How to auto remark unused variables?
TSEYFARTH
PostPosted: Wed Oct 11, 2017 5:13 am    Post subject: How to auto remark unused variables? Reply with quote
Hello all.
Using IDE version 2.0.8.0.004, the code explorer shows vars not used, but there does not appear to be a way to auto remark them all. Am I missing something? Is there a way? If so how?
Thank you!
Tim
(BASCOM-AVR version : 2.0.8 , Latest : 2.0.7.8 )
AdrianJ
PostPosted: Wed Oct 11, 2017 10:36 pm    Post subject: Reply with quote
Why go to the work of creating a variable if you are not going to use it ?
You can certainly have a collection of test variables, to see what is happening while debugging. If you use conditional compile, you can 'switch' them on only when the test code runs.
Const DebugMe = 1 'set to 0 for no debugging
#if DebugMe = 1
dim MyTestVar as  single
... 'any others you want
#endif
....'then in your code:
#if DebugMe = 1
MyTestVar = 'whatever you want to get from working variables
print MyTestVar
#endif
So the debugging variables are only defined and used when in debugging mode.
This way you can set up quite complex debugging stuff, and switch it in and out as needed, eg by setting the DebugMe constant to a different value for each run
Adrian Jansen
TSEYFARTH
PostPosted: Wed Oct 11, 2017 11:22 pm    Post subject: Reply with quote
Hi Adrian,
Thank you for your reply. That is not exactly what I am looking for. I used code from a different project that was very near what the new project has to do. However now, in this smaller project, there are tons of vars dimensioned which are not used. The IDE *knows* which are not used (dead they call them) but I was hoping there was a way to automatically remark them out. ie an IDE function.
Thanks again,
Tim
AdrianJ
PostPosted: Thu Oct 12, 2017 5:40 am    Post subject: Reply with quote
No way to automate it that I know of, but you can at least double-click on the greyed out entry in the code explorer and that jumps you to the DIM statement for that variable.
Adrian Jansen
TSEYFARTH
PostPosted: Thu Oct 12, 2017 5:58 am    Post subject: Reply with quote
Hi Adrian,
I did not know that! It's sure easier than having to find it first!
Thank you!
Tim
kimmi
Moderator
PostPosted: Thu Oct 12, 2017 1:35 pm    Post subject: Reply with quote
The fastest was to find them is CTRL+W scrool down to bottom
here you see unused vars under "Warnings:"
/ Kim
View user's profile Visit poster's website MSN Messenger
