Kanda USB_ISP issues
Wattsy
PostPosted: Tue May 29, 2018 7:21 pm    Post subject: Kanda USB_ISP issues Reply with quote
Hiya,
Hoping someone can give me a pointer or two.
I have been using Kanda's STK200 and 300 boards for a while but have never been able to 'see' the chip to be programmed on the STK board using the supplied Kanda USB-ISP programmer from the Bascom-AVR IDE.
I *can* see the chip (whatever it is I'm using at the time) on the STK if I use Kanda's AVRISP-U application. BUT, to use the app I need to save it in the Bascom-AVR IDE then open it in the Kanda AVRISP-U app. Not a huge problem simply an annoyance and an extra couple of steps each time I make a change to the code.
Is there a way to use Kanda's AVRISP-U dongle & STK board directly via the Bascom-AVR IDE please ?
Whatever setting / option I select to select the AVRISP-U programmer from within the Bascom-AVR IDE I am unable to 'see' the on board chip.
Any ideas / pointers as to what I'm doing wrong / what I should be doing please ?
Many thanks in advance !
(BASCOM-AVR version : 2.0.8.1 )
and there it was... gone !
Bascom Full Version 2.0.8.1
STK300 IDE
