allsetgo
Posted: Fri Feb 17, 2017 7:36 pm Post subject: Read Cypress Flash S25FL164K |
Hello
I have connected Cypress Flash S25FL164K with ATMEGA164p via SPI. I am not able to read the flash. has anyone worked with cypress flash before?
All I am doing is sending instruction ABh and as per datasheet I should get the device ID back. I have attached the datasheet for ref. Refer pg. 60, (6.6.1- Legacy Device Identification Commands)
Code: | $regfile = "M164pdef.dat"
$crystal = 14745600 'this freq give 0.0% error for all baud rates up to 115200
$baud = 57600
$hwstack = 80 'used for GOSUB addresses {default is 32}
$swstack = 80 'default use 10 for the SW stack
$framesize = 80 'space size for Registers defining variables
Config Serialin = Buffered , Size = 8
Config Spi = Hard , Interrupt = Off , Data_order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
Spiinit
Dim Spi_buffer As Byte
Dim Read_data As Byte
Spi_buffer = &B10101011 ' send Instruction code ABh
Reset Portb.4 ' Make CS/ low
Spiout Spi_buffer , 1
Spiin Read_data , 1
Waitms 1
Set Portb.4 ' Make CS/ high
Print Read_data
(BASCOM-AVR version : 2.0.7.5 , Latest : 2.0.7.8 ) |
kimmi
Posted: Fri Feb 17, 2017 10:56 pm Post subject: |
you must setup noss =0 and add a pin for CS sample code use portb.0 for CS
you must sent AB + 3 dumyi bytes
$crystal = 14745600
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 57600
'SPI config
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 0
Spiinit
'CS pin setup a pin for CS
Chip Alias Portb.0
Config Portb.0 = Output
Set Chip
Dim Spi_buffer(6) As Byte
Dim Read_data(6) As Byte
Dim Inst As Byte
Declare Sub Read_id()
Wait 1
Call Read_id() '&HAB cmd
Wait 5
When Used Only To Obtain The Device Id While Not In The Deep Power -down State,
shifting the instruction code ABh followed by 3-dummy bytes.
The Device Id Bits Are Then Shifted Out On The Falling Edge Of
Sck With Most Significant Bit(msb) First.
Sub Read_id()
Inst = &HAB ' send Instruction code ABh see 8.5.2
Spi_buffer(1) = Inst
Spi_buffer(2) = &H00 '3-dummy bytes
Spi_buffer(3) = &H00
Spi_buffer(4) = &H00
Reset Chip ' Make CS/ low
Spiout Spi_buffer(1) , 4 'sent ab + 3 dummy see 8.5.2
Spiin Read_data(1) , 1 'Read Device Id
Set Chip ' Make CS/ high
Print "ID : " ; Hex(read_data(1)) ; ' see 6.6.1
If Read_data(1) = &H14 Then Print " W25q16"
If Read_data(1) = &H16 Then Print " S25FL164K"
End Sub |
This is how i write read W25Q16dv
compare it to your datasheet
Code: | $regfile = "m328pdef.dat"
$crystal = 8000000
$baud = 38400
$hwstack = 64
$swstack = 64
$framesize = 80
'SPI config
Spiinit
'Chip Select handling of portB.0
'If the Noss = 1, the hardware SS internal management but are not limited,
'IMPORTANT!
'The Winbond W25Q16DV 16Mbit chip (also) organized WORD,
'So the CS rate is to be treated separately, as the HW-solving and bytes
' datasheet
'http://www.elinux.org/images/f/f5/Winbond-w25q32.pdf
'25q mcu
'/CS : Chip
'DO : MISO
'DI : MOSI
'Clk : Sck
'wp & hold pullup+3,3v
'CS pin
Chip Alias Portb.0
Set Chip
Declare Sub Jedec_id()
Declare Sub Device_id()
Declare Sub Parameter_page()
Declare Sub Read_data()
Declare Sub Write_data()
Declare Sub Clear_mem()
Declare Sub Clear_pp()
Declare Sub Write_dis()
Declare Sub Write_en()
Declare Sub Stbit()
Dim Sent_data(8) As Byte
Dim Sent_p(8) As Byte
Dim read_data_tmp(8) As Byte
Dim my_data(8) As Byte
Dim Data_in(4) As Byte ' the array of input data
Dim Data_out(8) As Byte ' the array of 'output data
Dim Mem_p As Byte
Dim St_bit As Bit
Dim Dummy As Byte
Dim Datas As Word
Dim Data_l As Byte At Datas Overlay
Dim Data_h As Byte At Datas + 1 Overlay
Dim Address As Long
Dim Addr_l As Byte At Address Overlay
Dim Addr_m As Byte At Address + 1 Overlay
Dim Addr_u As Byte At Address + 2 Overlay
Dim Addr_x As Byte At Address + 3 Overlay
Addr_x = 0
Dim A As Word
Dim B As Byte
' W25Q16 (2097151 bytes) = 16 Mbit
Print "Start ."
Print "read chip id"
Call Jedec_id()
Print Hex(read_data_tmp(1)) ; Hex(read_data_tmp(2)) ; Hex(read_data_tmp(3))
Print
Print "read Manufacturer Device Id "
Call Device_id()
Print Hex(read_data_tmp(4)) ; Hex(read_data_tmp(5)) ; Hex(read_data_tmp(6))
Print
'call Clear_mem()
'test for mem write data 256 bytes write
A = 0
Print "Write 255 bytes "
For Address = 0 To &HFF Step 2
Incr A
Data_h = Addr_m
Data_l = Addr_l
Call Write_data()
Print Hex(address) ; "h: " ; Hex(data_h) ; Hex(data_l)
Print "Writeing DONE "
Wait 5
Print "data dump: "
wait 1
For Address = 0 To &HFF Step 2 '8191
Call Read_data()
Print Hex(address) ; "h: " ; Hex(my_data(1)) ; Hex(my_data(2))
Print "Reading DONE "
' Manufacturing and Memory code reading
Sub Jedec_id()
Mem_p = &H9F
Reset Chip
Spiout Mem_p , 1
Spiin Read_data_tmp(1) , 3
Set Chip
'Call Stbit()
End Sub
Sub Device_id()
Mem_p = &H90
Reset Chip
Spiout Mem_p , 1
Spiin read_data_tmp(1) , 6
Set Chip
Call Stbit()
End Sub
' PARAMETER PAGE
Address = 0 'Long type variable!
Sent_p(1) = &H53 'read parameter page
Sent_p(2) = &H00 'address 3 byte
Sent_p(3) = &H00 '000000
Sent_p(4) = &H00
Reset Chip
Spiout Sent_p(1) , 4
Spiin read_data_tmp(1) , 3
Set Chip
Addr_u = read_data_tmp(1)
Addr_m = read_data_tmp(2)
Addr_l = read_data_tmp(3)
Print "CHIP ID: " ; Read_data_tmp(1) ; Read_data_tmp(2) ; Read_data_tmp(3)
' address Checking
'Parameter page deleted?
If Address = &HFFFFFF Then '16777215
Address = 0
Print "Flash: empty "
Wait 2
Goto Zero
'The memory is full? (Address = 1FFFFF)
If Address = &H1FFFFF Then '16777215
Print "Flash: full "
Address = Address + 2
Zero:
Call Clear_pp()
Sent_data(1) = &H52 'parameter page write
Sent_data(2) = &H00 'dummy
Sent_data(3) = &H00 'dummy
Sent_data(4) = &H00 'address
Sent_data(5) = Addr_u 'data1
Sent_data(6) = Addr_m 'data2
Sent_data(7) = Addr_l 'data3
Sent_data(8) = &H00 'data4 -> empty because of a couple of bytes to be!
Call Write_en()
Reset Chip
Spiout Sent_data(1) , 8
Set Chip
Call Stbit()
Cls
End Sub
' RAM read
Sub Read_data()
my_data(1) = 0
my_data(2) = 0
Mem_p = &H03
Sent_data(1) = Mem_p
Sent_data(2) = Addr_u
Sent_data(3) = Addr_m
Sent_data(4) = Addr_l
Reset Chip
Spiout Sent_data(1) , 4
Spiin my_data(1) , 2
Set Chip
Call Stbit()
End Sub
' RAM write
Sub Write_data()
Mem_p = &H02
my_data(1) = Mem_p
my_data(2) = Addr_u
my_data(3) = Addr_m
my_data(4) = Addr_l
my_data(5) = Data_h
my_data(6) = Data_l
Call Write_en()
Reset Chip
Spiout My_data(1) , 6
Set Chip
Call Write_dis()
Call Stbit()
End Sub
' Clear RAM
Sub Clear_mem() ' clear flash ram
Call Write_en()
Mem_p = &HC7
Reset Chip
Spiout Mem_p , 1
Set Chip
Call Stbit()
End Sub
' Clear PARAMETER PAGE
Sub Clear_pp() ' clear parameter page
Call Write_en()
Mem_p = &HD5
Reset Chip
Spiout Mem_p , 1
Set Chip
Call Stbit()
End Sub
' WRITE Disable - Enable
Sub Write_dis() ' write disable
Mem_p = &H04
Reset Chip
Spiout Mem_p , 1
Set Chip
End Sub
Sub Write_en() ' write enable
Mem_p = &H06
Reset Chip
Spiout Mem_p , 1
Set Chip
End Sub
' STATUS bit
' It will only be over when the memory of the transactions are finished!
Sub Stbit()
St_bit = 0
Kezd:
Mem_p = &H05
Reset Chip
Spiout Mem_p , 1
Spiin Dummy , 1
Set Chip
St_bit = Dummy.0
If St_bit = 0 Then Exit Sub
Goto Kezd
St_bit = 0
End Sub |
data via comport :
Quote: | [00]Start .
read chip id
EF4015
14EF14
Write 255 bytes
00000000h: 0000
000000FEh: 00FE
Writeing DONE
data dump:
00000000h: 0000
000000FAh: 00FA
000000FCh: 00FC
000000FEh: 00FE
_________________ / Kim |
allsetgo
Posted: Mon Feb 20, 2017 8:52 pm Post subject: |
Thanks Kim for your response.
Code: | 'SPI config
Spiinit
' I am using SS/ pin of Atmega164p i.e. PORTB.4 as CS/ for Flash. i.e. Noss =0 ; ( The NOSS parameter with a value of 1, will not set the SS line to logic 0 when the SPI operation begins.) |
I tried sending 3dummy bytes after ABh instruction although the datasheet of the flash I am using(S25FL164K) does not say that is reqd.
The MISO line is high all the time and the SPIIN reads FF. If I send on ABh and no dummy bytes, it is still high all the time.
Hardware connections:
ATMEGA164P (44pin)
MOSI (PORTB.5) to MOSI of flash
MISO (PORTB.6) to MISO of Flash
SCK ( PORTB.7) to SCLk of Flash
SS/(PORTB.4) to CS/ of Flash
Is there anything else I should look in to |
kimmi
Posted: Tue Feb 21, 2017 8:37 am Post subject: |
did you config PORTB.4 as output ?
and Set Portb.4 after config to output
Quote: | I tried sending 3dummy bytes after ABh instruction although the datasheet of the flash I am using(S25FL164K) does not say that is reqd. |
datasheet say it loud & clear page 78 see 8.5.2
Quote: | When Used Only To Obtain The Device Id While Not In The Deep Power -down State,
Sck With Most Significant Bit(msb) First. |
allsetgo
Posted: Tue Feb 21, 2017 4:19 pm Post subject: |
Thanks Kim
I am able to read the device ID now.
I made Noss=1 in Config SPI, and Used Set and Reset for PORTB.4 |
kimmi
Posted: Wed Feb 22, 2017 2:37 am Post subject: |
Good
pls post the working code you have
for other users with same issues _________________ / Kim |
