Mrshilov
Posted: Wed Oct 04, 2017 8:23 am Post subject: Copy data from SD-card to XRAM |
I need to load content of file (768000 bytes) from SD-card to XRAM memory array. Bload don't work with XRAM. Get has restriction of 64k. So this string:
Code: | Get #10 , X(1) , , 768000 |
don't work properly with >64k array index and length of data.
I use this way: load data portion to XRAM 48000 bytes buffer and next copy from buffer to destination XRAM position:
Code: | Temp_dword = 48001
For Temp_word = 1 To 16
Get #10 , X(1) , , 48000 ' Copy 48kb from SD to buffer
For Word_count = 1 To 48000
X(temp_dword) = X(word_count) ' Copy from buffer to destination
Incr Temp_dword
Next Word_count
Next Temp_word |
It works, but slow, because of double unwanted writings. 76800 bytes loads with about 7 seconds. (Xmega128A1U, 48MHz, 16Mb SDRAM - 3port bus, BASCOM 2080)
Is where a faster way to load big data from SD-card directly to XRAM? |
enniom
Posted: Tue Oct 24, 2017 11:20 pm Post subject: |
An idea to consider:
Code: | DIM A1(48000) as Byte, A2(48000) as Byte, ... , An(48000) as Byte 'Create Back-to-Back XRAM arrays
Get #10, A1(1), , 48000
Get #10, A2(1), , 48000
Get #10, An(1), , 48000
E |
Mrshilov
Posted: Wed Oct 25, 2017 1:37 pm Post subject: |
No, it's not works. XRAM placed upper internal RAM (+16384), so real address of A1(1) is 16384, and A1(48000) - 64384. The next array A2(48000) is upper 64k, so GET function not working properly. Because of it I use 48k size buffer and not 64k. |
enniom
Posted: Sun Oct 29, 2017 11:34 am Post subject: |
One more idea .... I cannot test as I do not have your hardware setup ...
From Help:
Quote: | Dim var AS [XRAM/SRAM/ERAM]type [AT location/variable] [OVERLAY]
Dim x as Long at &H60 'long uses 60,61,62 and 63 hex of SRAM
Code: | DIM A1(&H10000) As XRAM Byte at &H4000 , A2(&H10000) As XRAM Byte At &H14000, ... , An(&H10000) As XRAM Byte At &Hn4000 'Create Back-to-Back XRAM arrays
Get #10, A1(1), , &H10000 'Please check this - it may need to be &HFFFF
Get #10, A2(1), , &H10000 '(or &HFFFF)
Get #10, An(1), , &H10000 '(or &HFFFF)
If this does not work, then it must be that the BLOAD and GET commands are limited to SRAM variables.
We could look at changing the library code such that the BLOAD memory pointer can recognize XRAM? Maybe Josef could help here.
E |
mmarlette
Posted: Mon Feb 19, 2018 7:53 pm Post subject: |
Any update on this? |
