receive and evaluate signs over UART
SHA
PostPosted: Mon Apr 10, 2017 1:34 pm    Post subject: receive and evaluate signs over UART Reply with quote
Please excuse my bad english
I want to receive a signs over the UART and evaluate it.
I currently use this solution (example):
If Usr.rxc = 1 Then
Z = Udr
Select Case Z
Case "3"
Call Up
Case "2"
Call Down
End Select
This is not optimal - not all signs are detected -
i must repeat.
Is there a better solution?
Thanks Andreas
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.7.8 )
PostPosted: Mon Apr 10, 2017 2:40 pm    Post subject: Reply with quote
read the help and try the sample about serial
learn about Ascii code
Buffer ?
Speed of your program $baud ?
etc..
JP
bzijlstra
Bascom Ambassador
PostPosted: Mon Apr 10, 2017 2:54 pm    Post subject: Some communication improvements.. Reply with quote
If I understand your question correctly:
Check how the wireless serial ESP-module is connected to the Arduino Mega 2560 and not missing any character on the Weatherstation. Using a serial buffer, reading complete lines finished with CR/LF. The exchange of 'pure ASCII-characters' at 9600 baud.
Perhaps an idea?
Have fun
Ben Zijlstra
Paulvk
PostPosted: Tue Apr 11, 2017 11:43 am    Post subject: Reply with quote
Hello Andreas
I wrote this program
it sends a command to a solar inverter
it receives data back and works out what is sent
This may help you
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13341
Regards Paul
