Es gibt kein Register Tcf1_ovf in Xmega256A3
Ev3658
PostPosted: Wed Nov 22, 2017 4:24 pm    Post subject: Es gibt kein Register Tcf1_ovf in Xmega256A3 Reply with quote
Hallo, ich schreibe über einen Dolmetscher.
In den Timern Xmega256A3 8 kann ich den Ereigniskanal für Interrupts über den Timer-Überlauf Tcf1_OVF nicht bestimmen.
In [INTLIST] ist er auch abwesend.
Config Event_system = Dummy , Mux1 = Tcf1_ovf - Kompiliert, aber es gibt keine Unterbrechung.
On Tcf1_ovf Pl1 - Kompiliert nicht, erzeugt einen Fehler.
Простите за перевод, во всё виноват translate.google.ru :roll:
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.7.8 )
PostPosted: Wed Nov 22, 2017 5:07 pm    Post subject: Reply with quote
please write/translate to English.
There is no timer TCF1 in that micro. We will remove the references to TCF1.
So in short : it will not work since the resource is not available.
tomi
PostPosted: Wed Nov 22, 2017 9:36 pm    Post subject: Reply with quote
in attach you can find fixed dat file.
Best regards,
/Tomi
Sarek
PostPosted: Thu Nov 23, 2017 1:48 pm    Post subject: Reply with quote
this is not a bug in dat-File
there is simply no TCF1 in XMEGA 256A3 !!
Please look inside data sheet!
Ev3658
PostPosted: Thu Nov 23, 2017 10:04 pm    Post subject: Reply with quote
Indeed, there are only seven timers.
A wide range of interrupt or event sources are available, including T/C Overflow, Compare
match and Capture for each Compare/Capture channel in the T/C.
PORTC, PORTD and PORTE each has one Timer/Counter 0 and one Timer/Counter1. PORTF
I'm here not long ago, please tell me how to reset the counter on the index of quadrature decoding? (reset to zero on the 3 mark).
Config Pina.0 = Input                                       'A
Config Pina.1 = Input                                       'B
Config Pina.2 = Input                                       'Z
Config Xpin = Pina.0 , Sense = Rising
Config Xpin = Pina.1 , Sense = Rising                       '
Config Xpin = Pina.2 , Sense = Both
Config Event_system = Dummy , Mux0 = Porta.0 , Qd0 = Enabled , Qdi0 = Enabled , Qdirm0 = 2 , Digflt0 = 2
Config Tcc1 = Normal , Prescale = E0 , Event_source = E0 , Event_action = Qdec
I want to go to zero by the Z signal, but there are no details in the documentation of Xmega.
And how can I organize a 32 bit two directional account of two timers?
Sarek
PostPosted: Fri Nov 24, 2017 9:28 am    Post subject: Reply with quote
you need a second Event
like this
Config Event_system = Dummy , Mux1 = Porta.2 , Digflt1 = 2
Read data sheet!
Ev3658
PostPosted: Fri Nov 24, 2017 10:04 am    Post subject: Reply with quote
The problem is not to start the account, the problem is to reduce it and add it in the older timer.
QUAD----> ± Low Timer --EVENT- -> ± High Timer
I can not cause a (-) decrease in the second timer, only the (+) addition. Crying or Very sad (±)
