apds 9930
krolikbest
PostPosted: Mon Oct 01, 2018 8:19 am    Post subject: apds 9930 Reply with quote
Hello,
I'm looking for someone who did try or still is struggling to write (in bascom of course) a program for apds 9930. It is gesture/light ambient/proximity wonderful device. So far I can read datas from registers but for some reason I cannot write to registry. Let say if there are registers:
0x00 Enable - register1 Write/Read
0x01 Atime - register 2 W/R
0x02 Wtime - register 3 W/R
and I do a (pseudo) code:
 Addr_write=&H72 'according to the manual address=39hex
 Addr_read=&H73
 i2cinit
  i2cstart
   i2cwbyte Addr_write
   i2wbyte register1
   i2cwbyte value_to_register1
  i2cstop
  i2cstart
   i2cwbyte Addr_write
   i2wbyte register2
   i2cwbyte value_to_register2
  i2cstop
always I write into first register only. Second and others (above register1) are unchanged.
Martin
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.1 )
PostPosted: Mon Oct 01, 2018 4:43 pm    Post subject: Re: apds 9930 Reply with quote
krolikbest wrote:
wonderful device
Still wonderful, if it don't accept writes? Very Happy
   i2cwbyte Addr_write
   i2cwbyte register1
It's not sufficient to send the register address, you need to form a command, which consists of CMD - TYPE - ADD, see the data sheet.
ADD is actually your register address, TYPE is the form of following up data transfers and CMD is simply bit 7 set to 1.
An example to adress ATIME:
Const APDS_CMD_repByte = &h80 Or &h00
Const APDS_CMD_autoInc = &h80 Or &h20
Const APDS_CMD_specFunc = &h80 Or &h60
Const APDS_ATIME = &h01
Dim APDS_Command As Byte
APDS_Command = APDS_CMD_repByte OR APDS_ATIME
' now send to I2C
krolikbest
PostPosted: Mon Oct 01, 2018 5:44 pm    Post subject: Reply with quote
Ok, I get it. After your explanation datasheet seems very clear now. As a proof attach reading id number
 I2cstart
  I2cwbyte Addr_w 'slave i2c addres
  I2cwbyte &HB2    'CMD+type+register => register=12 (i2c address)
 I2cstart
  I2cwbyte Addr_r
  I2crbyte idNum , NAck
 I2cstop
 Print  Hex(idNum)
Thank you,
Martin
