Micha
Posted: Sun Jan 28, 2018 1:51 pm Post subject: Incorrect display in the editor window |
Hello everybody
I use the Bascom AVR version 2.0.8.1 and have already found in the version 2.0.8.0 the same effect.
Namely, the lines of code in the editor window are displayed incorrectly. For this I attached a picture.
If you call the Code Exploorer if it is displayed incorrectly, the content in the editor window is redrawn and displayed correctly.
This effect often occurs when scrolling lines of code.
Question:
Do you know the effect and what can you do about it? Is there perhaps a bug here from version 2.0.8.0?
Thanks for help.
(BASCOM-AVR version : 2.0.8.1 ) |
Posted: Mon Jan 29, 2018 11:53 am Post subject: |
this seems to be a bug in the 'dead code' and 'unused code' redrawing. but i am not sure.
you can turn these options off in the Edit menu and see if it will fix the problem.
when you have a problem like this it is important that others can reproduce it in order to check it.
in order to reproduce we need to know :
- used settings. you can attach your xml settings file (how to do it, i wrote that numerous times before)
- or show screen shots of your settings in relation to the editor
- have some sample code that will produce the problem, a sample file from MCS would be best
- show the steps needed to get the problem : for example, open files 'xx' , go to line 'xxx' and use page down. etc. _________________ Mark |
Micha
Posted: Mon Jan 29, 2018 5:24 pm Post subject: My used Settings, How to reproduce the incorrect display |
Hello Mark
I'm glad that you take care of it yourself.
My settings:
I use the settings as in the appendix. I have attached the XML file and the pictures.
Example Code
I was able to reproduce the error with the following file.
C: \ Users \ Michael \ Documents \ MCS Electronics \ BASCOM-AVR \ Samples \ 1WIRE \ 1wireDS2450.bas
To get the error do the following:
1. Replace your XML file with mine
2. Open BascomAVR 2.0.8.1 with my settings
3. Open the example file from above
4. Slowly scroll the entire code all the way down and back. Repeat this several times.
Try this a few times until you see the effect.
I use in the editor font courier new with size 12 'normal' not bold.
I hope the effect occurs with you too. Because I do not want to downgrade to version 2.0.7.8.
If you have questions, like.
I look forward to your result.
Mitch |
AdrianJ
Posted: Mon Jan 29, 2018 10:47 pm Post subject: |
I too had problems ( although not quite the same ) when using Courier font. Mark suggested switch to Consolas font in the IDE, and that has been working fine. _________________ Adrian Jansen
Micha
Posted: Tue Jan 30, 2018 7:33 pm Post subject: |
Hello
I tried to limit the error.
And one thing is for sure.
The settings in the menu "Show Excluded Code" and "Show Dead Code" have no effect. This definitely eliminates as the cause of the error.
If the font is changed to "Consolas", the effect does not occur.
It seems only on Courier New with larger font sizes (> 12pt).
Older versions up to 2.7.0.8 worked well with the font "Courier New 12pt".
Can not lie on the font, because before the update from Bascom to 2.0.8.1 the error did not occur.
It must be in my opinion at the IDE itself.
I hope that the programmer is doing the thing.
Because it should not be the solution to use a different font.
For the following actions in the IDE, the content of the editor was redrawn so that the display error disappeared.
- Shrink and restore the program to the taskbar
- Move the mouse over the code explorer so that it is updated
- Switch between the code pages, multiple files are loaded in the editor
Maybe after scrolling it will be enough to simply send the Windows message "Paint" again.
Hope the mistake can be found and eliminated.
Mitch |
Posted: Mon Feb 12, 2018 12:55 pm Post subject: |
you need to select 'use monofont' in options. that will solve the problem when using font like courier new. _________________ Mark |
Micha
Posted: Tue Feb 13, 2018 6:24 am Post subject: |
albertsm wrote: | you need to select 'use monofont' in options. that will solve the problem when using font like courier new. |
Hi Mark
I've tested font "Courier New" with selected Option "Use monofont" and it works.
Thank you very much for this great tip.
Micha. |
