Bascom Spi Newbie Problem
Goto page 1, 2  Next
MichaelB.
PostPosted: Wed Jul 12, 2017 11:10 am    Post subject: Bascom Spi Newbie Problem Reply with quote
Hi again, for a newbie Problem, and need a Specialist for SPI.
This time i try me on the SPI comunication between a Atmega32 and a SCA100T-D02 Anglesensor.
I make some Comments in the Code for you that will may help.
First, i had Create and send a 8 bit register code to the Anglesensor, to say that i will only read the 11 bit " Y " Values from the Sensor.
After that, i send two 8 bit packages to Shift it in the sensor, and the Sensor answers on the MISO line with the Y values.
I checked that with my "PeakTech 1350" Pen-Type Oscilloscpoe.
The "Y" Values on the MISO line is changing as Expected when tilt the Sensor.
BUT. Nothing more happens. My expectaion is that the MISO data "LoadY" is convert it into "Wert1"
The Zero Angle Position is "10000000000" witch is 1024, and in my Code it shall show me on my 7Segments a " 0 " on my Breadbord.
But it shows nothing, what do i miss here. Can anyone Help me in this case?
Best Regards
Michael
PostPosted: Wed Jul 12, 2017 6:36 pm    Post subject: Reply with quote
First: you can not be serious to post code as bitmap.
In case the uC is the master, SPI communication depends on shifting bits out via MOSI, master out slave in, and getting bits in via MISO, master in slave out.
The visible bitmap-part of your code uses nowhere commands to get data like SPIIN, SPIMOVE, there's only SPIOUT, you only talk but you do not listen.
Do you expect the requested bits are somehow magically transferred into the uC?
You have to cut down the controllers case at least one mm to make that magic work, i.e. let it out LOL
PostPosted: Wed Jul 12, 2017 9:20 pm    Post subject: Reply with quote
Michael, some pictures say more than 1000 words but in order to give help, you should post code, and please embed them with the CODE tags.
This way we can copy and past the code and check it.
Also, when using some chip, give a link to the data sheet PDF so we do not need to search for the data sheet.
MichaelB.
PostPosted: Thu Jul 13, 2017 12:42 pm    Post subject: Reply with quote
Oh sure. Here is the PDF and the Code.
http://www.produktinfo.conrad.com/datenblaetter/400000-424999/406067-da-01-en-NEIGUNGSSENSOR_SCA100T_D02.pdf
$regfile = "m32def.dat"
$crystal = 16000000
$framesize = 256
$swstack = 256
$hwstack = 256
Config Porta.0 = Output
Config Porta.1 = Output
Config Porta.2 = Output
Config Porta.3 = Output
Config Porta.4 = Output
Config Porta.5 = Output
Config Porta.6 = Output
Config Porta.7 = Output
Config Portb.0 = Output                                     'LED
Config Portb.1 = Output
Config Portb.2 = Output
Config Portb.3 = Output
Config Portc.0 = Output                                     'LED
Config Portc.1 = Output
Config Portc.6 = Output
Config Portc.7 = Output
Config Portd.4 = Output                                     'LED
Config Portd.5 = Output
  'Links
LEDLa alias PortB.0                                         ' 1er
LEDLb alias portB.1
LEDLc alias PortB.2
LEDLd alias PortB.3
LEDLe alias Porta.0
LEDLf alias Porta.1
LEDLg alias Porta.2
LEDL2b alias Porta.6                                        '10er
LEDL2c alias Porta.7
'Rechts
LEDRa alias Portc.0
LEDRb alias Portc.1                                         '1er
LEDRc alias Porta.3
LEDRd alias Portc.6
LEDRe alias Portc.7
LEDRf alias Porta.4
LEDRg alias Porta.5
LEDR2b alias Portd.5                                        '10er
LEDR2c alias Portd.4
Config Portb.4 = Output                                     'Chipselect
Portb.4 = 1                                                 'Chipselect = off
Dim LoadY as Word                                           '11 bit Slave Value Output (MISO)
Dim LoadYL as Byte at LoadY Overlay
Dim LoadYH as Byte at LoadY + 1 Overlay
Dim WertY as Byte
WertY = &B00010001                                          ' Y slave Register code
Dim Wert1 as Word
Config SPI = Hard , Interrupt = off , Master = Yes , Data_order = Msb , Polarity = Low , Phase = 0 , Clockrate = 128 , Noss = 1       ' mega32 with 16mhz
Spiinit
Cls
      Portb.4 = 0                                           'chip select on
      Spiout WertY , 1                                      ' Send "Y" Register code
      Spiout LoadYH , 1                                     'Send first 8 Bit of a 16 bit Word
      Spiout LoadYL , 1                                     ' Send second 8 Bit of a 16 bit Word
      Portb.4 = 1                                           'chip select off
      Wert1 = LoadY
        ' Right
        If Wert1 = 1009 then                                ' 15
                 LEDRa = 1
                 LEDRf = 1
                 LEDRg = 1
                 LEDRc = 1
                 LEDRd = 1
                 LEDR2b = 1
                 LEDR2c = 1
                 waitms 5000
                 LEDRa = 0
                 LEDRf = 0
                 LEDRg = 0
                 LEDRc = 0
                 LEDRd = 0
                 LEDR2b = 0
                 LEDR2c = 0
        End if
        If Wert1 = 1010 then                                ' 14
                 LEDRf = 1
                 LEDRg = 1
                 LEDRb = 1
                 LEDRc = 1
                 LEDR2b = 1
                 LEDR2c = 1
               waitms 5000
                 LEDRf = 0
                 LEDRg = 0
                 LEDRb = 0
                 LEDRc = 0
                 LEDR2b = 0
                 LEDR2c = 0
        End if
        If Wert1 = 1011 then                                ' 13
                 LEDRa = 1
                 LEDRb = 1
                 LEDRg = 1
                 LEDRc = 1
                 LEDRd = 1
                 LEDR2b = 1
                 LEDR2c = 1
                waitms 5000
                 LEDRa = 0
                 LEDRb = 0
                 LEDRg = 0
                 LEDRc = 0
                 LEDRd = 0
                 LEDR2b = 0
                 LEDR2c = 0
        End if
        If Wert1 = 1012 then                                ' 12
                 LEDRa = 1
                 LEDRb = 1
                 LEDRg = 1
                 LEDRe = 1
                 LEDRd = 1
                 LEDR2b = 1
                 LEDR2c = 1
                  waitms 5000
                 LEDRa = 0
                 LEDRb = 0
                 LEDRg = 0
                 LEDRe = 0
                 LEDRd = 0
                 LEDR2b = 0
                 LEDR2c = 0
        End if
        If Wert1 = 1013 then                                ' 11
                 LEDRb = 1
                 LEDRc = 1
                 LEDR2b = 1
                 LEDR2c = 1
                 waitms 5000
                 LEDRb = 0
                 LEDRc = 0
                 LEDR2b = 0
                 LEDR2c = 0
        End if
        If Wert1 = 1014 then                                ' 10
                 LEDRa = 1
                 LEDRb = 1
                 LEDRc = 1
                 LEDRd = 1
                 LEDRe = 1
                 LEDRf = 1
                 LEDR2b = 1
                 LEDR2c = 1
                 waitms 5000
                 LEDRa = 0
                 LEDRb = 0
                 LEDRc = 0
                 LEDRd = 0
                 LEDRe = 0
                 LEDRf = 0
                 LEDR2b = 0
                 LEDR2c = 0
        End if
        If Wert1 = 1015 then                                ' 9
                 LEDRa = 1
                 LEDRb = 1
                 LEDRc = 1
                 LEDRd = 1
                 LEDRg = 1
                 LEDRf = 1
                 waitms 5000
                 LEDRa = 0
                 LEDRb = 0
                 LEDRc = 0
                 LEDRd = 0
                 LEDRg = 0
                 LEDRf = 0
        End if
        If Wert1 = 1016 then                                ' 8
                 LEDRa = 1
                 LEDRb = 1
                 LEDRc = 1
                 LEDRd = 1
                 LEDRe = 1
                 LEDRf = 1
                 LEDRg = 1
                 waitms 5000
                 LEDRa = 0
                 LEDRb = 0
                 LEDRc = 0
                 LEDRd = 0
                 LEDRe = 0
                 LEDRf = 0
                 LEDRg = 0
        End if
        If Wert1 = 1017 then                                ' 7
                 LEDRa = 1
                 LEDRb = 1
                 LEDRc = 1
                 waitms 5000
                 LEDRa = 0
                 LEDRb = 0
                 LEDRc = 0
        End if
        If Wert1 = 1018 then                                ' 6
                 LEDRa = 1
                 LEDRf = 1
                 LEDRg = 1
                 LEDRe = 1
                 LEDRd = 1
                 LEDRc = 1
                 waitms 5000
                 LEDRa = 0
                 LEDRf = 0
                 LEDRg = 0
                 LEDRe = 0
                 LEDRd = 0
                 LEDRc = 0
        End if
        If Wert1 = 1019 then                                ' 5
                 LEDRa = 1
                 LEDRf = 1
                 LEDRg = 1
                 LEDRc = 1
                 LEDRd = 1
                 waitms 5000
                 LEDRa = 0
                 LEDRf = 0
                 LEDRg = 0
                 LEDRc = 0
                 LEDRd = 0
        End if
        If Wert1 = 1020 then                                ' 4
                 LEDRf = 1
                 LEDRg = 1
                 LEDRb = 1
                 LEDRc = 1
                 waitms 5000
                 LEDRf = 0
                 LEDRg = 0
                 LEDRb = 0
                 LEDRc = 0
        End if
        If Wert1 = 1021 then                                ' 3
                LEDRa = 1
                LEDRb = 1
                LEDRg = 1
                LEDRc = 1
                LEDRd = 1
                waitms 5000
                LEDRa = 0
                LEDRb = 0
                LEDRg = 0
                LEDRc = 0
                LEDRd = 0
        End if
        If Wert1 = 1022 then                                ' 2
               LEDRb = 1
               LEDRa = 1
               LEDRg = 1
               LEDRe = 1
               LEDRd = 1
               waitms 5000
               LEDRb = 0
               LEDRa = 0
               LEDRg = 0
               LEDRe = 0
               LEDRd = 0
        End if
        If Wert1 = 1023 then                                ' 1
              LEDRb = 1
              LEDRc = 1
              waitms 5000
              LEDRb = 0
              LEDRc = 0
        End if
        If Wert1 = 1024 then                                ' 0
              LEDRa = 1
              LEDRb = 1
              LEDRc = 1
              LEDRd = 1
              LEDRe = 1
              LEDRf = 1
              LEDLa = 1
              LEDLb = 1
              LEDLc = 1
              LEDLd = 1
              LEDLe = 1
              LEDLf = 1
              waitms 5000
              LEDRa = 0
              LEDRb = 0
              LEDRc = 0
              LEDRd = 0
              LEDRe = 0
              LEDRf = 0
              LEDLa = 0
              LEDLb = 0
              LEDLc = 0
              LEDLd = 0
              LEDLe = 0
              LEDLf = 0
        End if
        'Left
       If Wert1 = 1025 then                                 '1
             LEDLb = 1
             LEDLc = 1
             waitms 5000
             LEDLb = 0
             LEDLc = 0
       End if
       If Wert1 = 1026 then                                 '2
             LEDLb = 1
             LEDLg = 1
             LEDLa = 1
             LEDLe = 1
             LEDLd = 1
             waitms 5000
             LEDLb = 0
             LEDLg = 0
             LEDLa = 0
             LEDLe = 0
             LEDLd = 0
       If Wert1 = 1027 then                                 '3
             LEDLa = 1
             LEDLb = 1
             LEDLg = 1
             LEDLc = 1
             LEDLd = 1
             waitms 5000
             LEDLa = 0
             LEDLb = 0
             LEDLg = 0
             LEDLc = 0
             LEDLd = 0
       If Wert1 = 1028 then                                 '4
             LEDLf = 1
             LEDLg = 1
             LEDLb = 1
             LEDLc = 1
             waitms 5000
             LEDLf = 0
             LEDLg = 0
             LEDLb = 0
             LEDLc = 0
       End if
       If Wert1 = 1029 then                                 '5
             LEDLa = 1
             LEDLf = 1
             LEDLg = 1
             LEDLc = 1
             LEDLd = 1
             waitms 5000
             LEDLa = 0
             LEDLf = 0
             LEDLg = 0
             LEDLc = 0
             LEDLd = 0
       End if
       If Wert1 = 1030 then                                 '6
             LEDLa = 1
             LEDLf = 1
             LEDLg = 1
             LEDLc = 1
             LEDLd = 1
             waitms 5000
             LEDLa = 0
             LEDLf = 0
             LEDLg = 0
             LEDLc = 0
             LEDLd = 0
       End if
       If Wert1 = 1031 then                                 '7
              LEDLa = 1
              LEDLb = 1
              LEDLc = 1
              waitms 5000
              LEDLa = 0
              LEDLb = 0
              LEDLc = 0
       End if
       If Wert1 = 1032 then                                 '8
              LEDLa = 1
              LEDLb = 1
              LEDLc = 1
              LEDLd = 1
              LEDLe = 1
              LEDLf = 1
              LEDLg = 1
              waitms 5000
              LEDLa = 0
              LEDLb = 0
              LEDLc = 0
              LEDLd = 0
              LEDLe = 0
              LEDLf = 0
              LEDLg = 0
       End if
       If Wert1 = 1033 then                                 '9
              LEDLa = 1
              LEDLb = 1
              LEDLc = 1
              LEDLd = 1
              LEDLf = 1
              LEDLg = 1
              waitms 5000
              LEDLa = 0
              LEDLb = 0
              LEDLc = 0
              LEDLd = 0
              LEDLf = 0
              LEDLg = 0
       End if
       If Wert1 = 1034 then                                 '10
              LEDLa = 1
              LEDLb = 1
              LEDLc = 1
              LEDLe = 1
              LEDLf = 1
              LEDLd = 1
              LEDL2b = 1
              LEDL2c = 1
              waitms 5000
              LEDLa = 0
              LEDLb = 0
              LEDLc = 0
              LEDLe = 0
              LEDLf = 0
              LEDLd = 0
              LEDL2b = 0
              LEDL2c = 0
       End if
       If Wert1 = 1035 then                                 '11
              LEDLb = 1
              LEDLc = 1
              LEDL2b = 1
              LEDL2c = 1
              waitms 5000
              LEDLb = 0
              LEDLc = 0
              LEDL2b = 0
              LEDL2c = 0
       End if
       If Wert1 = 1036 then                                 '12
               LEDLa = 1
               LEDLb = 1
               LEDLg = 1
               LEDLe = 1
               LEDLd = 1
               LEDL2b = 1
               LEDL2c = 1
               waitms 5000
               LEDLa = 0
               LEDLb = 0
               LEDLg = 0
               LEDLe = 0
               LEDLd = 0
               LEDL2b = 0
               LEDL2c = 0
       End if
       If Wert1 = 1037 then                                 '13
               LEDLa = 1
               LEDLb = 1
               LEDLc = 1
               LEDLd = 1
               LEDLg = 1
               LEDL2b = 1
               LEDL2c = 1
               waitms 5000
               LEDLa = 0
               LEDLb = 0
               LEDLc = 0
               LEDLd = 0
               LEDLg = 0
               LEDL2b = 0
               LEDL2c = 0
       End if
       If Wert1 = 1038 then                                 '14
               LEDLf = 1
               LEDLg = 1
               LEDLb = 1
               LEDLc = 1
               LEDL2b = 1
               LEDL2c = 1
               waitms 5000
               LEDLf = 0
               LEDLg = 0
               LEDLb = 0
               LEDLc = 0
               LEDL2b = 0
               LEDL2c = 0
       End if
       If Wert1 = 1039 then                                 '15
               LEDLa = 1
               LEDLf = 1
               LEDLg = 1
               LEDLc = 1
               LEDLd = 1
               LEDL2b = 1
               LEDL2c = 1
               waitms 5000
               LEDLa = 0
               LEDLf = 0
               LEDLg = 0
               LEDLc = 0
               LEDLd = 0
               LEDL2b = 0
               LEDL2c = 0
       End if
kimmi
Moderator
PostPosted: Thu Jul 13, 2017 4:05 pm    Post subject: Reply with quote
why do you have "Cls" in your code its for lcd !!!!
and how did you connect 7 segment the :
is not clear to me what it do
/ Kim
View user's profile Visit poster's website MSN Messenger
MichaelB.
PostPosted: Thu Jul 13, 2017 5:39 pm    Post subject: Reply with quote
Maybe my mess will help you ^^
PostPosted: Thu Jul 13, 2017 6:48 pm    Post subject: Reply with quote
Hmm, what you're discussing about?
Led-pins?
Why?
It may be funny to discuss such things, but this does not solve anything. Makes no sense.
I wrote it already: if one wants to get data, one needs to fetch them, in this case from MOSI.
And this has to be done by clocking 11 bits in, the schema on page 12 shows exactly how to do it.
As it is described there, 11 bits need to be clocked in.
It is not clear what happens, if 16 bits are clocked in, in case the chip locks up while trying to clock 16 bit, then reading data can not be done with hardware SPI, which works on multiples of its register width of 8 bits.
Then it needs to be done with some simple code, however watching the TO's uninspired code-snake, I'm not sure if he can handle it.
But in case he's lucky, it won't matter whether clocking 11 or 16 bits in, clocking 2 bytes in by SPIIN() will be enough then, the 5 bits with invalid data can be removed either by shifting or masking.
PostPosted: Thu Jul 13, 2017 8:09 pm    Post subject: Reply with quote
TS mentioned he is a newbie with bascom so it will be good to show how to do it better.
But you are right : the LED stuff complicates and distracts from the actual problem.
When having a problem it is good practice to isolate it. this means : create a short as possible sample that still works (or should work). This is also true for the hardware.
For debugging you can use a 7-segment display but i would recommend to use the UART/serial port. that way you can simply use : PRINT "somevalue " ; wert
The help shows how to connect the TX pin to a max232 for connection to the PC.
spimove() might indeed work but a simple loop where you create the signals can do the job too. try to get a proper debug output first. then try hw SPI and if that does not work you can try the 'make your own signals' solution.
kimmi
Moderator
PostPosted: Thu Jul 13, 2017 11:55 pm    Post subject: Reply with quote
Led-pins?
Why?
I know you did not see why I ask
but the long setup of the 7 segment's
can be made more simple with a lookup table
when it's so simple why don't you just tell him that : Loadyh & Loadyl must be Spiin
   Spiin Loadyh , 1                                         'Get first 3 Bit of a 11 bit Word
   Spiin Loadyl , 1                                         ' Get second 8 Bit of a 11 bit Word
We can all make a simple write error but never see it (blind from 1000 times code read)
@Addon file for a simpler 7 segment
/ Kim
MichaelB.
PostPosted: Fri Jul 14, 2017 7:31 am    Post subject: Reply with quote
I tryed also this version:
Portb.4 = 0
Spiout WertY , 1
Spiout LoadYH , 1
Spiout LoadYL , 1
Spiin LoadYH ,1
Spiin LoadYL , 1
Portb.4 = 1
This make more sense to me, but sill nothing on the Led┤s. I tryed to Fuse the Spiin bytes together and Shifted 5 bits to the Right, i make it complicate as hell, and confused me more.
In my Code without Spiin, i thought it must work because its a shift register. That data that comes out of the Master MOSI Line, comes automaticly in the Master MISO Line, and i thought Spiin is only for the Slave Devices.
Next Week i can try it only with Spiin.
And sorry about the Confusing Breadboard Picture.
PostPosted: Fri Jul 14, 2017 10:10 am    Post subject: Reply with quote
I simply did not bother to think about, as the main problem is so obvious, that it needs to fixed first, before making any cosmetic changes.
The code for the display is a mess, agreed, but has the potential to work. But that does not matter, if no data coming in, which is the primary goal.
After the main issue is fixed, you'll have a point and I will agree, that this messy display-routine urgently needs a fix.
benoit
PostPosted: Fri Jul 14, 2017 12:31 pm    Post subject: Reply with quote
HI
Just:
THE STATUT FOR PORT B5 AND PORT B6 ARE NOT DEFINED AS INPUT OR OUTPUT .
I don t know if it can change something.
thank you to tell
Very Happy
PostPosted: Fri Jul 14, 2017 1:02 pm    Post subject: Reply with quote
No, there's no magic reading of MISO.
The controller is configured as SPI-master, your sensor is the slave.
If you check page 12 of the datasheet, you'll notice 8 bits, the command (watch SCK, 8-times going from low to high) is clocked out and after eleven bits are clocked in, so you can try to SPIOUT command-byte and after SPIIN result-word.
But, and I mentioned that in my post before, it may confuse the sensor, as it expects 11 clocks to shift out its data, while actually the SCK-pin is driven with 16 clocks from the ÁC.
Watching the page 12 diagram, CSB (the enable-pin of the sensor) goes low first, then the command byte is clocked to the sensor, after the result is clocked from the sensor, the MOSI-line is crisscrossed meanwhile, as the MOSI level is ignored, while getting the result via MISO.
On the panoramic view of the electronic one can barely notice 4 wires running to the sensor, that have to be: plus, ground, MOSI, MISO.
The fifth wire for CSB is not visible, so it can be assumed, that CSB is not connected or constantly held low, means the sensor is always addressed.
It may happen then, that the superfluous 5 clocks irritate the sensor and are taken as part of a next command-byte, this way screwing all further reads, even if the first one actually gave a good result. Then you need some sort of custom soft-SPI, which exactly behaves as the controller expects it.
Because of this, it is highly recommendable to connect and drive CSB, as this explicitly tells the sensor the start of the sequence, which may also act as sensor-reset and would thus allow to clock even 16 bits, because it removes the irritation of the 5 bits too much.
PostPosted: Fri Jul 14, 2017 1:18 pm    Post subject: Reply with quote
Why do you shout out?
SPIINIT takes care of setting the portpins, you just need to read the help.
MichaelB.
PostPosted: Mon Jul 17, 2017 5:30 pm    Post subject: Reply with quote
My messy Test/Learn Programm is more Logic to me Very Happy
The Programm from Kimmi didnt change anything.
I have here a Screenshot collection from the Sensor. The MISO line doesnt look Healthy at all Very Happy Shocked Shocked
In this case i use this Code:
      Spiout RDAY , 1                                       ' Send "Y" Register code
      Spiin LoadYH , 1
      Spiin LoadYL , 1
      Wert1 = LoadY
Goto page 1, 2  Next
Page 1 of 2
