Posted: Mon Apr 30, 2018 10:40 am Post subject: Using multiple LCDs
Normally with bascom you use only one lcd but sometimes its nice to have more than one
Here I will show how to use four or more by switching the chip select lines with an analog switch IC.
Below is a circuit diagram to show how its done I will post some code when I have finished testing
Here are two LCDs displaying different information
this is data from my offgrid solar system
and code used to initialise the two LCDs
Regards Paul
Glcd_cs1 AliasPortc.2
Glcd_cs2 AliasPortc.3
'select LCD two
'Portd.7 = 0 ResetPortd.7 'Portd.6 = 1 SetPortd.6
'make both chip select 1 Set Glcd_cs1
Set Glcd_cs2
'call initialise LCD from library
!call _Init_lcd
'make both chip select 0 Reset Glcd_cs1
Reset Glcd_cs2
Set Glcd_cs2
!call _Init_lcd
Reset Glcd_cs2
Yes we have two solutions for character LCDs SPI & I2C
These are graphic LCDs it would be great to have the same for them
they use almost two ports.
Regards Paul
