Library for ST7735R display
Goto page 1, 2  Next
Mrshilov
Bascom LCD Guru
PostPosted: Wed Mar 08, 2017 6:03 am    Post subject: Library for ST7735R display Reply with quote
I make asm library for ST7735R. I don't have this display and test it on Proteus-8 model.
Library works with 8-bit color in portrait & landscape modes and have "rotate 180°".
If anybody have this display, please check it.
enniom
PostPosted: Thu Mar 09, 2017 5:24 am    Post subject: Reply with quote
Thank-you for posting. I will test tomorrow.
Do you think this will work on Xmega?
E
Mrshilov
Bascom LCD Guru
PostPosted: Thu Mar 09, 2017 10:44 am    Post subject: Reply with quote
Yes, it must work on Xmega:
$regfile = "xm256a3budef.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 64
$framesize = 64
Config Osc = Disabled , 32mhzosc = Enabled
'------------------------------- Setup -----------------------------------------
$lib "glcd-ST7735R.lib"
Config Vport0 = D
Config Graphlcd = Color , Cs1 = Port0.7 , Si = Port0.6 , Sclk = Port0.5 , Cs1 = Port0.4, Rst = Port0.3
I can't test it - Proteus don't support Xmega.
PostPosted: Thu Mar 09, 2017 11:26 am    Post subject: Reply with quote
Hello Mrshilov
Thank you for sharing. Even while you could not test it, i am sure it will work. You are the LCD expert Very Happy
enniom
PostPosted: Tue Mar 21, 2017 10:28 pm    Post subject: Reply with quote
Hello Sergey,
I can confirm that the ST7735R library works on XMEGA. However, it seems that all connections must be from the same PORT. Is this correct?
How difficult would it be to change the library so that the connections are from different PORTs?
$crystal = 32000000
$hwstack = 64
$swstack = 64
$framesize = 64
'====== THIS WORKS OK ===========
Config Vport0 = C
Config Graphlcd = Color , A0 = Port0.3 , Si = Port0.5 , Sclk = Port0.7 , Cs1 = Port0.4, Rst = Port0.6
'   ====  THIS DOES NOT WORK ?????  ======
Config Vport0 = C, Vport1 = E
Config Graphlcd = Color , A0 = Port0.3 , Si = Port1.0 , Sclk = Port1.1 , Cs1 = Port0.4, Rst = Port0.6
PS: There is also a bicycle road racing professional from Russia with your same name?
E
Mrshilov
Bascom LCD Guru
PostPosted: Wed Mar 22, 2017 12:12 pm    Post subject: Reply with quote
It must work from different PORTs.
P.S. Yes, and also there is six time Paralympic Champion:
https://en.wikipedia.org/wiki/Sergey_Shilov
This not I am, and they are not my relatives. Smile
enniom
PostPosted: Wed Mar 22, 2017 2:09 pm    Post subject: Reply with quote
Hi Sergey,
Please see this video: https://youtu.be/HYXCUI1-I30
This is the result of defining connections from different VPORTs:
Config Vport0 = C , Vport1 = E
Config Graphlcd = Color , A0 = Port0.3 , Si = Port1.0 , Sclk = Port1.1 , Cs1 = Port0.4 , Rst = Port0.6
If real ports are used - for example:
Config Vport0  = c
Config Graphlcd = Color , A0 = Port0.3 , Si = Porte.0 , Sclk = Porte.1 , Cs1 = Port0.4 , Rst = Port0.6
Then, these errors are created:
Error : 221 Line : 205 Backward Jump Out Of Range [_clear_graph1 [ 86]] , In File : C : \ Program Files(x86) \ Mcs Electronics \ Bascom -avr \ Lib \ Glcd -st7735r.lib
Error : 221 Line : 207 Backward Jump Out Of Range [_clear_graph2 [ 89]] , In File : C : \ Program Files(x86) \ Mcs Electronics \ Bascom -avr \ Lib \ Glcd -st7735r.lib
PS: But you are the LCD Library Champion. :D :D
E
twinsen
PostPosted: Wed Apr 19, 2017 9:08 am    Post subject: Reply with quote
I have tested this library with ST7735R display.
All connections are from the same PORT.
It works, but with slight mistakes.
Everything (boxfill, lines, pset) is moved one pixel row down and two pixel columns to the right on the screen (in both landscape and portrait orientations).
To make it work correctly I had to write like this:
Boxfill( -2 , -1) -(127 , 159) , Green
Personally for Mrshilov:
Работает, но все смещено на 2 пикселя вправо и 1 пиксель вниз в обеих ориентациях.
Поворот не пробовал.
Mrshilov
Bascom LCD Guru
PostPosted: Thu Apr 20, 2017 9:25 am    Post subject: Reply with quote
May be, may be. ST7735 has 162x132 resolution. Proteus model also. If real display 160x128, so some pixels are unvisible. In NOKIA-1616 LCD with SPFD54124B the same situation and screen has shift 2 pixels horizontal and 1 pixel vertical. So I make library for ST7735 similarly.
If this shifts not needed - try this version.
twinsen
PostPosted: Thu Apr 20, 2017 8:51 pm    Post subject: Reply with quote
This version works OK.
I tried it in portrait orientation.
Thank you Mrshilov for your hard work.
Эта версия работает правильно: рисует рамку и ставит точки по углам как надо.
Спасибо за проделанную работу.
VladYar
PostPosted: Tue May 16, 2017 2:29 am    Post subject: Fonts Reply with quote
Sergei! I ask you to add fonts with the support of the Cyrillic if possible. Also I ask to add fonts with a larger size. How to make fonts? Thank you.
jure_m
PostPosted: Wed Feb 06, 2019 12:15 pm    Post subject: Reply with quote
Hi Mrshilov,
I am testing your sample for ST7735R display library for resolution 128x160.
It all works well however, you have mentioned there that CS1 & Rst are optional. I did disconnect them, but then LCD does not show anything. Do I have to connect CS1 or RST to GND or Vcc instead?
Best regards
Jure
Mrshilov
Bascom LCD Guru
PostPosted: Wed Feb 06, 2019 12:54 pm    Post subject: Reply with quote
CS must be connected to GND.
RST - to Vcc.
jure_m
PostPosted: Wed Feb 06, 2019 2:11 pm    Post subject: Reply with quote
Hi Mrshilov,
well this connection does not work if power is OFF and back ON again. I have connected RST in between 10k connected to Vcc and 10uF connected to GND to reset LCD, while CS had to be connected to uC.
Best regards
Jure
O-Family
PostPosted: Wed May 01, 2019 3:22 pm    Post subject: 0.96inch 65K FullColorLCD 160x80dot [ST7735R] Reply with quote
Thank you to Mrshilov's efforts.
The ST7735R library has been modified for a 0.96inch 160x80 dot LCD module.
Circuit diagram
https://drive.google.com/file/d/1h0WkDd3q_3EPc-RvnaiICzqX5lO6kHED/view?usp=sharing
Goto page 1, 2  Next
Page 1 of 2
