Xmega32 E5 DDS Sine Wave Signal Generator Example
JC
PostPosted: Tue Feb 14, 2017 10:04 pm    Post subject: Xmega32 E5 DDS Sine Wave Signal Generator Example Reply with quote
The following is a simple DDS Sine Wave Generator for the Xmega E5 series.
It is not a Direct Digital Synthesis tutorial, but if you are familiar with the concept it should make sense.
Basically one has a signal lookup table, (Sine, Square, Triangle, etc.), and runs an ISR at a fixed, fast, rate.
One calculates the next sample to output based upon the desired output frequency, table size, and DAC update rate.
This program is set up for a 62.5 kHz DDS ISR, (sample update rate).
The number of samples the output signal has is fixed at 62.5 k samples / Second.
A 1 Hz sine wave would have 62.5 K samples for one Period of the sine wave.
A 1 KHz sine wave would have 62.5 samples per one Period of the sine wave.
A 10 KHz sine wave would have 6.25 samples per one Period of the sine wave.
Know that even a simple first or second order Low Pass Filter will significantly clean up the output signal by removing the higher frequency components of the "stair-step" signal.
There is certainly room for improvement, but this demonstrates a working example of the concept.
JC
PostPosted: Tue Feb 14, 2017 10:12 pm    Post subject: Reply with quote
thanks for sharing Very Happy
