) compatible and has been tested.
For TWI, "i2cv2.lib" is not used.
Are there any problems with your hardware or connections?
What type of display unit are you using? |
bifi
Posted: Thu Sep 30, 2021 8:29 am Post subject: |
I try to implement a display 128x32 pixels from alibaba in an existent hardware
based on an ATMega644 that uses the "i2cv2.lib".
I made a demoboard with an atmega88 and this works fine
with the TWI lib, but shows nothing with the i2cv2.
I don't know if the existent hardware will run wit the i2c_twi lib. |
O-Family
Posted: Thu Sep 30, 2021 9:32 am Post subject: |
I am not sure what your problem is.
Please describe your symptoms in detail.
It is also important to attach the program. |
bifi
Posted: Thu Sep 30, 2021 9:50 am Post subject: |
Sorry, i mixed hardware and software twi.
I thought that i2c_twi was the software interface, but reading the help
should be done first. |
georgestheking
Posted: Tue Feb 21, 2023 11:47 am Post subject: SSD1306 128 X 32 |
I am using a new device on AlliExpress : a Arduino NANO + a display SSD1306 on the same board.
The resolution is 128 x 32.
using
Config Graphlcd = Custom , Cols = 128 , Rows = 32 , Lcdname = "SSD1306"
I get something on the display but completly crush.
Any idea ?
Best regards
Georges |
O-Family
Posted: Wed Feb 22, 2023 2:08 am Post subject: |
Please show me the program you used for the test and a picture of the display screen. |
