3.12" 256x64 OLED with SSD1322 Controller SPI Mode
O-Family
PostPosted: Tue Jun 18, 2024 2:14 pm    Post subject: 3.12" 256x64 OLED with SSD1322 Controller SPI Mode Reply with quote
Library and test code for 3.12" 256x64 OLED using SSD1322 controller SPI mode.
16 grayscales are available, allowing for character-by-character brightness adjustment and black-and-white pictures.
There are four types of OLED display colors: white, yellow, green, and blue.
SPI can be selected from 3-wire and 4-wire. The drawing speed will be slightly slower with 3-wire.
The connector position relative to the display screen can be selected on either the left or right.
In SPI mode, the G-RAM in the controller is write-only, so graphic commands such as LINE commands cannot be used.
In parallel mode, reading and writing are possible, so we plan to create a library that can use graphic commands.
Module size
https://drive.google.com/file/d/1a6RrUDQEoZceiI_GM7utmMFMd49oglFg/view?usp=drive_link
Test Circuit Diagram
https://drive.google.com/file/d/1B8tez6ug7UETKyszuatrrB79hResgz7_/view?usp=drive_link
   '  * 3.12inch 256x64 OLED test           *
   '  *     [SSD1322] 3-wire or 4-wire SPI  *
   '  *          O-Family  2024. 6.17       *
$regfile = "m328pdef.dat"
$hwstack = 64
$swstack = 10
$framesize = 24
   '  * OLED Initial Settings *
   Const Rotate_180 = 0                                     'OLED screen installation direction (180degree rotation).
                                                            ' (Connector: 0 = Right side, 1 = Left side)
   Const Spi_wire_selection = 4                             'Select the number of lines for SPI connection.
                                                            ' (3 = 3-wire: drawing spd low, 4 = 4-wire: drawing spd high)
$lib "glcdSSD1322-SPI.lib"                                  'Embedded SSD1322 3.12inch 256x64 SPI library.
   ' Specifies the connection port for OLED. Cs1 = [/CS] , Rst = [/RES] , A0 = [D/C] , Si = [SDIN] , Sclk = [SCLK]
   Config Graphlcd = Color , Cs1 = Portc.0 , Rst = Portc.1 , A0 = Portc.2 , Si = Portc.3 , Sclk = Portc.4       '[Cs1]&[Rst] optional.
   ' Character drawing commands : [Lcdat Y , X , Character , FG , BG]
   '   Y = Y(row) address (0 - 63) , X = X(column) address (0 - 255) , Character = String or variable to display
   '   FG = Foreground Grayscale Value (0 - 15) , BG = Background Grayscale Value (0 - 15) / (0:dark - 15:bright)
   '   Note: Since the SSD1322 writes 4-bit grayscale data in word units, set the X address in 4-dot intervals. (ex. 0,4,8 - 248,252)
   ' Command to draw BGC image data in RLE compressed format : [Showpic X , Y , label]
   '   X = X(column) address (0 - 255), Y = Y (row)address (0 - 63), label = label of image data to display.
   '     See the help for SHOWPIC command.
   '   To create RLE compressed BGC image data from BMP images, use the LCD RGB-8 converter [LCDconvert.exe].
   ' Below is a table that maps 8-bit BGC format RGB8 code (RRRG_GGBB) to a 4-bit grayscale brightness value (0 - 15).
   Const _bgc_r2 = &B0000_1000                              'BGC RGB8 code [Red2]
   Const _bgc_r1 = &B0000_0000                              'BGC RGB8 code [Red1]
   Const _bgc_r0 = &B0000_0000                              'BGC RGB8 code [Red0]
   Const _bgc_g2 = &B0000_0100                              'BGC RGB8 code [Green2]
   Const _bgc_g1 = &B0000_0000                              'BGC RGB8 code [Green1]
   Const _bgc_g0 = &B0000_0000                              'BGC RGB8 code [Green0]
   Const _bgc_b1 = &B0000_0010                              'BGC RGB8 code [Blue1]
   Const _bgc_b0 = &B0000_0000                              'BGC RGB8 code [Blue0]
   ' By default, the intermediate luminance value for each of the colors R,G,B is the lower 4bits(0-15) of the grayscale luminance value.
   ' Adjust the grayscale to match the color scheme of the original image.
   '  * Drawing Tests *
      Setfont Color8x8
      Lcdat 0 , 0 , "SSD1322 SPI 3.12in OLED 256x64" , 15 , 0
      Setfont Color16x16
      Lcdat 10 , 4 , "ABC" , 13 , 4
      Lcdat 10 , 56 , "0123" , 4 , 10
      Setfont Color_offont8x8
      Lcdat 30 , 0 , "ORIGINAL Font 8x8" , 15 , 4
      Setfont Color_offont16x16
      Lcdat 44 , 0 , "16x16" , 0 , 15
      Setfont Color_offont40x32
      Lcdat 18 , 140 , "40" , 4 , 12
      Showpic 212 , 10 , Plaatje                            'Draw BGC files.
      Wait 3
      Glcdcmd &HC1 : Glcddata 64                            'Contrast setting. (0-255)
      Wait 3
      Glcdcmd &HAE                                          'Sleep mode ON. (Display OFF)
      Wait 2
      Glcdcmd &HAF                                          'Sleep mode OFF. (Display ON)
      Wait 3
      Glcdcmd &HC1 : Glcddata 128                           'Contrast setting. (0-255)
      Glcdcmd &HA7                                          'Inverted display.
      Wait 3
      Glcdcmd &HA6                                          'Normal display.
      Wait 3
      Cls                                                   'Clear all screens.
      Glcdcmd &HC1 : Glcddata 255                           'Contrast setting. (0-255)
      Wait 2
   '  * Font data *
$include "color8x8.font"
$include "Color16x16.font"
$include "Color_OFfont8x8.font"
$include "Color_OFfont16x16.font"
$include "Color_OFfont40x32.font"
   '  * Image data *
Plaatje:
$bgf "FL001-2.BGC"                                          'Incorporate BGC files. (Carnation)
PostPosted: Tue Jun 18, 2024 2:51 pm    Post subject: Reply with quote
Hello O-Family,
Thanks for sharing. You are the man!
Wonderful work on this LCD.
As usual your contribution is complete : source, lib,description and circuit connection info.
O-Family
PostPosted: Wed Jun 26, 2024 2:46 am    Post subject: Reply with quote
Next is a library and test code using the 8-bit parallel mode of the SSD1322 controller.
Graphics instructions such as LINE, BOX, and CIRCLE can also be used.
Although the number of wires increases, the advantage is the variation of screen configurations and the increase in drawing speed!
   '  *     [SSD1322] 8-bit Parallel        *
   '  *          O-Family  2024. 6.25       *
$hwstack = 64
$swstack = 10
$framesize = 24
$lib "glcdSSD1322-Para.lib"                                 'Embedded SSD1322 3.12inch 256x64 8-bit Parallel library.
   ' Specifies the connection port for OLED. Cs1 = [/CS] , Rst = [/RES] , A0 = [D/C] , Wr = [/WR] , Rd = [/RD] ,  Dataport = [D0-D7]
   Config Graphlcd = Color , Cs1 = Portc.0 , Rst = Portc.1 , A0 = Portc.2 , Wr = Portc.3 , Rd = Portc.4 , Dataport = Portd       '[Cs1]&[Rst] optional.
   '         Graphics drawing instructions(LINE, BOX, etc.) can be specified at any address on the screen.
   '  * Drawing Tests *
   Dim Temp1 As Byte , Temp2 As Byte
      Setfont Color8x8
      Lcdat 6 , 8 , "SSD1322 Para 3.12{034} OLED 256x64" , 8 , 4
      Line(0 , 0) -(255 , 0) , 8                            'Drawing the outer frame.
      Line(0 , 63) -(255 , 63) , 8
      Line(0 , 2) -(0 , 61) , 2
      Line(255 , 2) -(255 , 61) , 2
      Box(2 , 2) -(253 , 61) , 5
      Temp2 = 15                                            'Test of LINE instruction.
      For Temp1 = 0 To 44 Step 3
         Line(8 , 58) -(56 , 58 -temp1) , Temp2
         Temp2 = Temp2 - 1
      Next Temp1
      Circle(90 , 38) , 19 , 15                             'Test of CIRCLE instruction.
      Circle(90 , 38) , 10 , 3
      Line(67 , 38) -(113 , 38) , 10
      Pset 90 , 23 , 15
      Pset 90 , 38 , 0
      Boxfill(128 , 18) -(168 , 58) , 3                     'Test of BOX instructions.
      Boxfill(142 , 32) -(154 , 44) , 6
      Box(134 , 24) -(162 , 52) , 15
      Showpic 184 , 17 , Plaatje                            'Draw BGC files.
      Wait 3
      Wait 3
      Wait 2
      Wait 3
      Wait 3
      Wait 3
      Wait 2
   '  * Font data *
   '  * Image data *
Plaatje:
   $bgf "mcse3.BGC"                                         'Incorporate BGC files. (MCS)
PostPosted: Sat Jun 29, 2024 3:31 pm    Post subject: Reply with quote
thanks O-Family for this great extension. These are also great learning projects for others that like to create a driver.
