pass an eeprom variable to sub/function
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions
karlos
PostPosted: Wed May 24, 2017 5:25 pm    Post subject: pass an eeprom variable to sub/function Reply with quote
Hi
i want to pass a variable and its related eeprom variable to sub and by pressing a key save current value of variable to related eeprom variable,how is it possible?
for example
dim param as byte
dim e_param as eram byte
dim m as byte
dim e_m as byte
dim s as byte
dim e_s as eram byte
sub save_to_ee(param as byte,e_param as byte,key_condition)
if key_condition=1 then
   e_param=param
endif
end sub
key_condition=pinb.0
call save_to_ee(m,e_m,key_condition)
call save_to_ee(s,e_s,key_condition)
end
karlos
PostPosted: Wed May 24, 2017 5:28 pm    Post subject: Reply with quote
some note:
-compiler dont accept eeprom variables as input argument
-compiler accept eeprom variable as byval
so it make a copy of value of variable and we can not save value to eeprom in sub/functions.
thanks
PostPosted: Wed May 24, 2017 6:22 pm    Post subject: Reply with quote
I use tables for that. You should only decide which address will represent which value.
Config Submode = New
'general purposes
Dim N As Byte , Helpb As Byte , Helpw As Word
'variables
Dim My_bytes(20) As Byte , My_ee_bytes(20) As Eram Byte
Sub Read_whole_memory()
 For N = 1 To 20
  My_bytes(n) = My_ee_bytes(n)
End Sub
Sub Save_to_ee(byval Address As Byte)
 My_bytes(address) = Helpb
 My_ee_bytes(address) = Helpb
End Sub
Call Save_to_ee(1)                      'for example
You can even add aliases that will be related to variable function. For example:
Voltage Alias 1
Current Alias 2
Call Save_to_ee(current)
karlos
PostPosted: Wed May 24, 2017 7:22 pm    Post subject: Reply with quote
thanks a lot EDC
i remember that we have some instructions in assembly for find address,why the compiler does not find address by these instruction automatically and write to related address?!
is some limitions on stack or frame or some things else?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions All times are GMT + 1 Hour
