medicb
Posted: Thu Oct 25, 2018 10:35 am Post subject: Encoder - what is wrong |
I want to get numbers between 0 and 4 but sometimes I get the number -1 or 5.
What is wrong?
$regfile = "m8adef.dat"
$crystal = 12000000
$hwstack = 64
$swstack = 32
$framesize = 128
Config Lcd = 40 * 2
Config Lcdpin = Pin , Db4 = Portd.5 , Db5 = Portd.6 , Db6 = Portb.2 , Db7 = Portb.1 , E = Portb.0 , Rs = Portd.7
Config Portd.4 = Input
Set Portd.4
Guzik Alias Pind.4
Cursor Off
Lcd "Menu"
Const Intermediate = 0 ' impulsy plusowe czy minusowe?
Const Int_pcint = 0 ' korzystamy z INT czy PCINT
Encoder_a Alias Pind.2 'PCINT18
Encoder_b Alias Pind.3 'PCINT19
Portd = Portd And &B11110011 'PINy PODRTD2 i PORTD.3 to wejścia
#if Intermediate = 0
Portd = Portd Or &B00001100 'podciąganie na PORTD.2 i PORTD.3
#endif
#if Int_pcint = 1
Pcmsk2 = &B00001100
Enable Pcint2
On Pcint2 Encoder_isr Nosave
#else
Config Int0 = Change 'ewentualnie INT0 = Change
Config Int1 = Change 'eventualnie INT1 = Change
Enable Int0 : On Int0 Encoder_isr Nosave
Enable Int1 : On Int1 Encoder_isr Nosave
#endif
Dim State As Byte , Enc_new As Byte , Enc_old As Byte , Steps As Integer , Old_steps As Integer
If Steps > 4 Then Steps = 4
If Steps < 0 Then Steps = 0
If Old_steps <> Steps Then
Old_steps = Steps
Locate 2 , 1
Lcd Old_steps ; " " ; "< "
Encoder_isr:
$asm
!PUSH R16
!PUSH R24
!PUSH R26
!PUSH R27
!PUSH R30
!PUSH R31
!in R24, sreg
!PUSH R24
$end Asm
Enc_new.0 = Encoder_a
Enc_new.1 = Encoder_b
Select Case Enc_new
Case 1
Select Case State
Case 0 : State = 1
Case 3 : State = 1
Case 4 : State = 5
Case 2
Select Case State
Case 0 : State = 2
Case 4 : State = 2
Case 3 : State = 6
#if Intermediate = 1
Case 3
#else
Case 0
#endif
Select Case State
Case 1 : State = 3
Case 2 : State = 4
Case 5 : State = 4
Case 6 : State = 3
Case 0
#else
Case 3
#endif
Select Case State
Case 5 : Incr Steps
Case 6 : Decr Steps
State = 0
' Tuned with NoSave Tool
$asm
!POP R24
!out sreg, r24
!POP R31
!POP R30
!POP R27
!POP R26
!POP R24
!POP R16
$end Asm
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.1 ) |
Posted: Thu Oct 25, 2018 11:08 am Post subject: Re: Encoder - what is wrong |
medicb wrote: | What is wrong? |
Assume the ISR is immediately executed with increase of Steps after this line when Steps is 4:
Code: | If Steps > 4 Then Steps = 4 |
After the ISR increased it, Steps is 5, at least the short moment until the main loop is executed again and sets it back to 4.
Limiting a variable against under- or overflow has to be done where it is altered and that is within the ISR at the incr/decr block. |
Posted: Thu Oct 25, 2018 11:34 am Post subject: |
This code was written for one variable only. For driving some menus (I suppose that by line "Lcd "Menu") better is use it like that: Encoder can set value +1 or -1 and this you can use for increment/decrement any variable in the menu. At the end of "If Steps<>0" you simply make Steps=0.
Should work now...
Code: | $regfile = "m8adef.dat"
$crystal = 12000000
$hwstack = 64
$swstack = 32
$framesize = 128
Config Lcd = 40x2
Set Portd.4
Guzik Alias Pind.4
Cursor Off
Lcd "Menu"
#endif
#if Int_pcint = 1
Pcmsk2 = &B00001100
Enable Pcint2
#else
#endif
Dim Your_value As Byte
If Steps <> 0 Then
Select Case Steps
Case Is < 0
If Old_steps > 0 Then Decr Old_steps
Case Is > 0
If Old_steps < 4 Then Incr Old_steps
Locate 2 , 1 : Lcd Old_steps ; " " ; "< "
Steps = 0
Encoder_isr:
$asm
!PUSH R16
!PUSH R24
!PUSH R25
!PUSH R26
!PUSH R27
!IN R24, SREG
!PUSH R24
$end asm
Select Case Enc_new
Case 1
Select Case State
Case 0 : State = 1
Case 3 : State = 1
Case 4 : State = 5
Case 2
Select Case State
Case 0 : State = 2
Case 4 : State = 2
Case 3 : State = 6
Case 3
#else
Case 0
#endif
Select Case State
Case 1 : State = 3
Case 2 : State = 4
Case 5 : State = 4
Case 6 : State = 3
Case 0
#else
Case 3
#endif
Select Case State
Case 5 : Steps = 1
Case 6 : Steps = -1
State = 0
' Tuned with NoSave Tool 1.10
$asm
!POP R24
!OUT SREG, R24
!POP R27
!POP R26
!POP R25
!POP R24
!POP R16
$end asm
