balou
Posted: Sun Sep 10, 2017 5:47 pm Post subject: Attiny4313 PWM problem |
Sometimes the PWM signal is free running.
Measure port B.3 OC0A.
Bascom 2.0.8.0
What is wrong ?
Balou.
$regfile = "attiny4313.Dat"
$hwstack = 20
$swstack = 20
$framesize = 20
$baud = 9600
Config Pind.2 = Input '** IR **
Config Timer0 = Timer , Prescale = 256 '** 8000000/256=31250 Hz
Config Int0 = Falling '** Interruption on Falling
Stop Timer0
Enable Timer0
Enable Timer1
Enable Int0
On Timer0 Tikers '** work on timer
On Int0 Infrared '** work on interruption
'******************* PWM Timer1 *****************
Config Timer1 = Pwm , Prescale = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up
'********* OC1A = B.3 / OC1B = B.4 **************
Dim Tik As Word 'counter of teaks of timer
Dim Byt As Byte 'counter accepted bit
Dim Repeat_flag As Bit 'flag of repetition
Dim Start_flag As Bit 'flag of start condition
Dim Address As Byte 'byte of address
Dim Command As Byte 'byte of command
Dim Address_1 As Byte 'direct byte of address
Dim Command_1 As Byte 'direct byte of command
Dim Address_0 As Byte 'indirect byte of address
Dim Command_0 As Byte 'indirect byte of command
'Dim Summa As Word
'**************************** Main program ***********************************************
Pwm1a = 0
Pwm1b = 0
Do 'Main cycle
Select Case Command
Case 90 : Pwm1a = Pwm1a + 10 '** Up B.3 **
Waitms 15
Case 16 : Pwm1a = Pwm1a - 10 '** Low B.3 **
Waitms 15
Case 152 '** Off "0" B.3/B.4 **
Pwm1a = 0
Pwm1b = 0
Waitms 10
Waitms 40
End 'End of main cycle
'############################# Timer0 ###########################################
Tikers: '** work on timer
Timer0 = 253 '** 31250/(256-253)=10416,66 Hz (96 een)
Incr Tik
If Tik >= 1200 Then '** if 1200 teaks, have thrown all in source condition
Tik = 0
Repeat_flag = 0
Start_flag = 0
Address_1 = 0
Command_1 = 0
Address_0 = 0
Command_0 = 0
Address = 0
Command = 0
Stop Timer0
'############################## Timer 0 ############################################
Infrared: '** work on interruption
Start Timer0
If Tik >= 139 And Tik < 150 Then '** if has happenned from 139 before 150 teaks - "START"
Address = 1
Repeat_flag = 0
Start_flag = 1
Address_1 = 0
Command_1 = 0
Address_0 = 0
Command_0 = 0
If Tik >= 116 And Tik < 139 Then '** if has happenned from 116 before 138 teaks - "REPETITION"
Address = 2
Repeat_flag = 1
Start_flag = 0
If Tik >= 22 And Tik < 116 And Start_flag = 1 Then '** if has happenned from 22 before 115 teaks - have taken "1"
Incr Byt
If Byt < 9 Then
Shift Address_1 , Left
Address_1 = Address_1 + 1
If Byt >= 9 And Byt < 17 Then
Shift Address_0 , Left
Address_0 = Address_0 + 1
If Byt >= 17 And Byt < 25 Then
Shift Command_1 , Left
Command_1 = Command_1 + 1
If Byt >= 25 Then
Shift Command_0 , Left
Command_0 = Command_0 + 1
If Tik >= 10 And Tik < 22 And Start_flag = 1 Then '** if has happenned from 10 before 21 teaks - have taken "0"
Incr Byt
If Byt < 9 Then
If Byt >= 25 Then
Tik = 0
If Byt = 32 Then '** if have taken 4 bytes, check correctness a receiving a command
'if address or command 16-bit, check does not pass
'Summa = Address_0 + Address_1
'If Summa = 255 Then
Address = Address_1
'Else
'Address = 0
'End If
'Summa = Command_0 + Command_1
Command = Command_1
'Else
'Command = 0
'End If
Byt = 0
Repeat_flag = 0
Start_flag = 0
Stop Timer0
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.7.8 ) |
Posted: Sun Sep 10, 2017 8:00 pm Post subject: Re: Attiny4313 PWM problem |
balou wrote: | Sometimes the PWM signal is free running. |
Define "free running".
Some potential problems: no test for under-/overrun of pwm1a, command is not cleared immediately after execution. |
balou
Posted: Sun Sep 10, 2017 8:33 pm Post subject: |
Free running, pwm1a change from 0 to 255. |
