jeezywonder
Joined: 19 Jan 2017 Posts: 34 Location: Russia, Vladivostok
Posted: Fri May 05, 2017 12:41 pm Post subject: Shiftout clocks EDGE??? |
Im in the situation now where clock generated by SLAVE(eeprom) and for example for data shiftin - it is impossible to read by slave's clocks, like this:
Code: | $regfile = "m8def.dat"
$crystal = 7600000
$hwstack = 64
$swstack = 64
$framesize = 64
$baud = 9600
D2 Alias Portd.2 'msda output
Dim Start_byte As Byte
Dim Data_read As Byte
Datain2 Alias Pind.3 'msda input
Datain4 Alias Pind.4 'clock input
Config Pind.4 = Input
Config Pind.3 = Input
Config Portd.2 = Output
D2 = 1 ' make msda = 0 (cuz of resistors output msda is inversve, 0 is 1, 1 is 0)
Waitms 5 ' wait 5ms, so clock will do its inizialisation bits
D2 = 0 ' put msda high
Waitus 20
Bitwait Datain4 , Reset
Waitus 5
D2 = 1
Bitwait Datain4 , Set
Waitus 1
D2 = 0
Shiftin Datain2 , Datain4 , Data_read , 7 , 8 , 40
If Data_read = &H55 Then
Print Hex(data_read)
Else
Print "BOOT FAIL"
But the problem comes with shiftout, it just doesn't have option 7, simply say shiftout cmd can't use xtl clock, why is that?
And how i can shiftout bytes another way?
Also, i can't use i2cSlave.lib, because im using simplified i2c.
Any help appriciate it, thanks
jeezywonder
Posted: Sat May 06, 2017 3:43 pm Post subject: |
Noone? |
bzijlstra
Posted: Sat May 06, 2017 5:59 pm Post subject: More info |
Perhaps you have to give some more information. Gone over your question but don't know what the problem is. You are talking about Slave(eeprom), is this hardware and what kind of hardware?
Not using the i2cSlave.lib, but you are using simplfied i2c. What is that?
Ben Zijlstra |
jeezywonder
Posted: Sun May 07, 2017 7:42 am Post subject: Re: More info |
bzijlstra wrote: | Perhaps you have to give some more information. Gone over your question but don't know what the problem is. You are talking about Slave(eeprom), is this hardware and what kind of hardware?
Ben Zijlstra |
I'm using Atmega8 with PCF7945 IC's eeprom, so in PCF7xxx family clock generates by pcf, therefore i can not use any of shiftout options[0-3], becouse it can work only with Atmega8(master) clocks. Simplified i2c means PCF more like i2c, spi - use their own dialogue, other then standart i2c protocol. And im not comletly sure about i2cSlave.lib because im lack of info about it, help page is not providing to much of it... thanks |
