voltage level right or not?
krolikbest
PostPosted: Sat Mar 10, 2018 7:53 pm    Post subject: voltage level right or not? Reply with quote
Hello,
here i attach my simple code:
$regfile = "m8adef.dat"
$crystal = 8000000
Config Pinb.1 = Output 'step silnik2
silnik2 Alias Portb.1
config pinc.2=output
kier Alias Portc.2
Dim rozruch2 as Integer, szybko2 as Integer, wolno2 as Integer
$baud = 19200                                               ' baud rate
Config Timer1 = Timer, Prescale = 64, Compare A = Disconnect, Compare B = Disconnect, Clear Timer = 1
On compare1a run_stepper2
Compare1a = szybko2
szybko2=120
silnik2=0
run_stepper2:
 Toggle silnik2
as you may guess this is for running stepper motor. But on output pin voltage level is only 2.14V while ATMega8 is sourced with 5v connected to VCC(d7) and AVCC(d20), so I expected that output will be ~5v. In the output (pin PB1) i use 1N4148 as a protection.
When I test it with a small lighting diode it works, it means, square wave generator works and diode is blinking all the time. But when I connect atmega's output to stepper's controller as a PULSE signal, it works for a while(1 sec) and then stops. Parallel i've connected oscilloscope 'Hantek' and see that ATmega8 is generating square wave no more! It looks like stepper (or to be more precise) stepper's controller stops ATMega8?
So with lighting diode atmega8 is generating square wave all time, with stepper only for a while. I suppose that either some kind of level shifter should be used or ... Maybe someone has similar experience?
Best regards
Martin
(BASCOM-AVR version : 2.0.7.6 , Latest : 2.0.8.1 )
PostPosted: Sat Mar 10, 2018 10:00 pm    Post subject: Reply with quote
Beside where it would make sense, I would not use a signed variable to control an unsigned register.
Also this code part makes no sense:
Compare1a = szybko2
szybko2=120
silnik2=0
as szybko2 is zero at start, compare1a is and stays thus zero too, because writing szybko2 to 120 has no effect on compare1a.
Compare1a however is timer-top in CTC-mode, surely not intended this way.
Else, it may be a hardware issue of noisy power line, locking up the controller.
krolikbest
PostPosted: Sun Mar 11, 2018 11:38 am    Post subject: Reply with quote
You are right but this piece of code is not exactly what is in uC. This is only few lines copied/pasted (probably there i did mistake during pasteing) from the whole program to demonstarte the problem.
Ok, found the problem. As you may know, AVCC should be connected to VCC and all GND to ground. For AVCC i did but not for one of GND. That was a problem. So many time checked .. Smile
<SOLVED>
PostPosted: Sun Mar 11, 2018 11:58 am    Post subject: Reply with quote
Are you joking? You're asking for help and for that purpose you post code, which you do not actually use?
Even after you get aware of that, you still don't post actual code.
Surely the error may be in hardware - something which you also do not show - but it may be a software issue.
It seems you assume the latter, otherwise this is the wrong part of the forum.
Good luck, you surly need it.
krolikbest
PostPosted: Sun Mar 11, 2018 12:03 pm    Post subject: Reply with quote
Ok, sorry. But you were right that problem WAS in hardware. Now it works, i've described in my previous post what was bad. Thank you and good luck too Wink
