KenHorse
Posted: Mon Sep 11, 2017 4:31 pm Post subject: Lookup using variable? |
According to the HELP, you can use a variable for the LABEL when using LOOKUP.
"You may also use a variable that holds the address of a label."
Take the following code as an example:
Code: |
Dim TempString As String * 30
Dim TempInt As Integer
Dim Index As Integer
Index =10
TempString = "EEPROM1"
TempInt = LOOKUP(Index , TempString)
Print "TempInt " ; TempInt
EEPROM1:
Data 1% , 2% , 3% , 4% , 5% , 6% , 7% , 8% , 9% , 10% , 11% , 12% , 13% , 14% , 15% , 16% , 17% , 18% , 19% , 20% , 21% , 22% , 23% , 24% |
TempInt returns a -1
Instead of using a string, I tried this instead:
Code: |
Dim TempInt2 As Integer
Index =10
TempInt2 = 3
TempInt = LOOKUP(Index , TempInt2)
1:
And this returns 6144
What am I doing wrong? |
KenHorse
Posted: Mon Sep 11, 2017 4:37 pm Post subject: Re: Lookup using variable? |
KenHorse wrote: | According to the HELP, you can use a variable for the LABEL when using LOOKUP.
Code: |
Index =10
EEPROM1:
Code: |
Index =10
TempInt2 = 1
1:
six1
Posted: Tue Sep 12, 2017 6:51 am Post subject: |
"Address of a Label" can be done with LOADLABEL _________________ For technical reasons, the signature is on the back of this message. |
KenHorse
Posted: Tue Sep 12, 2017 3:43 pm Post subject: |
six1 wrote: | "Address of a Label" can be done with LOADLABEL |
I'm not sure that's what I'm looking for as I'm not using the $EEPROM directive
But since I'm using a Mega2561, even if it is, I guess I can't do this (Help says it only works for <=64K memory AVRs)
Oh well.....
Posted: Tue Sep 12, 2017 3:49 pm Post subject: |
it should work with >64K also.
lookup was enhanced later to support this. _________________ Mark |
KenHorse
Posted: Tue Sep 12, 2017 3:53 pm Post subject: |
albertsm wrote: | it should work with >64K also.
lookup was enhanced later to support this. |
Doesn't seem to work in the simulator:
Code: |
Dim A As Integer
Index = 5
TempInt = LOOKUP(Index , A)
EEPROM1:
A = Loadlabel(EEPROM1) |
This returns -27368 |
Posted: Tue Sep 12, 2017 8:07 pm Post subject: |
doesnt surprise me
why did you put this : A = Loadlabel(EEPROM1) at the bottom?
you should load the value BEFORE you use the variable A. _________________ Mark |
KenHorse
Posted: Tue Sep 12, 2017 8:15 pm Post subject: |
albertsm wrote: | doesnt surprise me
you should load the value BEFORE you use the variable A. |
Point 1 - doesn't matter where I put it, it still doesn't work for me
Point 2 - the HELP says (and shows):
Quote: | Loadlabel will only work for processors with <= 64KB memory.
If you use Loadlabel on an EEPROM label (a label used in the $EEPROM data area) , these labels must precede the Loadlabel function.
This would be ok :
$eeprom ' eeprom image
label1:
data 1,2,3,4,5
label2:
data 6,7,8,9,10
$data ' back to normal mode
dim w as word
w=loadlabel(label2)
This code will work since the loadlabel is used after the EEPROM data labels.
Sorry Mark but this is confusing |
Posted: Tue Sep 12, 2017 9:58 pm Post subject: |
you did not specified the version you use. I use 2080.
so if you use an older version it will not work with >64K.
loadlabel loads the address of a label into a variable.
you could pass this to lookup()
lookup does not work on eeprom data.
you mix up 2 things from the help.
the working code is this :
Code: | Dim TempInt As Integer
Dim A As Integer
Index = 5
EEPROM1:
in the loadlabel help text , there is a remark that when you load the address of a label in EEPROM, you must place the eeprom data before the loadlabel. this because eeprom data is not actual data that ends up in flash but in a file you can use to program the eeprom. _________________ Mark |
KenHorse
Posted: Tue Sep 12, 2017 10:15 pm Post subject: |
albertsm wrote: | you did not specified the version you use. I use 2080.
Dim A As Integer
Index = 5
EEPROM1:
in the loadlabel help text , there is a remark that when you load the address of a label in EEPROM, you must place the eeprom data before the loadlabel. this because eeprom data is not actual data that ends up in flash but in a file you can use to program the eeprom. |
Sorry, using 2.0.7.9 (don't see a license file for 2.0.8.0) |
Posted: Tue Sep 12, 2017 10:18 pm Post subject: |
my working code will also work for 2079, just not when data is located in pages other than the first.
there is no lic file for 2080, only a full setup. _________________ Mark |
KenHorse
Posted: Tue Sep 12, 2017 10:23 pm Post subject: |
albertsm wrote: | my working code will also work for 2079, just not when data is located in pages other than the first.
there is no lic file for 2080, only a full setup. |
Got it, thanks |
