Send String over USB instead Byte
katipefendi
PostPosted: Sun Mar 11, 2018 3:16 am    Post subject: Send String over USB instead Byte Reply with quote
Hallo,
it is possible send string over usb instead Byte with usb.inc file?
Sub Hid_task()
 If Usb_connected = 1 Then ' Check USB HID is enumerated
 Usb_select_endpoint Ep_hid_out ' Get Data Repport From Host
 If Ueintx.rxouti = 1 Then ' Is_usb_receive_out())
 Dummy1 = Uedatx : Print "Got : " ; Dummy1
 Dummy2 = Uedatx : Print "Got : " ; Dummy2
 Dummy = Uedatx : Print "Got : " ; Dummy
 Usb_ack_receive_out
 If Dummy1 = &H55 And Dummy2 = &HAA Then ' Check if we received DFU mode command from host
 Usb_detach ' Detach Actual Generic Hid Application
 Waitms 500
 Goto &H1800 'goto bootloader
 'here you could call the bootloader then
 Usb_select_endpoint Ep_hid_in ' Ready to send these information to the host application
 If Ueintx.txini = 1 Then ' Is_usb_in_ready())
 Uedatx = 1
 Uedatx = 2
 Uedatx = 3
 Uedatx = "Here i want send Text"                           '<-- for example!!! is it possible??
 Uedatx = 5
 Uedatx = 6
 Uedatx = 7
 Uedatx = 8
 Usb_ack_fifocon ' Send data over the USB
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.1 )
PostPosted: Mon Mar 12, 2018 10:11 am    Post subject: Reply with quote
you can send strings since these are just bytes terminated with a zero byte.
for example :
total_length=len(somestring) + 1
for j=1 to total_length
  Uedatx = asc(somestring, J)  'get byte from string and send it
next
you should however take in mind the length of the end point. in the sample it is 8. so to keep it working the string length is limited to 7.
the next step would be to send multiple packets. and/or to use bigger end points.
katipefendi
PostPosted: Sat Mar 17, 2018 1:51 am    Post subject: Solved Reply with quote
Hallo,
i have solved with this method, it works very well.
         Uedatx = Ausgang1
         Uedatx = Ausgang2
         Uedatx = Ausgang3
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = Deviceadresse
         Uedatx = Devicetype
         Uedatx = 0
         Uedatx = Timeout
         Uedatx = 3
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 20
         Uedatx = 18
         Uedatx = 03
         Uedatx = 17
         Uedatx = 01
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
         Uedatx = 0
BR
Sinan
