UTF-8 to ASCII in a string
kimmi
Moderator
PostPosted: Mon Feb 13, 2017 2:45 pm    Post subject: UTF-8 to ASCII in a string Reply with quote
For a webradio i sent raw metadata via comport to mcu to display it on Nextion HMI lcd
metadata is in raw UTF-8 so i need to convert UTF-8 to ascii
it works but is there a better / faster way to convert UTF-8 to ascii in a string ?
'For lcd convert utf-8
Declare Sub Remove_utf8(byval Characters As String)
Dim Index As Byte , Len_characters As Byte , Index_1 As Byte
Dim Tmp_str_1 As String * 1 , Tmp_str_2 As Byte , Tmp_str_3 As Byte , Tmp As Byte
Dim My_string As String * 60
' THOR GÖRANS - FREDAG I KÖPENHAMN  <****>  Chr(195) + Chr(150) = hex C3 96    Ã–
My_string = "THOR G" + Chr(195) + Chr(150) + "RANS - FREDAG I K" + Chr(195) + Chr(150) + "PENHAMN"
   Call Remove_utf8(my_string)
   Print My_string
   Index = 1
   Len_characters = Len(characters)
   While Index <= Len_characters
      If Mid(characters , Index , 1) >= Chr(194) And Mid(characters , Index , 1) <= Chr(195) Then       ' C3 C4
         Index_1 = Index + 1
         Tmp_str_1 = Mid(characters , Index , 1)
         Tmp_str_2 = Asc(tmp_str_1)
         Shift Tmp_str_2 , Left , 6
         Tmp_str_2 = Tmp_str_2 And &HFF
         Tmp_str_1 = Mid(characters , Index_1 , 1)
         Tmp_str_3 = Asc(tmp_str_1)
         Tmp_str_3 = Tmp_str_3 And &H3F
         Tmp = Tmp_str_2 Or Tmp_str_3
         Tmp_str_1 = Chr(tmp)
         Mid(characters , Index , 1) = Tmp_str_1
         Delchar Characters , Index_1
      Incr Index
   Wend
 My_string = Characters
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.7.8 )
/ Kim
PostPosted: Tue Feb 14, 2017 2:35 am    Post subject: Reply with quote
Lookup table ?
Adrian Jansen
PostPosted: Tue Feb 14, 2017 10:40 pm    Post subject: Reply with quote
if you want the clean ASCII, you only need to check the MS bit. If it is 1, skip, if it is 0, it is plain ASCII and keep it.
then make a simple loop :
z="" 'clear return string
for j=1 to len(s)
  b=asc(s,J) 'get byte
  if b.7=0 then  'normal ASCII
    z=z+chr(b)  'add to return string
  end if
next
now z contains the plain ascii code.
kimmi
Moderator
PostPosted: Wed Feb 15, 2017 11:48 am    Post subject: Reply with quote
The "normal ASCII" did not work for me on lcd
S : THOR GÖRANS - FREDAG I KÖPENHAMN
Z : THOR GRANS - FREDAG I KPENHAMN
but you'r code was simple, so i change it and now it runs fine for me
Z : THOR GÖRANS - FREDAG I KÖPENHAMN
Dim S As String * 60
Dim Z As String * 60
Dim J As Byte , B As Byte , A As Byte
S = "THOR G" + Chr(195) + Chr(150) + "RANS - FREDAG I K" + Chr(195) + Chr(150) + "PENHAMN"
   Print S                                                  ' Thor Gã–rans - Fredag I Kã–penhamn
   Z = ""                                                   'clear return string
   For J = 1 To Len(s)
      B = Asc(s , J)                                        'get byte
      If B >= 194 And B <= 195 Then                         'utf-8 ASCII
         J = J + 1                                          'incr j for next char
         A = Asc(s , J)                                     'get next char
         Shift B , Left , 6                                 ' shift it left by 6
        B = B Mod &HFF
        A = A Mod &HFF
         B = B Or A                                         'or  utf-8 with next char
         Z = Z + Chr(b)                                     'add to return string
    S = Z                                                   'Thor Görans - Fredag I Köpenhamn
/ Kim
PostPosted: Wed Feb 15, 2017 3:35 pm    Post subject: Reply with quote
aha, i see. you want to have the other chars.
well you could do a lookup and replace them. and when not in the table, use a ?
kimmi
Moderator
PostPosted: Wed Feb 15, 2017 5:25 pm    Post subject: Reply with quote
hi,
The Nextion HMI lcd i have added ISO 8859-15 so all chars are working with this code
/ Kim
PostPosted: Mon Apr 17, 2017 5:34 pm    Post subject: Reply with quote
I see the Nextion project,
Before trying
It seems to me it is a "Visual basic like" to do very fast interface, maybe you have a video about it... working with Bascom ?
How it works, serial instruction ?
many thanks for your help
JP
Rolling Eyes Question
