BascomAVR IDE -> Kanda AVRUSB-ISP
Goto page 1, 2  Next
Wattsy
PostPosted: Wed May 30, 2018 7:40 am    Post subject: BascomAVR IDE -> Kanda AVRUSB-ISP Reply with quote
Hiya,
I have copied this from the 'Various' forum as I posted it there by mistake - apologies for the duplication.
Hoping someone can give me a pointer or two.
I have been using Kanda's STK200 and 300 boards for a while but have never been able to 'see' the chip to be programmed on the STK board using the supplied Kanda USB-ISP programmer from the Bascom-AVR IDE.
I *can* see the chip (whatever it is I'm using at the time) on the STK if I use Kanda's AVRISP-U application. BUT, to use the app I need to save it in the Bascom-AVR IDE then open it in the Kanda AVRISP-U app. Not a huge problem simply an annoyance and an extra couple of steps each time I make a change to the code.
Is there a way to use Kanda's AVRISP-U dongle & STK board directly via the Bascom-AVR IDE please ?
Whatever setting / option I select to select the AVRISP-U programmer from within the Bascom-AVR IDE I am unable to 'see' the on board chip.
Any ideas / pointers as to what I'm doing wrong / what I should be doing please ?
Many thanks in advance !
(BASCOM-AVR version : 2.0.8.1 )
and there it was... gone !
Bascom Full Version 2.0.8.1
STK300 IDE
Wattsy
PostPosted: Wed May 30, 2018 8:17 am    Post subject: More info Reply with quote
...some more detailed info (just in case it helps) :
I'm using a Windows 10 on a Windows Surface Pro, Bascom-AVR 2.0.8.1 and a Kanda.com USB ISP2.
I have connected the KandaUSB-ISP to the Surface and I get the 'connected' tadaa tone.
Using Kanda's AVR-ISP software and loading the Bascom created hex file I can see, connect and program the ATMega16 on the STK200 board.
Trying to connect to the same setup using Bascom results in a "USB programmer not found"message.
Clicking on "OK" rerults in a "Erasing chip, are you sure message".
Clicking "Yes" or "No" resultrs in another "USB programmer not found" message. Clicking "OK" results in a repeat of the last message "USB programmer not found".
Clicking "OK" after that results in a "Difference at 00000" message.
Clicking "OK" after that produces a 'dalek' sound and a completion of the error
message sequence.
In 'Options'/'Programmer' I have tried 'AVR ISP Programmer', 'STK200/STK300 Programmer', 'USBProg programmer / AVR ISP mkII', 'USB ISP programmer' and various others.
All fail.
Do I need to do soemthing else to point the Bascom-AVR IDE's selected USB programmer to some specific USB / virtual comm port 'thing' or... ?
Hope the above helps a bit and goes some way to proving I am trying to fix this myself but have drawn a blank !
Any help please ?
STK300 IDE
PostPosted: Wed May 30, 2018 8:52 am    Post subject: Reply with quote
https://wiki.mcselec.com/bavr/index.php?title=LIBUSB
PostPosted: Wed May 30, 2018 9:11 am    Post subject: Reply with quote
That programmer is not supported. So it will not work. you can only try the 'external programmer' option and call their software.
Years ago Kanda bought a lot of CD licenses from us and then they wend bankrupt without paying the bill.
Some weeks later they happily continued using the same name and staff but without paying the bills.
After that i had it with kanda and as a result there is no support for their programmers.
Wattsy
PostPosted: Wed May 30, 2018 1:09 pm    Post subject: Reply with quote
Sorry to hear that Mark. Truly I am.
I am trying to be helpful here :
Maybe a message saying something like : "Kanda programmers (STK200/300) NOT supported !" would be helpful on your site.
To be fair, the Programmer options in the IDE are confusing in that the IDE appears (to the otherwise uninitiated) to give the option for : STK200/STK300 programmer, STK500 programmer, AVR USB ISP programmer - all leading me (and others, I'm sure) to beleive that the Kanda kit IS supported. Had I known otherwise I ewould NOT have purchased the Kanda STKs.
Not your fault - most certainly - and, like I say, I'm truly sorry for you. It's this sort of behaviour that really causes companies like yours and mine unnecessary pain and suffering !
Thanks for the quick response. Would you recommend a programmer (or two) to handle a range of the Atmel micros please ?
Anywatys, as always, thanks.
Regards.
STK300 IDE
Wattsy
PostPosted: Wed May 30, 2018 1:15 pm    Post subject: Reply with quote
Hi MWS.
Thanks for your response.
Yep, I'd tried that. got to the last step of Scenario 1 successfully but I lost my way at the line :
Now the programmer will work in BASCOM. Just select the proper programmer, and timeout of 100 ms. You can try lower time outs too to make it quicker. When you get errors, increase the time out. 100 ms should do for all programmers.
Which 'proper programmer' do I select please ?
I'm not really expecting a specific answer but just how to know the 'proper programmer' name ?
Again, thanks.
Regards.
STK300 IDE
PostPosted: Wed May 30, 2018 1:21 pm    Post subject: Reply with quote
stk200 and stk300 ARE supported.(LPT programmers) But they are not from Kanda but from atmel. Kanda only designed them from atmel just like the stk200/stk300.
the problem is that many companies all named 'their' programmer USB ISP.
The USB-ISP programmer refers to the EMBUD USB-ISP programmer which they do not make anymore.
The UsbProg Programmer / AVR ISP mkII is named because the author requested so. But it is a clone of the atmel ISP mkII. Olimex has clones too that work.
The Kamprog works without drivers (that is they use built in windows drivers) but they were no on stock last time i checked.
The mySmartUSB light skt500 mode programmer is a nice and cheap one.
Wattsy
PostPosted: Wed May 30, 2018 1:52 pm    Post subject: Reply with quote
Thanks Mark, much appreciated.
Regards.
STK300 IDE
PostPosted: Wed May 30, 2018 2:48 pm    Post subject: Reply with quote
yes it is the best one
even when Windows 10 do update it works !
you will found it here
http://shop.myavr.com/index.php?sp=article.sp.php&artID=200006
but don't forget the adapter 6 to 10 pins :
http://shop.myavr.com/index.php?sp=article.sp.php&artID=100075
If you have any problem let me know by MP
JP
Wink
PostPosted: Wed May 30, 2018 3:49 pm    Post subject: Reply with quote
Someday you may want to program Xmega chip and then clone/origin AVR ISP MK2 is the best solution because it cover ISP,TPI and PDI means Attiny + Megas + Xmegas and clone price is very low now...
O-Family
PostPosted: Thu May 31, 2018 1:01 am    Post subject: Reply with quote
I also think that Atmel genuine AVRISPmkII clone writer is good.
[USB AVRISP XPII], the function and appearance are very similar to AVRISPmkII.
This is very compatible with BASCOM-AVR.
You can also use it from Atmel Studio without problems, you can also update the same firmware as genuine.
https://www.waveshare.com/product/mcu-tools/avr/programmers-debuggers.htm
The comparison article is in Japanese, so please translate it on Google.
Original Japanese.
http://www.ne.jp/asahi/shared/o-family/ElecRoom/AVRMCOM/AVRISPmkII/AVRISPmkII.html
English translation.
http://translate.google.com/translate?hl=ja&sl=auto&tl=en&u=http%3A%2F%2Fwww.ne.jp%2Fasahi%2Fshared%2Fo-family%2FElecRoom%2FAVRMCOM%2FAVRISPmkII%2FAVRISPmkII.html&sandbox=1
retailer.
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20180530155853&SearchText=AVRISP+XPII
Wattsy
PostPosted: Thu May 31, 2018 8:47 am    Post subject: Reply with quote
Hi all.
Thanks to all of you. Great advice. I do have one question though (at the bottom) :
JP : 'MySmartUSB Light' looks great. And only 22Euro on Amazon France with 2 day delivery !
EDC :
Someday you may want to program Xmega chip and then clone/origin AVR ISP MK2 is the best solution...
. Understood. I used to use the ATMega 1281 and 2561's and now I'm playing with ATtiny 2313's and 85's amongst others, so flexibility / ability to handle the range of AVRs would be great.
O-Family :
. Understood too !
So, to my question :
Would the programmer I purchase simply replace the Kanda AVRUSB programmer I have (USB one end and 10pin IDE connector at the other) and still connect to the Kanda / Atmel STK200 / STK300 ? Havbing 'invested' in the two STK boards I am reluctant to give them up - I'm hoping to simply replace the Kanda USB programmer with another and continue to use the STK boards... unless there are better options ?
Thanks again.
Regards.[/quote]
STK300 IDE
benoit
PostPosted: Thu May 31, 2018 9:02 am    Post subject: Reply with quote
HI
YOU CAN LOOK AT EBAY FOR FRENCH SELLER
LOOKAT " USBASP AVR ISP programmeur "
YOU CAN HAVE THEM FOR 5€
IT WORK WELL FOR ME
PostPosted: Thu May 31, 2018 9:43 am    Post subject: Reply with quote
a lot of answers... forum is living and well !
you use STK200 so it is 10 pin connector.
the genuine AVRISPmkII programmer or the "MySmartUSB Light" is a 6 pin one
I repeat don't forget the adapter 6 to 10 pins :
this converter is usable with the genuine AVRISPmkII programmer too
JP Wink
PostPosted: Thu May 31, 2018 9:53 am    Post subject: Reply with quote
Mr Duval,
Why use 10 pin connector where 6 pi is enough?
I can understand that KANDA was developed for dbuging with USART and they need more pins but for programming AVRs we do not need more than MasterInputSlaveOutput(MISO), Master OutputSlave Input (MOSI) ,Clock and reset for both if needed.
Goto page 1, 2  Next
Page 1 of 2
