two stepper independent
krolikbest
PostPosted: Wed Feb 01, 2017 8:30 pm    Post subject: two stepper independent Reply with quote
Hello,
i would like to run two independent steppers and decided to use timer1 for 1-st stepper and timer2 for second stepper.
The code lokks like
$regfile = "m8adef.dat"
$crystal = 8000000
Config Timer1 = Timer, Prescale = 1, Compare_A = Disconnect, Clear_Timer = 1
Config Timer2 = Timer, Prescale = 1, Compare = Disconnect, Clear_Timer = 1
Config Twislave = &H20,Btr = 1,Bitrate = 100000,Gencall = 1
Dim temp1 as Integer, temp2 as Integer, fast as Integer, slow as Integer
Dim stan As Byte
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
Config Pinb.1 = Output 'stepper1
Config Pinb.3 = Output 'stepper2
stepper1 Alias Portb.1
stepper2 Alias Portb.3
On Compare1a run_stepper1
On compare2 run_stepper2
  enable timer2 ' ??? should it be
stan=10
fast=350
slow=600
 'slow down stepper1
 if stan=0 then
  stan=10
  for temp1=fast to slow step 10
   Compare1a=temp1
   waitus 200
  next temp1
  disable Compare1a
 end if
 'slow down stepper2
 if stan=3 then
  stan=10
  for temp2=fast to slow step 10
   Compare2=temp2
   waitus 200
  next temp2
  disable compare2
 end if
 'start stepper1
 if stan=1 then
  stan=10
  Enable Compare1a
  for temp1=slow to fast step -10
   Compare1a=temp1
   waitus 200
  next temp1
 end if
 'start stepper2
 if stan=4 then
  stan=10
  Enable compare2
  for temp2=slow to fast step -10
   Compare2=temp2
   waitus 200
  next temp2
 end if
Twi_stop_rstart_received:
Twi_addressed_goread:
Twi_addressed_gowrite:
Twi_gotdata:
  stan=twi
Twi_master_needs_byte:
 'Twi_btr
 Twi = stan
Twi_master_need_nomore_byte:
run_stepper1:
 Toggle stepper1
run_stepper2:
 Toggle stepper2
The problem is that for the 1-st stepper it works, but this code for the second stepper does not. Surely i did something wrong, but what should i change?
Previously i tested only timer1 for both steppers but UNsuccessful, because second stepper didn't rotate if the firs did. when first stopped second continued ...
Any help would be appreciated.
Martin
(BASCOM-AVR version : 2.0.7.6 , Latest : 2.0.7.8 )
PostPosted: Wed Feb 01, 2017 10:28 pm    Post subject: Reply with quote
TIMER2 like TIMER0 is also 8BIT and can count only to 255.
So it can`t handle your "slow=600" and even "fast=350" Very Happy
Answear to the question in code - "Enable Timer2" means "enable interrupt when Timer2 overflow"
If Clear_Timer=1 is used this will never happend Very Happy
krolikbest
PostPosted: Thu Feb 02, 2017 4:25 pm    Post subject: Reply with quote
Thank you! I've so many times checked where could bug(or bugs..) be that i didn't notice
that timer2 is 8bit! Now works fine!
<SOLVED>
