Precompiler directives?
Sebastian.Heyn
PostPosted: Fri Mar 16, 2018 8:47 am    Post subject: Precompiler directives? Reply with quote
does bascom have an option - so that I can tell the compiler to output debug information in the code or not?
For example: Right now, I use a software UART for debug output
? #1 , "Some debug text"
However in the final version, I dont need that and my usual way is to go through the code and uncomment everything.
Sometimes I put a
if debug_out=1
but this is also taking up some cpu time. is there a possibility to disable these commands with a compiler option somehow?
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.8.1 )
PostPosted: Fri Mar 16, 2018 10:05 am    Post subject: Reply with quote
in the help you find the DEBUG statement which is similar to PRINT. It can be turned on'/off
A good way is using conditional compilation :
const cWantDebug=1  ' create some constant
#IF cWantDebug   'notice there is NO THEN for #
#ELSEIF  cWantDebug=2  '  optional
#ELSE  'also optional
#ENDIF  'notice no space between end and if
The IDE can also show which code is included and which not (edit show excluded code)
