DIR & Type /Dump
nicofer
PostPosted: Tue Apr 17, 2018 8:14 am    Post subject: DIR & Type /Dump Reply with quote
Hi .
I use a XX128 with a USB- serial interface with SD card for data .
At the moment I need to take the SD card out and , get filename and copy the file to a pc if required , all working fine.
I want to perform this all over the usb / serial interface .
I have used the DIR / TYPE / DUMP commands in the FS_interpreter.bas in the SAMPLE files but need to use only those few commands to copy the file .
What would be the minimum code to perform only a file DIR and then copy to PC ( via serial terminal) - I also only need to access a single
file at a time ?
Regards
Nico
