Porelo
Posted: Thu Dec 07, 2017 3:06 pm Post subject: I need help understanding what's wrong with the sed1330 rout |
I need help for "sed1330", with the lib available in the forum I can not that it works does nothing, compiler without errors, but it does not work what can be wrong ??
this is the test code
$regfile = "m128def.dat" ' specify the used micro
$baud = 38400 ' use baud rate
$hwstack = 550 ' default use 32 for the hardware stack
$swstack = 550 ' default use 10 for the SW stack
$framesize = 430 ' default use 40 for the frame space
$lib "glcd-sed1330.lib"
Const Lcd_x_size = 320
Const Lcd_y_size = 240
'DEFENIÇÃO DO LCD
Config Graphlcd = 320 * 240sed1330 , Dataport = Porta , Controlport = Portc , Reset = 4 , Rd = 2 , Wr = 0 , Cs = 7 , A0 = 3 , Osc = 10000000
'CONFIG PORTA = OUTPUT
'CONFIG PORTC = OUTPUT
'Dim variables (y not used)
Dim X As Byte , Y As Byte
'Clear the screen will both clear text and graph display
'Cls
'Other options are :
' CLS TEXT to clear only the text display
' CLS GRAPH to clear only the graphical part
'Cursor Off
Wait 1
'locate works like the normal LCD locate statement
' LOCATE LINE,COLUMN LINE can be 1-8 and column 0-30
Locate 1 , 1
'Show some text
Lcd "MCS Electronics"
'And some othe text on line 2
Locate 2 , 1 : Lcd "T6963c support"
Locate 3 , 1 : Lcd "1234567890123456789012345678901234567890"
Locate 16 , 1 : Lcd "write this to the lower line"
Waitms 10
Cls Text
'use the new LINE statement to create a box
'LINE(X0,Y0) - (X1,Y1), on/off
Line(0 , 0) -(239 , 127) , 255 ' diagonal line
Line(0 , 127) -(239 , 0) , 255 ' diagonal line
Line(0 , 0) -(240 , 0) , 255 ' horizontal upper line
Line(0 , 127) -(239 , 127) , 255 'horizontal lower line
Line(0 , 0) -(0 , 127) , 255 ' vertical left line
Line(239 , 0) -(239 , 127) , 255 ' vertical right line
Wait 10
' draw a line using PSET X,Y, ON/OFF
' PSET on.off param is 0 to clear a pixel and any other value to turn it on
For X = 0 To 140
Pset X , 20 , 255 ' set the pixel
For X = 0 To 140
Pset X , 127 , 255 ' set the pixel
Wait 10
'circle time
'circle(X,Y), radius, color
'X,y is the middle of the circle,color must be 255 to show a pixel and 0 to clear a pixel
For X = 1 To 10
Circle(20 , 20) , X , 255 ' show circle
Wait 1
Circle(20 , 20) , X , 0 'remove circle
Wait 1
Wait 2
For X = 1 To 10
Waitms 200
Wait 10
'Now it is time to show a picture
'SHOWPIC X,Y,label
'The label points to a label that holds the image data
'Test:
'Showpic 0 , 0 , Plaatje
'Showpic 0 , 64 , Plaatje ' show 2 since we have a big display
'Wait 2
'Cls Text ' clear the text
'This label holds the mage data
Plaatje:
'$BGF will put the bitmap into the program at this location
$bgf "mcs.bgf"
'You could insert other picture data here
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.7.8 ) |
Posted: Thu Dec 07, 2017 9:16 pm Post subject: |
It is usually a good idea to simply toggle the pins and see if they work.
like :
config portc=output
do
toggle portc
waitms 1000
loop
do this for all pins you use. then connect the LCD.
Also, make sure the LCD is good and that it is indeed the type you think it is. _________________ Mark |
Evert :-)
Porelo
Posted: Fri Dec 08, 2017 1:10 am Post subject: |
thanks for the replies, disabled the M103 compatible fuse bit? = yes, it is in 128 mode.
In the hardware issue it works fine with any different lcd, I have 3 lcd (s) 2 with the same reference 1 different , but with the same results in all not working at all, even changing ports, I think the problem is the lib , which is this "https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=9540&highlight=sed1330".
I also changed sed1330 and memory ram with the same result, I have no idea what it might be, I've tried almost everything I do not know what to do. |
JC
Joined: 15 Dec 2007 Posts: 586 Location: Cleveland, OH
Posted: Fri Dec 08, 2017 7:47 pm Post subject: |
I don't have a seg1330 data sheet in front of me, but I'll still share a thought or two.
If you have a POT for contrast, have you tried adjusting it?
Have you measured it's output voltage?
If the display used a register to set the contrast, have you tried changing that?
Some displays take a long time to boot up internally.
Try, at least for now, putting a several second delay at the very start of your code, so that the display can boot up on power up before the micro sends it any commands. When you have it working, you can shorten the delay.
JC |
Porelo
Posted: Sun Aug 26, 2018 10:55 pm Post subject: |
My apologies for the percistence, but after testing a large number of "8" lcds with the sed1330f I think I have reached the conclusion only can be the library that is not correct or incomplete, can anyone confirm or help?
Posted: Mon Aug 27, 2018 9:08 am Post subject: Re: I need help understanding what's wrong with the sed1330 |
Porelo wrote: | Code: | $lib "glcd-sed1330.lib" |
Where this lib is from?
My actual Bascom-version doesn't know it, I get a lib-not-found compile error. |
Porelo
