kinjark
Posted: Mon Apr 03, 2017 7:53 pm Post subject: Do something when var changes |
Dear MCSelec community,
the purpose is that I want to change 1 var when I press the button (Incr) and I want to use CLS if that var changes. Only once. I would also use that for example when pin = 1 then A=1 but I would like to incr A even if pin = 1. Pin would just set A back to 1 to start again.
So like if var C is not same as C in the previous cycle, or also maybe if one condition was true, but now it is not anymore and then again when it comes true. If I put cls in the code, it would clear all the time and it is annoying.
At the moment I used:
Config Timer0 = Timer , Prescale = 64
On Timer0 Casovnik
Enable Timer0
Casovnik:
If C = 1 OR C = 2 OR C = 3 OR C = 4 then 'C is the var I change by pressing the button'
Cas4 = Cas4 + 1
If Cas4 >= 201 Then
Cas4= 0
end if
If Cas4 = 200 then D = C 'D is only there so I have delay for cls'
If D <> C and Cas4 = 50 then cls
the problem is that sometime is working ok and sometimes not as it should or I would want to. If I scroll menu fast it doesn't cls.
I can post whole code but it is quite big and it is hard to find stuff.
Posted: Mon Apr 03, 2017 8:43 pm Post subject: |
I was try to understand question but..I dont understant it maybe.
But I have a tip:
Code: | Dim Value As Byte, Old_value As Byte
If Old_value <> Value Then
' do wanted staff
Old_value = Value ' alignment values for purpose of doing this only once if they differ
End If |
kinjark
Posted: Mon Apr 03, 2017 9:40 pm Post subject: |
EDC wrote: | I was try to understand question but..I dont understant it maybe.
But I have a tip:
' do wanted staff
End If |
Interrupts are enabled so I think this won't work.
For example:
On Timer0 Casovnik
Enable Timer0
Casovnik:
Cas1 = Cas1 + 1
If Cas1 >= 490 Then
Cas1= 0
If Cas1 = 1 then
Incr A
If A => 10 then A=0
End if |
How can I say if pina.0 = 0 then A = 1, but even if pina.0 is still 0 the cycle would incr A with pina.0 staying 0.
If I say
if pina.0=0 then A = 1
incr A
So I have a problem because it will stay 1 because condition is still true.
I need so when I press button I will incr C and for each number of C I have a menu on LCD that is shown. But I want to cls LCD only when C increases. if C = 3 and I incr C to 4, I want to cls only once, even if C is still 4. If I say If C=4 then cls it will cls every cycle (490 times a second) because C is still 4.
Same problem is with Incr. If I say: if pinA.0 = 0 then incr C and with interrupts means it will increase for 490 every second until pina.0 <> 0. I want C to be increased only once even if pina.0 is still 0. |
Posted: Mon Apr 03, 2017 10:13 pm Post subject: |
Please post the code (short as possible but that show the issue)
For reading more than one pin from port I use pinmasks
Const Sw_mask = &B00011110 'checked will be bits/pins 1,2,3 and 4
Sw_state = Pinb And Sw_mask
If Sw_state <> Sw_mask Then
To understand how switches can be handle look at this short one button example.
Code: | ' This code toggle Led_1 after short push on Switch and toggle Led_2 when Switch is push and hold for long
$regfile = "m16def.dat"
$hwstack = 32
$swstack = 16
$framesize = 64
Config Porta.6 = Output : Led_1 Alias Porta.6
Config Porta.7 = Output : Led_2 Alias Porta.7
Config Porta.0 = Input : Set Porta.0 : Switch Alias Pina.0
Dim Sw_cnt As Byte , Lock As Byte
Config Timer2 = Timer , Prescale = 1024 , Compare = Disconnect , Clear_timer = 1
COMPARE2 = 77 '10ms @8MHz/1024
If Tifr.ocf2 = 1 Then 'the 10ms is past, this flag set the Timer
Tifr.ocf2 = 1 'clearing the flags is done by writing ones NOT ZEROS!
If Switch = 0 Then 'if button is pressed
If Lock = 0 Then 'and lock is not triggered
If Sw_cnt < 50 Then 'we increase sw_counter if long_push value not reached
Incr Sw_cnt 'increasing counter
Else 'but if we hold button long..
Lock = 1 'lock increasing the counter
Toggle Led_2 '->and change state of LED_2 because it is long_push
Else '..if button is released
If Lock = 0 Then ' and previous,it was not a long push activity
If Sw_cnt > 3 Then Toggle Led_1 'check if button was pressed atleast 3 periods (3x10ms)
End If '->toggle LED_1 because it was short click
Lock = 0 : Sw_cnt = 0 'clear lock and counter
End |
This can be easy adapted for more switches or autorepeat action when buttons holded for long. |
kinjark
Posted: Tue Apr 04, 2017 7:48 am Post subject: |
I will try if I can use your button/switch thing, it will definitely help me for some cases but it is hard to see it from my code because it is not working
On Timer0 Casovnik : Enable Timer0
Config Debounce = 20
Count = 1
wait 5
cls
B=0
C=1
Debounce tipkaparametri , 0 , meni , Sub
If 0 < Ischarwaiting() Then
Inputbin Array(count) , 1
Timeout = 100
If Count < 17 Then
Incr Count
If you remember you helped me with that transmission.
'Meni za prikaz stanja vode v rezervarju'
If C = 1 then
Locate 1 , 1 : Lcd "Meritve vode: ";B;
Locate 1 , 20 : Lcd ;A;
Locate 2 , 2 : Lcd "Globina: " ; SP3 ;" cm "
Locate 3 , 2 : Lcd "Volumen: " ; Fusing(CUB1 , "#.###") ;" m"; Chr(4) ;" "
Locate 4 , 2 : Lcd "Nivo v %: " ; Fusing(procenti , "#.#") ;" % "
Locate 4 , 20 : Lcd ;C;
End if
'Osnovni meni'
If C = 2 then
Locate 1 , 1 : Lcd "*** STANJE VODE ***"
Locate 2 , 1 : Lcd "Breznica pod"
Locate 3 , 1 : Lcd " Lubnikom 15 "
Locate 4 , 8 : Lcd ;Fusing(procenti , "#.#") ;" %"
If procenti > 99 and pretokaktiven <> 0 then
Locate 4 , 4 : Lcd ;Chr(7);;Chr(7);;Chr(7);
end if
If procenti =< 99 and procenti > 98 and pretokaktiven <> 0 then
Locate 4 , 5 : Lcd ;Chr(7);;Chr(7);
end if
If procenti =< 98 and procenti => 97 and pretokaktiven <> 0 then
Locate 4 , 6 : Lcd ;Chr(7);
end if
if pretokaktiven = 0 then
Locate 4 , 4 : Lcd ;Chr(5);;Chr(5);;Chr(5);
end if
end if
So when I press the button I increase C, If C=1 then I have the first menu and if C=2 then it shows second menu.
When I press button, menu 1 will appear for example but if I press it again menu 2 will have some letters remaining from menu 1 because I don't have cls. If I put cls at the beginning of every menu, then menu will be blinking. What I want to do is that if I change the menu, I would cls so I don't have anything from previous menu, but then I do not cls unless I change the menu again.
The other part is that I have some signs for inputs. If I have some inputs active I have some arrows on my LCD (different for every input), but sometimes no input is active then I want to cls to remove all arrows. But only once not every time when atmega will read that pinc.0=0 because I would get blinking all the time again.
Lcd "";Chr(1);"akam povezavo..."
Count = 1
Waitms 1
'this will set array pointer to start if not whole array arrive on time
If Timeout > 0 Then
Decr Timeout
Count = 1
Casovnik:
'Nastavitev 1 sekunde za Incr A intervala'
Cas1 = Cas1 + 1
If Cas1 >= 490 Then 'Nastavitev zakasnitve, št. ciklov po 64, ker PS=64'
Cas1= 0
If Cas1 = 1 then
Incr A
If A => 10 then A=0
End if
'Nastavitev cls'
Cas4 = Cas4 + 1
If Cas4 >= 201 Then 'Nastavitev zakasnitve, št. ciklov po 64, ker PS=64'
Cas4= 0
end if
If D <> C and Cas4 = 199 then cls
Meni:
incr C
if C => 5 then C = 1
This is just the end with timers, that I used so far. For example every second I increase A from 1 to 10. Is it possible to say if pinc.0=0 then A=1, but continues to count up to 10 even if pinc.0 stays = 0. Because if I write If pinc.0 = 0 then A=1, A will remain 1 and it will not increase until pinc.0 <> 0.
Whole file is attached in txt just in case.
Many thanks for your help already! |
Posted: Tue Apr 04, 2017 10:41 am Post subject: |
If I understand the code enough program refresh LCD only if new data arrive and You want to view diferrent menu pages/values from that one transmission.
You also want to update some view with timer, and it would be nice to update LDC with button
This can be easy done. You must independ showing data on lcd from Ischarwaiting()
I add variable Refresh. This variable can be set by incomming data, by presing the button or timer tick
So if Refresh = 1 LCD wil be updated depending on variable C value
Look at this pseudo code
Code: | Dim Refresh As Byte
If Data Is Valid Then Refresh = 1
Debounce Switch , 0 , Switch_sub , Sub 'button
If Refresh = 1 Then 'independent from Ischarwaiting
Refresh = 0 'show only once per "Refresh = 1"
'switch also can set this flag to 1
Cls 'clear then screen only once
Select Case Menu
Case 1
Case 2
Case 3
Switch_sub :
Incr Menu : If Menu > 3 Then Menu = 1
Refresh = 1 'switch also can trig the refresh
Timer_tick :
Incr Ticker
If Ticker > Period Then
Ticker = 0 : Refresh = 1
..and now its time for another tip
This is not nice solution
Code: | If C = 1 Or C = 2 Or C = 3 Or C = 4 Then
'all conditions are for the same variable
End If |
Better would be:
Code: | Select Case C
Case 1 To 4 : 'do something
End Select |
Your code slightly modified, but not tested, attached. This is for show the idea.
In this code much another points can be optimised.
Have a nice day  |
kinjark
Posted: Tue Apr 04, 2017 5:20 pm Post subject: |
Well Bardzo dziękuję!
I have found "case" thing few days ago because I was looking for this solution, but haven't put it in yet because I was not 100% sure in it and I had other problems to solve. But code is much bigger then I thought before I started this project and I am always adding something and deleting something else, that is why code is a mess. And also I did something the ways I knew how at that time but then I figured there is a command for it and can be done with much less effort
Your file will also help me understand this ifcharwaiting much better, first time when I got the code from you with interrupts I had no idea why simple incr A in the middle of code didn't work. So I guess that is a progress
As a first project it will do even if it is a little messy But I am getting addicted to this.
Thank you very much again!  |
