LCD Keypad Shield (ADC Keypad)
PostPosted: Thu Apr 26, 2018 4:31 pm    Post subject: LCD Keypad Shield (ADC Keypad) Reply with quote
Cause I got this module so I wrote basic code for it (LCD connections and kepad with autorepaeat).
Code is like framework "ready to use" Very Happy
This keypad is connected to the only one pin A0
You can watch how this code works -> LINK TO VIDEO
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 32
$framesize = 128
'*         LCD KEYPAD SHIELD DEMO              *
'*    RobotDyn Shield with resistive keypad    *
'*  Demo shows hardware configuration, and     *
'*      function for reading switches          *
'*                                   by BARTek *
Config Submode = New
'*           ALPHANUMERIC LCD                  *
 Config Lcdpin = Pin , Rs = Portb.0 , E = Portb.1 , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7
 Config Lcd = 16x2
 Cursor Off , Noblink : Cls
'*         CONFIG ADC FOR SWITCHES             *
 Config Adc = Single , Prescaler = Auto , Reference = Avcc
'*            TIMER2 FOR TIME BASE             *
 Config Timer2 = Timer , Prescale = 1024 , Compare_a = Disconnect , Clear_timer = 1
 Compare2a = 155                                            '10ms @16MHz
'*                VARIABLES                    *
 Const Sw_r = 1
 Const Sw_u = 2
 Const Sw_d = 3
 Const Sw_l = 4
 Const Sw_s = 5
'switches
  Dim Old_key As Byte , Key_cnt As Byte , Key As Byte
'demo
  Dim Lr As Integer , Up_dn As Integer , Flipb As Byte
Function Read_keypad() As Byte
 'function with autorepeat
 Local Adc_read As Word , Read_key As Byte , Key_val As Byte
   Adc_read = Getadc(0)
   Select Case Adc_read
    Case 0 To 100 : Read_key = Sw_r                         'right = 0
    Case 101 To 250 : Read_key = Sw_u                       'up = 145
    Case 251 To 400 : Read_key = Sw_d                       'dwn = 330
    Case 401 To 600 : Read_key = Sw_l                       'left = 506
    Case 601 To 850 : Read_key = Sw_s                       'select = 743
    Case Is > 851 : Read_key = 0                            'no key = 1023
   End Select
   If Read_key <> 0 Then
    If Old_key = Read_key Then
     If Key_cnt < 20 Then
      Incr Key_cnt
       Key_val = 0
     Else
      Key_cnt = 0
       Key_val = Read_key
   Else
    Key_cnt = 15
     Key_val = 0
   Old_key = Read_key
    Read_keypad = Key_val
End Function
'for demo
Locate 1 , 1 : Lcd "UpDn=0"
Locate 2 , 6 : Lcd "< 0 >"
Locate 1 , 14 : Lcd "*"
 If Tifr2.ocf2a = 1 Then                                    '10ms
   Tifr2.ocf2a = 1
   Key = Read_keypad()
   If Key <> 0 Then
    Select Case Key
     Case Sw_u
      If Up_dn < 9 Then Incr Up_dn
       Locate 1 , 6 : Lcd Up_dn ; " "
     Case Sw_d
      If Up_dn > -9 Then Decr Up_dn
     Case Sw_r
      If Lr < 9 Then Incr Lr
       Locate 2 , 7 : If Lr >= 0 Then Lcd " " : Lcd Lr
     Case Sw_l
      If Lr > -9 Then Decr Lr
     Case Sw_s
       Locate 1 , 14
       If Flipb = 0 Then
        Lcd " *" : Flipb = 1
       Else
        Lcd "* " : Flipb = 0
    End Select
    Key = 0
PostPosted: Thu Apr 26, 2018 6:27 pm    Post subject: Reply with quote
Hi EDC,
I used this keyboard too, it is an excellent tools to learn the ADC to people
I like the way you use the timer
If Tifr2.ocf2a = 1 Then '10ms 'from doc : The compare match event will also set the
' Compare Flag (OCF2A or OCF2B) which can be used to generate an Output Compare interrupt request.
Tifr2.ocf2a = 1
Key = Read_keypad()
Nice Work Mister Expert Wink
JP
PostPosted: Fri Apr 27, 2018 8:30 pm    Post subject: Reply with quote
Thank you for sharing. And for the nice video demo. Nice clear demo. Well done !
