Two Stepper motor at different speeds
mastermindjp
PostPosted: Thu Jan 11, 2018 4:26 pm    Post subject: Two Stepper motor at different speeds Reply with quote
Hello Friends,
I am trying to run two Stepper motors, with same controller, together but at different speeds, but no success..
Take a look at the code and suggest any possible solutions..
$hwstack = 40
$regfile = "m32def.dat"
$swstack = 40
$framesize = 40
X_step Alias Portd.4
X_dir Alias Portd.3
Y_step Alias Porta.3
Y_dir Alias Porta.2
Config Y_step = Output
Config X_dir = Output
Config X_step = Output
Config Porta.4 = Output
Config Portd.5 = Output
Config Pinb.4 = Input
Config Pinb.5 = Input
Config Pinb.6 = Input
Config Pinb.3 = Input
Dim N As Word , M As Word
Porta.4 = 0
Portd.5 = 0
Begin:
Porta.4 = 0
Portd.5 = 0
N = 0
Lcd "SYSTEM READY"
Waitms 100
If Pinb.4 = 0 Then
       Porta.4 = 1
       Portd.5 = 1
       Reset Y_dir
       Reset X_dir
       Set Y_step
       Set X_step
       Waitms 2
       Reset Y_step
       Reset X_step
       Waitms 2
       Loop Until Pinb.4 = 1
       Portd.5 = 0
       Porta.4 = 0
       Waitms 100
If Pinb.5 = 0 Then
       Porta.4 = 1
       Portd.5 = 1
       Set Y_dir
       Set Y_step
       Waitms 2
       Reset Y_step
       Waitms 2
       Set X_dir
       Set X_step
       Waitus 500
       Reset X_step
       Waitus 500
       Loop Until Pinb.5 = 1
       Portd.5 = 0
       Porta.4 = 0
       Waitms 100
waitms 100
goto begin
thanks
Aniruddha
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.1 )
We are not innovating, we are just manipulating innovations done by Mother Nature.......
mastermindjp
PostPosted: Fri Jan 12, 2018 9:36 am    Post subject: Reply with quote
Forgot to add, using Stepper Motor Driver,
A4988.
Aniruddha
PostPosted: Fri Jan 12, 2018 3:33 pm    Post subject: Reply with quote
This should be almost as simply as the software PWM is.
You should define what resolution of steps you need then run some 2xspeed interrupt.
In this interrupt :
if steps for first_motor > 0 then
 If Speed1 = 0 Then
  Decr Speed1
  Speed1 = My_speed1 'My_speed1 is the divider or countdown for toggle port
   Toggle Clk1
    decr steps_for_first_motor
End if
if steps for second_motor2 > 0 then
 If Speed2 = 0 Then
  Decr Speed2
  Speed2 = My_speed2
   Toggle Clk2  'output for clocking second module
    decr steps_for_second_motor
End if
You can also use PWM of Timer1 and Timer2 in PWM8 Bit both....
Vary your needs
Per Svensson
PostPosted: Tue Jan 16, 2018 12:17 am    Post subject: Reply with quote
Have a look at this:
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=14042
mastermindjp
PostPosted: Thu Jan 18, 2018 7:44 am    Post subject: Reply with quote
Hello friends,
Thank you both of you for the valuable suggestions and link.
Will work on it.
Aniruddha
