Advantages of PCB design over bread board
Post new topic   Reply to topic    www.mcselec.com Forum Index -> PCB's
Balam
PostPosted: Mon May 22, 2017 8:52 am    Post subject: Advantages of PCB design over bread board Reply with quote
A PCB is used to connect electronic components electrically. This is done by making conductive path ways for circuit connections by etching tracks from copper sheet laminated onto a non-conductive substrate.
A PCB consists of a conducting layer that is made up of thin copper foil. The insulating layer di-electric is laminated together with epoxy resin prepreg. The most commonly used PCB type is the FR-4. Boards may be single sided or double sided. Double sided PCB can be used to connect components on both sides through through-hole plating. This is done by copper plating the walls of each hole so as to connect the conductive layers of the PCB.
Advantages of PCB over Bread-board
    You can get a much higher density board with PCB.
    You will find the PCB design to be more reliable than the one made on a bread board. The circuit will look neat without any wires popped up and will not fall apart.
    You can have very precise control over the circuit component you are using, and you can comfortably fit in odd shaped components that are difficult to fix on a bread board.
    For production of large volume of circuit boards, the costs become less and the soldering can be done by fully automated machines.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> PCB's All times are GMT + 1 Hour
