DIFFERENCE SPEED PORTC VS PORTB ATMEGA644P
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions
benoit
PostPosted: Thu Jun 07, 2018 6:36 am    Post subject: DIFFERENCE SPEED PORTC VS PORTB ATMEGA644P Reply with quote
HELLO
I FOUND THAT THERE IS A DIFFERENCE SPEED BETWEEN PORTC AND PORT B
atmega644p
voltage vcc 5v25 (under dont start) current consumption >100ma
first of all clock at 40mhz with external clock fuze 010000
program in basic (may be in asm it is faster)
do
portc=0
portc=255
loop
speed mesured at oscilloscop 2.69mhz the same for porta and portd
do
portb=0
portb=255
loop
speed mesured at oscilloscop 5.76mhz
the frequency is stable in all case
WHY THIS DIFFERENCE ?
(BASCOM-AVR version : 2.0.7.3 , Latest : 2.0.8.1 )
laborratte
PostPosted: Thu Jun 07, 2018 2:22 pm    Post subject: Reply with quote
You really wonder that the chip does weird things when you run it way outside its specifications?
benoit
PostPosted: Sun Jun 10, 2018 3:26 pm    Post subject: Reply with quote
HELLO
IF I DISABLE INTERRUPT ALL THE PORTS RUN AT SAME FREQUENCY LET 5.76MHZ
LET ABOUT 11MHZ BY BYTES
GOOD
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions All times are GMT + 1 Hour
