Using multiple MAX 7219 8 Digit Displays
PostPosted: Mon Jul 10, 2017 10:37 am    Post subject: Using multiple MAX 7219 8 Digit Displays Reply with quote
The max 7219 8 digit displays are very cheap to buy so I thought I would get some.
Then I looked for code to use them I found an example by Benoit to use one but not for multiple displays.
I developed code to use more than one it has six now but could be extended with ease.
NOTE when I went past two I started to get problems
I have found you MUST power each display separately do not daisy chain the power connections
power them from one central power feed.
Below is the code with dummy values loaded into the display buffer
There is more to come!
Regards Paul
  'multiple MAX 7219 8 DIGIT DISPLAY
$regfile = "m328pdef.dat"
$hwstack = 100
$swstack = 100
$framesize = 100
Config Portc.0 = Output                                     'PORT = OUTPUT
Config Portc.1 = Output                                     'PORT = OUTPUT
Config Portc.2 = Output                                     'PORT = OUTPUT
Declare Sub Displ_write(byval Pos As Byte , Byval Info As Byte , Byval Disnum As Byte)
Declare Sub No_op(byval T As Byte)
Declare Sub Max7219_setup
Declare Sub Buff_out(byval Disno As Byte)
' ---- USE PORT C
Cs_enable Alias Portc.2                                     ' chip-select 7219
Ser_clk Alias Portc.1                                       ' clk  7219
Ser_data Alias Portc.0                                      ' data  7219
Dim Seg_buff(6 , 9) As Byte                                 'enough for 6 x 7219s  9th byte for brightness
 '*** CONFIGURATION OF REGISTERS  7219
Call Max7219_setup
Seg_buff(1 , 8) = 14 + 128                                  'P.    ADD 128 TO TURN ON DECIMAL POINT
Seg_buff(1 , 7) = 13                                        'L
Seg_buff(1 , 6) = 11                                        'E
Seg_buff(1 , 5) = 12                                        'H
Seg_buff(1 , 4) = 10                                        '-
Seg_buff(1 , 3) = 3                                         '3
Seg_buff(1 , 2) = 2                                         '2
Seg_buff(1 , 1) = 1                                         '1
Call Buff_out(1)
Seg_buff(2 , 8) = 1                                         '1
Seg_buff(2 , 7) = 2                                         '2
Seg_buff(2 , 6) = 3                                         '3
Seg_buff(2 , 5) = 10                                        '-
Seg_buff(2 , 4) = 12                                        'H
Seg_buff(2 , 3) = 11                                        'E
Seg_buff(2 , 2) = 13                                        'L
Seg_buff(2 , 1) = 14                                        'P
Call Buff_out(2)
Seg_buff(3 , 8) = 1                                         '1
Seg_buff(3 , 7) = 2                                         '2
Seg_buff(3 , 6) = 3                                         '3
Seg_buff(3 , 5) = 4                                         '4
Seg_buff(3 , 4) = 5                                         '5
Seg_buff(3 , 3) = 6                                         '6
Seg_buff(3 , 2) = 7                                         '7
Seg_buff(3 , 1) = 8                                         '8
Call Buff_out(3)
Seg_buff(4 , 8) = 9                                         '9
Seg_buff(4 , 7) = 8                                         '8
Seg_buff(4 , 6) = 7                                         '7
Seg_buff(4 , 5) = 6                                         '6
Seg_buff(4 , 4) = 5                                         '5
Seg_buff(4 , 3) = 4                                         '4
Seg_buff(4 , 2) = 3                                         '3
Seg_buff(4 , 1) = 2                                         '2
Call Buff_out(4)
'Disable Interrupts
Reset Ser_data
Reset Ser_clk
Reset Cs_enable
   '===We need to send no operation to other 7219s
   '===so here we work out when to send
  Select Case Disnum
    Case 1                                                  'display 1
       Call No_op(5)
       Shiftout Ser_data , Ser_clk , Pos , 1 , 8 , 10
       Shiftout Ser_data , Ser_clk , Info , 1 , 8 , 10
    Case 2                                                  'display 2
       Call No_op(4)
       Call No_op(1)
    Case 3                                                  'display 3
       Call No_op(3)
       Call No_op(2)
    Case 4                                                  'display 4
       Call No_op(2)
       Call No_op(3)
    Case 5                                                  'display 5
       Call No_op(1)
       Call No_op(4)
    Case 6                                                  'display 6
       Call No_op(5)
Set Cs_enable
'Enable Interrupts
 Local C As Byte
 Local H As Word
 H = 0
 For C = 1 To T
  Shiftout Ser_data , Ser_clk , H , 1 , 16 , 10
 Next C
For Digit8 = 1 To 8
Call Displ_write(digit8 , Seg_buff(disno , Digit8) , Disno)
Sub Max7219_setup
   Local A As Byte
 For A = 1 To 6
Call Displ_write(12 , 0 , A)                                ' SHUTDOWN
Call Displ_write(9 , 255 , A)                               ' NO Decode "B" For 1st 7
Call Displ_write(10 , 1 , A)                                ' MAXIMUM BRIGHTNESS
Call Displ_write(11 , 7 , A)                                'DISPLAY 8 DIGITS
Call Displ_write(15 , 0 , A)                                ' TEST OFF
    'blank all display digits
For Digit8 = 1 To 8
Call Displ_write(digit8 , 15 , A)
Call Displ_write(12 , 1 , A)                                ' TURN ON
Waitms 100
PostPosted: Mon Jul 10, 2017 10:47 am    Post subject: Reply with quote
thanks for sharing Paul.
Simple to use Very Happy
PostPosted: Mon Jul 10, 2017 11:32 am    Post subject: Reply with quote
Hello Mark
Yes I wanted it simple.
Note there are errors in the comments next to buffer load because of cut and paste I will fix. >Done
Next I will read the ADCs and put that on the displays.
As with everything I post if you think it worthy you can put it in the examples.
Regards Paul
