KBD Interrupt on AT89C51ED2
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
dunkelbunt
PostPosted: Wed Mar 28, 2018 4:20 pm    Post subject: KBD Interrupt on AT89C51ED2 Reply with quote
I'm dealing with a AT89C51ED2. I'd like to use the kbd-interrupt, which rises when input on P1.x changes.
But when code is compiled the following error come up:
Error 13: UNKNOWN INTERRUPT [KBD]
Is there a way to solve that problem or isn't this interrupt supported by BASCOM?
Thank you for your help. Smile
$regfile "89C51ED2.dat"
$baud = 9600                                                  'set your own baudrate
$crystal = 20000000
Dim S1 As String * 16
Dim I As Integer
Dim Count As Integer
On Kbd Kbd_init
Enable Kbd                                                    'set your own crystal frequen
   Print Count
   If Count > 10 Then
      I = Makeint(p1 , P4)
      S1 = Bin(i)
      Print "Port1: " ; S1
      Count = 0
   End if
Kbd_init:
Incr Count
PostPosted: Wed Mar 28, 2018 8:29 pm    Post subject: Reply with quote
you can add them to the dat file.
open it with notepad then make sure the end of the file looks like this :
[MISC]
I_TIMER2 = 2B
I_PCA=33
I_KBD=3B
I_DUM=43
I_SPI=4B
up=89C51ED2
IRAM = 256
org = 2E
clockdiv = 6
to enable the interrupt you manual need to set the register : Ie1.1 = 1
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
