HELP using MEGA2560 and TFT ili9341
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions
hobby
PostPosted: Fri Dec 14, 2018 1:47 pm    Post subject: HELP using MEGA2560 and TFT ili9341 Reply with quote
Moderator: delete this post wrong forum, moved: https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=14305
Hi All,
I try to using the MikroElektronika TFT Proto MI0283QT9A. (Rev 2.0) with MEGA2560 @ 16Mhz in SPI soft mode. But the screen stay white.
I use the example code for testing for wiki web site, just remove the code with picture example for quick compiling. (in attachement) and add the Print everry start example.
I have define in code:
Const Lcd_enable_spi = True
Const Lcd_use_soft_spi = True
Const Lcd_ctrl_port = Portk
Const Lcd_reset_pin = 0
Const Lcd_pin_dc = 1
Const Lcd_pin_cs = 2
Const Lcd_pin_sdo = 3
Const Lcd_pin_clk = 4
But, with scope, no clock signal on portK.4 and the runing code is slow.
I have test with define PortA, same result.
For tesing the MCU, i have create this code for testing portA:
$regfile = "m2560def.dat"
$hwstack = 64
$swstack = 64
$framesize = 64
$crystal = 16000000
$baud = 9600
Config Porta = Output
Print "Start"
  Toggle Porta
  Waitms 10
Mesuring with scope works.
I use TBX0104 for level adaptor.
What do I do wrong?
Thanks
Olivier
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.1 )
Thanks
Olivier
Printpix52
PostPosted: Fri Dec 14, 2018 8:11 pm    Post subject: Reply with quote
Hi,Already configure the parameters? BASCOM-AVR option (communication = 16000000)
hobby
PostPosted: Fri Dec 14, 2018 11:04 pm    Post subject: Reply with quote
Thanks for reply.
But the 'communication' is for serial ($BAUD) not for SPI.
After check in ili9341.inc file, i see only xmega or m328, the lib is not tested in mega2560.
I cancel to use this lib, too much uncertainty.
Thanks
Olivier
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions All times are GMT + 1 Hour
