Timer question to make a driver for TLC59401
hzz
PostPosted: Fri Jul 20, 2018 11:52 am    Post subject: Timer question to make a driver for TLC59401 Reply with quote
Hello. I need ideas to do the following (with XMEGA):
A) Clock pulses. Output a 16MHz clock signal. OK, this is easy. I can just use a timer in frequency mode
Config Tcd1 = Freq , Prescale = 1 , Comparea = Enabled , Resolution = 16
Tcd1_cca = 0                                                ' System Clock  /2*Prescaler(CCA + 1) = 32MHz/2*1(0 + 1) = 32MHz/2 = 16MHz
B) Blank Pulse. Output a short pulse (about 100ns) after 4096 Clock Pulses . Any idea about how to do this?
C) Xlat Pulse. When a variable is =1, output a pulse which should go high after the Blank pulse and should go low before the Blank pulse. (The Xlat pulse is inside the Blank pulse). Again any idea?
PD: Each output uses a different pin (so 3 pins in total)
In https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=14193&highlight=tlc59401 I posted a driver for TL59401/TL5940 LED/Servo PWM control chips.
But it didn't work. Now I understand why and need to solve what I mention above in order to correct the driver.
Thanks
Hector
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.8.1 )
