Write or Put ?
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS
PostPosted: Thu Jul 05, 2018 4:08 pm    Post subject: Write or Put ? Reply with quote
Hi,*
I never use AVRdos to write somethng, only to read
ex :
    Chdir "lalong"
     Sentence = "lalong.txt"
     Ff = Freefile()
     Open Sentence For Input As #ff
          Lineinput #ff , Stdir       ' read a line  and result in stdir string
          Wait 1
     Loop Until Eof(ff) <> 0
     Close #ff
     Chdir "\"       'change to the root directory
The result was 491625N031317ELONGPONT without any "
so I would like replace the file from my ATMEGA2560
I use :
                   Chdir "lalong"
                    Print "kill lalong.txt"
                    Kill "lalong.txt" l
                    Waitms 100
                    Ff = Freefile()
                    Open "lalong.txt"for Output As #ff
                   Write #ff , Sentence
                    Close #ff
                    Waitms 100
                    Ff = Freefile()
                    Open "lalong.txt" For Input As #ff
                         Wait 1
                    Close #ff
                    Print "stdir" ; Stdir
the result is
"484754N021849EBAGNEUX"
So my question : It is possible to write a string without " " as VBA for excel does ?
Thanks for your help Wink
Jp
PostPosted: Thu Jul 05, 2018 9:05 pm    Post subject: Reply with quote
Like the help suggests, WRITE uses double quotes just as in VB.
You need to use the good old PRINT when you do not want that.
PostPosted: Fri Jul 06, 2018 10:02 am    Post subject: solved Reply with quote
Hi Mark
and thanks for your answers
During the night ....I add some line and now it's solved
     If Left(stdir , 1 ) = Chr(34) Then       'suppression du " si stdir vient du clavier
        Delchar Stdir , 1
     If Right(stdir , 1) = Chr(34) Then
        Lenst = Len(stdir)
        Delchar Stdir , Lenst
like that if the file is write with VBA it is good, and if it is write from the AVRDOS it is good also
JP Wink
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS All times are GMT + 1 Hour
