Posted: Wed May 30, 2018 4:50 pm Post subject: Lookupstr(idx , variable) |
Hi everybody,
I would like to use Lookupstr(touchx, myvar)
where myvar must be a label address and not the label
is it possible ?
I do a touch screen keyboard
so I receive touchY and touchx
I have put my keyboard in data :
Line1:
Data " " , "1" , "2" , "3" , "4" , "5" , "6" , "7" , "8" , "9" , "0" , "-" , "+"
Linea:
Data " " , "A" , "Z" , "E" , "R" , "T" , "Y" , "U" , "I" , "O" , "P" , "x" , "/"
Lineq:
Data " " , "Q" , "S" , "D" , "F" , "G" , "H" , "J" , "K" , "L" , "M" , "=" , "@"
Linew:
Data " " , "W" , "X" , "C" , "V" , "B" , "N" , "?" , "," , "." , ":" , "g" , "d"
If Touchy < 480 And Touchy > 0 Then
Print "touchy: " ; Touchy
Touchy = 30 + Touchy
Touchy = Touchy \ 70
Print "intY:" ; Touchy
Select Case Touchy
Case 2
Ligne = Adr ligne1
Case 3
Ligne = Adr Lignea
Case 4
Ligne = Adr Ligneq
Case 5
Ligne = Adr Lignew
Case 6
and after I use
If Touchx < 800 And Touchx > 0 Then
Touchx = 65 + Touchx
Touchx = Touchx \ 66 ' 'dividion entiere de touchx give the idx in the data line
' Print "intx:" ; Touchx
Cle = Lookupstr(touchx , Ligne)
Call Lcd_text(cle , 10 , 80 , 1 , Red , White , 1)
but ligne =adr ligne1 or ligne=adr (ligne1)
give an error : Error : 93 Line : 180 Variable not dimensioned [ADR(LIGNE1)]
my var ligne is a word
the help said :"The label where the data starts. A variable with the address is accepted as well."
JP
:roll:
(BASCOM-AVR version : 2.0.8.1 ) _________________ pleasure to learn, to teach, to create |
laborratte
Posted: Wed May 30, 2018 6:14 pm Post subject: |
or you can do something like
Code: | Line1:
Linea:
Lineq:
Linew:
lineadr:
adr2 Line1
adr2 Linea
adr2 Lineq
adr2 Linew
Touchy = Touchy - 2
Ligne = lookup(Touchy,lineadr)
so adr2 puts the address of the label as data in memory. But keep in mind what edc mentioned: word-vars can only access 64KB data space. on bigger avrs put data statements in the beginning of your code:
Code: | regfile ="...."
'here starts your program
goto MyProgram
labels:
data...
data....
MyProgram:
'lets start
Posted: Thu May 31, 2018 9:55 am Post subject: |
EDC and laborratte
many thanks to your help
yes you right I must use code but here it is a too large program it fill 65% of a M2560
so I saw the help for adr2 and loadlabel and I saw the limit of 64ko... I'm looking for a B plan
The bestial way is to made a small macro
I let you know
Posted: Thu May 31, 2018 10:06 am Post subject: |
The first you should share with us what is the used micro... |
Posted: Thu May 31, 2018 10:37 am Post subject: |
Hi EDC
finally I find a simple solution with only 5 lines of code !
It works :
on a graphic 'Display SSD1963 800x480
ATmega2560 with the routine of H.Kipnik (many thanks for him) and the AVR DOS of Vögel Franz Josef
Code: | '
#if Use_touch = 1
If Touch_flag = 1 Then
Touchx = 0
Touchy = 0
Call Read_touch()
'Print "touchx: " ; Touchx
Touchx = Touchx \ 66 'dividion entiere de touchx little swing {65+1} to be ok with the picture
Touchy = Touchy \ 70 'dividion entiere de touchx
Select Case Touchy
Case 2 'ligne 1
Cle = Lookupstr(touchx , Line1)
Case 3 'Lignea
Cle = Lookupstr(touchx , Linea)
Case 4 'Ligneq
Cle = Lookupstr(touchx , Lineq)
Case 5 'Lignew
Cle = Lookupstr(touchx , Linew)
Case 6 'ligne other
Sentence = Sentence + Cle
Call Lcd_text(sentence , 10 , 80 , 1 , Red , White , 1)
Waitms 20
#endif
that the start of my work :
I design a French keyboard with draw8
I translate it in a bin file put on a sd card
I have to finish the prog but as usual I will share it
