Debugging in AVR Studio
Goto page 1, 2  Next
jure_m
PostPosted: Wed Jan 20, 2010 12:08 am    Post subject: Debugging in AVR Studio Reply with quote
Hi all,
this thread gave me a "kick" this afternoon until I've done it (thanks Luciano!).
I was using JTAG ICE clone, like this one, after few hours I have connected it to ATmega32 uC, then I followed Luciano's tip how to start OBJ code generated with Bascom in the AVR studio. There was one small change: simulator that I selected was JTAG ICE - and voila: I can step into code with actual debugging on real micro controller. When I press STOP, program inside uC stops, steps by step etc. As far as I test all seems to work nice Very Happy
It's rather late hour now so I will stop my work now, but will report soon more about this interesting topic.
Jure
jure_m
PostPosted: Thu Feb 04, 2010 7:15 pm    Post subject: Reply with quote
just a short update on that topic.
I have used JTAG ICE with Bascom OBJ code with success. I could also change variables and see immediate effect on running program.
I will shortly report how goes on debugging with interrupt routines.
Jure
PostPosted: Thu Feb 04, 2010 11:26 pm    Post subject: Reply with quote
Yes, it works really well. But the one thing Bascom misses is that it does not generate an ELF file. If it did, you would have the named variables available in AVR Studio, and could watch the variables change as you run the code. With just the .obj module, you must look at the memory locations to see the changes.
Adrian Jansen
enniom
PostPosted: Sat Feb 06, 2010 8:57 pm    Post subject: Reply with quote
Adrian,
have you developed some "system" to view the changing variables for us less-experienced users to adopt and use? For example: a variable memory map, hex converter, etc??
Ennio
PostPosted: Sun Feb 07, 2010 1:08 am    Post subject: Reply with quote
@enniom
No, I never had those tools when I grew up with using ASM on micro controllers, so I got used to looking at raw memory dumps to find out what is going on. With Bascom, the compiler report gives the variable locations, and I just use that alongside AVR Studio. But then I have done it that way for 30+ years. Some better tools would be nice, but I am usually too busy writing applications to write tools.
Adrian Jansen
laborratte
PostPosted: Thu Feb 11, 2010 6:36 pm    Post subject: Reply with quote
I wrote a small tool for viewing vars in AVR-Studio some years ago (see attached file). Sometimes it is helpfull.
Usage from commandline:
avrmapbuilder YourProgramm.rpt YourProgramm.map
It generates a .MAP-File like the AVR Assembler from a Bascom .RPT-File. If the MAP File is in the same Directory as your .OBJ-File, AVR Studio recognized it and you can use the watch window for your variable names.
But it is still assember-like, so you can only watch byte values. My workaround is splitting word or long-vars like that:
BASIC:
dim bOne as byte
dim wTwo as word
dim lThree as long
watch-vars:
bOne
wTwo_L     '(Low-byte of wTwo)
wTwo_H     '(High-byte of wTwo)
lThree_LL   '(Lowest byte of lThree)
lThree_LH
lThree_HL
lThree_HH   '(Highest byte of lThree)
Arrays are also recognized. Just look into the generated .MAP file for details.
It is a small tool I wrote for myself, so don't expect a user interface, cool sound effects or updates and improvements. Also the watch windows in AVR_studio seems sometimes a little bit buggy (like the disassembler view).
For shure: it would be much nicer, if BASCOM would generate a .ELF-File (or even better: a .COFF-File). Oh please, Mark, please.....
enniom
PostPosted: Thu Feb 11, 2010 6:47 pm    Post subject: Reply with quote
Thank-you Laborratte - this is a great start.
Do you think we can help Mark by laying out the requirements of an *.ELF file?
PostPosted: Thu Feb 11, 2010 11:34 pm    Post subject: Reply with quote
@laborratte
Nice !
Maybe now the hard work of the XMega stuff is out of the way, Mark might have time. *Please*
Adrian Jansen
jure_m
PostPosted: Fri Feb 12, 2010 11:06 pm    Post subject: Reply with quote
Well, actually you can watch variables in the Memory window. In Bascom report file you can find address of all variables, then you can access these variables within AVR Studio and monitor/change them.
PostPosted: Fri Feb 12, 2010 11:43 pm    Post subject: Reply with quote
I should visit the forum more often Smile
Very nice to see this.
I wanted to support COFF but got reply from atmel that they will not support it anymore. ELF is the way to go.
I did not got very clear info on ELF.
I am happy to generate all the required info for COFF or ELF.
Or even the map if that will work for all variables.
While Xmega is done for a big part it is not finished. Things like timers and other hardware need to be handled. Of course you can access all registers and most users that need to use Xmega should be able to do so, but to say it is finished, no.
After i released the IDE beta (which was scheduled for last Xmas Sad ), i will continue xmega support.
So any help would be great Smile
you can contact me at mark at youknow which domain Smile
Also, do you know ISIS simulator? They added bascom DBG format. You can simulate and watch variables. I found it more convenient then Studio. Especial all the hardware you can simulate !
MHz
PostPosted: Sat Aug 21, 2010 7:44 am    Post subject: Reply with quote
Hi Mark,
watching variables in AVR studio is still an issue. Is there any progress I have missed
Regards Wink
PatchleAD
PostPosted: Thu Aug 26, 2010 11:01 pm    Post subject: Reply with quote
damn ... That ISIS looks sweet..... will need to look into it to see if it can import my Altium Designer circuits or is i need to re-draw them....
ex4
PostPosted: Fri Aug 27, 2010 12:43 am    Post subject: Reply with quote
ehem..ehemm...
hope someone dont mind on this word 'damn' , hehehehe Laughing
Altium, wow....
i thought altium specially made only for FPGA(thats what the Altium guy from Singapore told me on the phone)
View user's profile Visit poster's website AIM Address Yahoo Messenger
PatchleAD
PostPosted: Fri Aug 27, 2010 2:26 am    Post subject: Reply with quote
.... Laughing i must have miss spelled it .. I ment to say Dam.... and in the big pool of water... Wink
It is a massive package, I do not use it for the programming and simulation side (did not pay for it).... It is a great circuit and PCB design package but..
and I just got a email on the import into the ISIS ... It is a big NO.... Crying or Very sad
ex4
PostPosted: Fri Aug 27, 2010 2:37 am    Post subject: Reply with quote
mmm, yes it is a big package
a friend of mine using it. jeez about 2GB of files Shocked
but when i tell him about proteus,he just make a big woowww
Goto page 1, 2  Next
Page 1 of 2
