EEPROM Problem
muhammadzvl
PostPosted: Sat Jun 03, 2017 6:58 pm    Post subject: EEPROM Problem Reply with quote
hello, i'm using at8535.
i want to know why the uC can't read and write the bytes from EEPROM. This is the source code of my work.
$regfile = "m8535.dat"
$baud = 9600
Config Portd.7 = Output
Config Portc.0 = Output
Config Portc.1 = Output
Config Portc.2 = Output
Config Portc.3 = Output
Config Portc.4 = Output
Portd.7 = 0
Portc.0 = 0
Portc.1 = 0
Portc.2 = 0
Portc.3 = 0
Portc.4 = 0
Dim I As Byte
$eeprom
Memory1:
Data 1,2
$data
Readeeprom I, Memory1
   I = Waitkey()
   Writeeeprom I, Memory1
   '3 lamp'
   If I = "A" Then
   Portd.7 = 1
   Elseif I = "B" Then
   Portd.7 = 0
   Elseif I = "C" Then
   Portc.0 = 1
   Elseif I = "D" Then
   Portc.0 = 0
   Elseif I = "E" Then
   Portc.1 = 1
   Elseif I = "F" Then
   Portc.1 = 0
   'solenoid'
   Elseif I = "G" Then
   Portc.2 = 0
   Elseif I = "H" Then
   Portc.2 = 1
   'rolling door'
   Elseif I = "I" Then
   Portc.3 = 1
   Portc.4 = 1
   Waitms 300
   Portc.3 = 0
   Portc.4 = 1
   Wait 3
   Portc.3 = 1
   Portc.4 = 1
   Elseif I = "I" Then
   Portc.3 = 1
   Portc.4 = 1
   Waitms 300
   Portc.3 = 1
   Portc.4 = 0
   Wait 3
   Portc.3 = 1
   Portc.4 = 1
   Waitms 100
When i turned off the supply for uC and turned on again, the EEPROM seems not working. I want to use the EEPROM to control the lamp.
What is wrong with the code, any help would be appreciated. Thanks
Best Regards,
Zulfikar
(BASCOM-AVR version : 2.0.7.5 , Latest : 2.0.7.8 )
PostPosted: Sat Jun 03, 2017 10:39 pm    Post subject: Reply with quote
For the At90S8535 you have to use $regfile = "8535DEF.dat"
If you using the AtMega8535 then $regfile = "m8535.dat" is correct.
muhammadzvl
PostPosted: Sun Jun 04, 2017 4:21 am    Post subject: Reply with quote
i'm using AtMega8535, so the regfile is correct.
the problem is when i turned off the power for the uC and turn it on again, the last command (the bytes that i want to stored to EEPROM) for controlling the lamp is not working. it seems that the bytes didn't wrote to EEPROM.
for example: before the power is off, i'm sending the bytes via bluetooth to turn on the lamp, then i'm shutting down the power and the lamp is not turned on although i've turned it on.
what should i do? is the code is wrong?
best regards,
Zulfikar
PostPosted: Sun Jun 04, 2017 10:04 am    Post subject: Reply with quote
The waitkey in your do~loop is blocking the rest of the do loop because is waiting forever for input.
Better is to see every loop is there's input and then handle it.
Something like this
$baud = 9600
Portd.7 = 0
Portc.0 = 0
Portc.1 = 0
Portc.2 = 0
Portc.3 = 0
Portc.4 = 0
Dim A As Byte
Dim I As Byte
Dim Memory1 As Byte
Memory1 = 1
  A = Ischarwaiting()
   If A = 1 Then                                            'we got something
      I = Waitkey()                                         'get it
        Writeeeprom I , Memory1
   '3 lamp'
   If I = "A" Then
   Portd.7 = 1
   Elseif I = "B" Then
   Portd.7 = 0
   Elseif I = "C" Then
   Portc.0 = 1
   Elseif I = "D" Then
   Portc.0 = 0
   Elseif I = "E" Then
   Portc.1 = 1
   Elseif I = "F" Then
   Portc.1 = 0
   'solenoid'
   Elseif I = "G" Then
   Portc.2 = 0
   Elseif I = "H" Then
   Portc.2 = 1
   'rolling door'
   Elseif I = "I" Then
   Portc.3 = 1
   Portc.4 = 1
   Waitms 300
   Portc.3 = 0
   Portc.4 = 1
   Wait 3
   Portc.3 = 1
   Portc.4 = 1
   Elseif I = "I" Then
   Portc.3 = 1
   Portc.4 = 1
   Waitms 300
   Portc.3 = 1
   Portc.4 = 0
   Wait 3
   Portc.3 = 1
   Portc.4 = 1
  Waitms 100
muhammadzvl
PostPosted: Sun Jun 04, 2017 12:21 pm    Post subject: Reply with quote
Something like this
$baud = 9600
Portd.7 = 0
Portc.0 = 0
Portc.1 = 0
Portc.2 = 0
Portc.3 = 0
Portc.4 = 0
Dim A As Byte
Dim I As Byte
Dim Memory1 As Byte
Memory1 = 1
  A = Ischarwaiting()
   '3 lamp'
   If I = "A" Then
   Portd.7 = 1
   Elseif I = "B" Then
   Portd.7 = 0
   Elseif I = "C" Then
   Portc.0 = 1
   Elseif I = "D" Then
   Portc.0 = 0
   Elseif I = "E" Then
   Portc.1 = 1
   Elseif I = "F" Then
   Portc.1 = 0
   'solenoid'
   Elseif I = "G" Then
   Portc.2 = 0
   Elseif I = "H" Then
   Portc.2 = 1
   'rolling door'
   Elseif I = "I" Then
   Portc.3 = 1
   Portc.4 = 1
   Waitms 300
   Portc.3 = 0
   Portc.4 = 1
   Wait 3
   Portc.3 = 1
   Portc.4 = 1
   Elseif I = "I" Then
   Portc.3 = 1
   Portc.4 = 1
   Waitms 300
   Portc.3 = 1
   Portc.4 = 0
   Wait 3
   Portc.3 = 1
   Portc.4 = 1
  Waitms 100
Oh dear- work like a charm! thank you mate!
(edit) that source code is just worked with 1 lamp, so how if i controlled more than one, for example 3 lamps? just modifying the A?
one last question, how if i want to set the PWM for the "rolling door"?
i'm using DC motor, 12V supply.
Best Regards,
Zulfikar
