Simulator wait n and waitms n problem
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions
sidknox
PostPosted: Sun Nov 12, 2017 12:41 am    Post subject: Simulator wait n and waitms n problem Reply with quote
I am unable to make either "wait n" or "waitms n" work in the simulator.
This simple code example shows the problem:
'-----------[ Title ]----------------------------------------------------------
' Filename : Sim-Wait test.bas
' Purpose : testing wait and waitms in simulator
' Author : sid knox
' Date : 11 Nov 2017
' Compiler : BASCOM-AVR Rev. 2.0.7.8
' PC : Toshiba Satelite Pro, XP Pro SP3
'----------- [ Options/Compiler/Chip ] ------------------------------------------
$Regfile = "ATtiny2313.dat"
$Crystal = 1000000 'internal 8 MHz clock / 8
$hwstack = 32
$swstack = 32
$framesize = 32
$sim
'-------------------------------- [ Main] ------------------------------------------
print "start wait"
wait 3
'waitms 990
print "wait finished"
When I click the Run button (F5), both the print statements print to the sim's Terminal with no delay from the
"start wait" to the "wait finished" . This happens whether I use "wait" or waitms".
I have read Help for the Sim, read Help for WAIT, and searched the forum with the search string:
simulator wait
and found nothin related to what I am seeing.
The attached jpg shows what files the compiler made.
SidK
Oklahoma
USA
i.dobson
PostPosted: Sun Nov 12, 2017 8:40 am    Post subject: Reply with quote
Just remove the $sim command.
This tells the Compiler you want to run in the Simulator/which causes the Compiler to modify the code Abit (including removing delays).
Regards
Ian Dobson
sidknox
PostPosted: Mon Nov 13, 2017 5:02 am    Post subject: Reply with quote
Hi Ian,
You obviously know your way around the Simulator, that fixed it.
The delay time now is a factor of about 6 longer than the time specified in the 'Wait n' statement but that is ok for what I am doing. If I need a more precise time I can just tweak n as desired.
I have another Sim question but I'll start another thread.
I thank you for your help.
Sid
SidK
Oklahoma
USA
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions All times are GMT + 1 Hour
