EEPROM 93C HELP
Goto page 1, 2, 3  Next
jeezywonder
PostPosted: Wed Feb 01, 2017 8:16 am    Post subject: EEPROM 93C HELP Reply with quote
hello hello , this time i'm in deep trouble i think.
Just started to work with EEPROM interface, i have 93C46, and as i understood to use "$EEPOM", "EEPROMWRITE" and etc, i need a $lib, which doesnt exist with 93C46.
I serached a forum and found this link from "grifo"
http://www.grifo.com/CORSO/uk_BASCOM_AVR/uk_Capitoli_AVR/uk_BASAVR_047.BAS
It coded for "93LC46A", i checked Datasheet of mine, and datasheet of 93LC46A, thos EEPROM's have the same WRITE and READ timing.
Therefore i started to explore this code. But due to the fact that im only around 3 week programming in BASCOM, some thngs looks inconceivable for me.
I will not copy past a full example here, because you can just check URL above. I have 16 bit memory model
 Do                                                        ' Begin endless loop
    Print                                                   ' Shows menu with available operations
    Print "R -> Read location"
    Print "W -> Writee location"
    Print "E -> Enable erase and write"
    Print "D -> Disable erase and write"
    Print "Perform the choice by pushing the associated key: ";
    Choice = Waitkey()                                      ' Wait selection of operation to execute
    Printbin Choice                                         ' Shows performed choice
    Print
    If Choice >= "a" Then                                   ' If choice is lower case
      Choice = Choice And &HDF                              ' Convert it in upper case
    Print                                                   ' Separate menu from following visualizations
    Select Case Choice                                      ' Check converted choice
      Case "R":                                             ' Selected operation is read EE location
        Input "Addrress of location to read (0..128): " , Addmw
        Call Read_mwee()                                    ' Read byte from Microwire EE
        Print "Read data= " ; Datmw
        Call Ask_key()                                      ' Ask and wait a key pressure on console to allow results reading
      Case "W":                                             ' Selected operation is write EE location
        Input "Addrress of location to write (0..128): " , Addmw
        Input "Data to write (0..255): " , Datmw
        Call Write_mwee()                                   ' Write byte on Microwire EE
        Print "Write performed."
      Case "E":                                             ' Selected operation is enable erase and write operations
        Call Enaew_mwee()                                   ' Enable erase and write operations on Microwire EE
        Print "Erase and write operations enabled."
      Case "D":                                             ' Selected operation is disable erase and write operations
        Call Disew_mwee()                                   ' Enable erase and write operations on Microwire EE
        Print "Erase and write operations disabled."
      Case Else:                                            ' Selected operation is not valid
        Printbin &H07                                       ' Generate an advise BEL on console
    End Select
  Loop                                                      ' End endless loop
After we declarated subroutines and variables, here we have a main code, I send "R", from my PC console , and get to the case "choice" where i should send from PC "Addrress of location to read (0..128): " I tried to send 1 in ASCII in byte and hex, no respons, it just duplicate my sendings. Here we got the first incomprehension.
Then i dont get what is
 Printbin &H07
do? We send received info in HEX data?
Sub Read_mwee()
  Pincs = 1                                                 ' CS signal at high level
  Call Com_mw(&H06 , Mwin , 3)                              ' Send 3 bits of READ command to Microwire EE
  Call Com_mw(addmw , Mwin , 7)                             ' Send 7 bits of address to Microwire EE
  Call Com_mw(&H00 , Mwin , 8)                              ' Get 8 bits of data to read from Microwire EE
  Datmw = Low(mwin)
  Pincs = 0                                                 ' CS signal at low level
End Sub
here we send 3 bits becouse we need " 1 1 0" on our "DI" port the makes our EEPROM "wakes up" and recieve adress.
But why then we send 7 bits of our address instead of 6?
Also, why we get 8 instead of 16? And also what "&H06", "&H00" do?
As you see have a lot of questions about this, thank you in further for your help. I will post a working code for sure later, because not only i who was looking for this.
jeezywonder
PostPosted: Thu Feb 02, 2017 3:13 am    Post subject: Reply with quote
due to inactivity of the forum, i tried to write my simplest code to read a byte from "000 000" memery cell, just to understand how EEPROM works,
pretty confident that its wrong, but i tried as i can, any help appreciate it, commented coments mean what im trying to do. I attached "the READ mode figure" to the post, I would very much appreciate if someone could spend some of his time explaining this to me thanks in advance.
The communication is performed through 4 different signals:
1) The first (/CS) enables the EEPROM.
2) Tthe second (CLK) supplies Timings and Synchronizations.
3) The third (DI) sends data to device.
4) The fourth signal (DO) acquires data from the device.
$regfile = "m8def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 8
$framesize = 24
$baud = 9600
Config Portc.0 = Output
Config Portc.1 = output
Config Portc.2 = output
Config Portc.3 = input
Clk Alias Portc.1            ' Output
Cs Alias Portc.0              ' Output
Di Alias Portc.2                ' Output
Do1 Alias Portc.3             ' Input
Dim A As Byte
Dim B As Byte
B = Inkey()                           ' waiting for command from console
If B <> 0 Then
Clk = 0
Waitms 10
Cs = 0
Waitms 10
Di = 0
Cs = 1                 ' Enables EEPROM
Waitms 10
Di = 1                  ' start bit, when Di = 1 and Cs = 1, and when di = 0(below)  from here our microwire knows that we want to read data.
Waitms 10
Cs = 1
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Di = 0              'here
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
'===========Adress==========
Clk = 1                              '  read a address from "0" memory cell
Waitms 10
Clk = 0                               '  6 bits to make EEPOM realize the adress
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10     ' here we output the data through DO
Clk = 1         '   16 bits
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
Clk = 0
Waitms 10
Clk = 1
Waitms 10
Clk = 0
Waitms 10
 Print Do1                                         ' Print data from "0" memort cell
jeezywonder
PostPosted: Thu Feb 02, 2017 6:16 am    Post subject: Reply with quote
I checked my Chip Serial, Serial Clock, Data in and Data out with Oscilloscope.
I receive data from PC and send data to pc, but i always get 0 value. Seems like my "d01" didnt memirize the values and just ouput the last one which equals 0
jeezywonder
PostPosted: Thu Feb 02, 2017 7:55 am    Post subject: Reply with quote
I'm confused with how we read a data from memory cell, for example:
I have port "DO"( data out) on my EEPROM, then config our EPROM "data out" port for input:
Then make a variable
Then due to the fact that ports can't store any data, i make an another varibale witch equals "DO" :
Dim z as Byte
Z = Do1
Therefore Z storing a 1 byte now.
But how this "Z" variable reads the data from EEPROM address? Becouse after our DI and CLK equal 1
EEPROM gets ready and it waitinig for address, which we indicate with DI = 0, then we toggle a Clock Serial to make EERPOM read the full 8 bit adress, it how i understand it
kimmi
Moderator
PostPosted: Thu Feb 02, 2017 12:52 pm    Post subject: Reply with quote
Hi
Wy dont you just use shiftout / shiftin
93c46 is 1K: 128 x 8 or 64 x 16
for 8bit read/write :
so for read shiftout 9 bits Instruction (read 3 bits 110) (address 6 bits) read + address ,9
and shiftin 8 bits
reset cs pin 50ms before you start
msb first
CS = 1
shiftout xxxxxxxxxxxxxxx
Shiftin xxxxxxxxxxxxxxxx
cs = 0
read help about shiftout/in
/ Kim
View user's profile Visit poster's website MSN Messenger
Bufalo
PostPosted: Thu Feb 02, 2017 2:39 pm    Post subject: Reply with quote
Tried to use EEPROM too, but didnt get it too
jeezywonder
PostPosted: Thu Feb 02, 2017 2:41 pm    Post subject: Reply with quote
Kimmi much thanks, its more clear now
But Honestly, its hard to visualize and without practice its harder, i have 64 x 16
And i still dont get where and how do we put our adress, for get access to ZERO memory cell, sorry for that
I tried to wrote some sample:
dim clock as byte, sinp as byte, cs as byte
dim Intr as Integer                                        ' cuz have we 16 bit type of EEPROM
clock Alias Portc.1
Output Alias Portc.2
sinp Alias Pinc.3
 '*******Main************
Waitms 50
Cs = 1
Shiftout Output , Clock , Intr , 1 , 9   ' puted one because MSB first,clock high due to datasheet as i understand
Shiftin Sinp , Clock , Intr , 1 , 9
Cs = 0
Print sinp
kimmi
Moderator
PostPosted: Thu Feb 02, 2017 3:52 pm    Post subject: Reply with quote
here is a test setup
!!!did not test it on real hardware !!!
but maby you can use some of it and read the datasheet !
'$sim
http://www.atmel.com/Images/doc5140.pdf
AT93C46  1K: 128 x 8 or 64 x 16
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 32
$swstack = 32
$framesize = 32
'$baud = 9600
Cs Alias Portd.2
Config Portd.2 = Output
Pin_out Alias Portd.3
Config Portd.3 = Output
Pin_in Alias Pind.4
Config Pind.3 = Input
Sck Alias Portd.5
Config Portd.5 = Output
Declare Sub Read_data_93c46(byval A As Byte , Byval B As Byte)
Declare Sub Write_data_93c46(byval A As Byte , Byval B As Byte)
Declare Sub Setup_93c46()
Dim R_data(128) As Byte                                     '  1K: 128 x 8bit
Dim W_data(128) As Byte                                     '  1K: 128 x 8bit
Dim Count As Byte , A As Byte , B As Byte
Dim My_93c46 As Word
Dim Adr_93c46 As Byte At My_93c46 Overlay
Dim R_w As Byte At My_93c46 + 1 Overlay
Dim R_93c46 As Byte
R_93c46 = &B00000110
Dim W_93c46 As Byte
W_93c46 = &B00000101
Dim Read_enable As Byte
Read_enable = &B00010011
Cs = 0
Call Setup_93c46()                                          ' Enable serial EEPROM    (EWEN):
Waitms 50
For Count = 1 To 128                                        '  1K: 128 x 8
   W_data(count) = Count
'sent
   Call Write_data_93c46(w_93c46 , Count)
   Waitms 10
'read
Call Read_data_93c46(r_93c46 , Count)
Waitms 10
Wait 5
  R_w = A
  Adr_93c46 = B
'read from eeprom             3+6       '&B110+address   9 bits
   CS = 1
   Shiftout Pin_out , Sck , My_93c46 , 1 , 9 , 40
   Shiftin Pin_in , Sck , R_data(adr_93c46) , 1 , 8 , 40
   Cs = 0
   Waitms 10
End Sub
Sub Write_data_93c46(byval A As Byte , Byval B As Byte )
   R_w = A
  Adr_93c46 = B
' write address and data
   Cs = 1
   Shiftout Pin_out , Sck , My_93c46 , 1 , 9 , 40           ' Send address and data
   Cs = 0
   Waitms 10
End Sub
Sub Setup_93c46()
   Cs = 1
   Shiftout Pin_out , Sck , Read_enable , 1 , 5 , 40        ' Send write enable command
   Cs = 0
   Waitms 10
End Sub
/ Kim
jeezywonder
PostPosted: Fri Feb 03, 2017 3:52 am    Post subject: Reply with quote
I tried it, but to check it i have to know which variable i should to PRINT out?
jeezywonder
PostPosted: Fri Feb 03, 2017 10:47 am    Post subject: Reply with quote
Ok, after i killed a whole day to finally understand, that shifting procedure, much thanks to you kimmi, and your posted code, i did step by step.
If you can see on a code below, somehow a had to put "2 LSB shifted in first when clock goes low" option instead of 1. After that i get my vale on the console.
it was 8080(HEX).
$crystal = 8000000
$hwstack = 32
$swstack = 8
$framesize = 24
$baud = 9600
Cs Alias Portc.0
Pin_out Alias Pinc.3
Config Portc.3 = Input
Pin_in Alias Portc.2
Config Portc.2 = Output
Sck Alias Portc.1
Config Portc.1 = Output
Dim Send_adress As Word
'Send_adress = &B000000011
Dim Read_enable As Word
Read_enable = &B0000011
Declare Sub Setup()
Dim Count As Byte
'******** Main Programm ***********
Cs = 0                                                      '
Call Setup()
Waitms 50
For Count = 1 To 64
Cs = 1
Shiftout Pin_in , Sck , Read_enable , 2 , 9            ' Here 2 istead of 1, wonder why due to data shit it should be 1
Shiftin Pin_out , Sck , Send_adress , 1 , 16
Cs = 0
Waitms 150
Print Send_adress
'*************Sub*****************
Sub Setup()                                                 '
Cs = 1
Shiftout Pin_out , Sck , Read_enable , 1 , 1 , 40           ' Read_enable = &B0000011
Cs = 0
Waitms 10
End Sub
Much tanks to kimmi again,
next step is to write a "for - next" loop, which should read datas from all memory cell, as i have 64x16 chip, that i need to read 64.
I tried by my own forces, but it doesnt work, seems to "subs+for loops + OVERLAY as" can help, due to your example, kimmi.
Here is the code. Whats im missing? Any tips? PS: Again i will share my code after i done
$crystal = 8000000
$hwstack = 32
$swstack = 8
$framesize = 24
$baud = 9600
Cs Alias Portc.0
Sck Alias Portc.1
Declare Sub Setup()
Dim Count As Byte
Dim R_data(64) As Byte
Dim Adr_93c46 As Byte At Send_adress Overlay                ' Overlay( Anr_93c46 into My_9c46)
Dim R_w As Byte At Send_adress + 1 Overlay
 Dim R_93c46 As Byte
Cs = 0                                                      '
Call Setup()
Waitms 50
For Count = 1 To 64
Call Read_data_93c46(r_93c46 , Count )
Sub Read_data_93c46(byval A As Byte Byval B As Byte)
R_w = A                                                     ' R_w(As Byte At My_93c46 + 1 Overlay) = A(
Adr_93c46 = B
Cs = 0
Waitms 150
End Sub
Sub Setup()                                                 '
Cs = 1
Shiftout Pin_out , Sck , Read_enable , 1 , 1 , 40           ' Read_enable = &B00000011
Cs = 0
Waitms 10
End Sub
kimmi
Moderator
PostPosted: Fri Feb 03, 2017 12:39 pm    Post subject: Reply with quote
here is a test for 64x16
And i made wrong setup in overlay
be cause of the 3+6 for w/r + address and forgot to add data sent
here is a test new with VAR long and shift data to long
' 64 x 16 bit sent      r/w  addr    data 16 bit
W addr + data : 0000000 101 000000 xxxxxxxxxxxxxxxx
' 64 x 16 bit read                     r/w  addr    data 16 bit
R addr + data: 00000000000000000000000 110 000000 xxxxxxxxxxxxxxxx
read data will be 4000 + count_x
4000 to 4063
$crystal = 8000000
$hwstack = 32
$swstack = 32
$framesize = 32
$baud = 9600
Cs Alias Portc.0
Sck Alias Portc.1
Declare Sub Read_data_93c46()
Declare Sub Write_data_93c46()
Dim R_data(64) As Word                                      '  1K: 64x16bit
Dim Count As Byte , Count_x As Byte
Dim My_data As Word
Dim My_93c46 As Long
Dim R_93c46 As Byte
Dim W_93c46 As Byte
Read_enable = &B100110000                                   '64x16
Cs = 0
Call Setup_93c46()
Waitms 50
   For Count = 1 To 64                              '  1K: 64*16
     Count_x = Count - 1
     'setup sent data
      My_93c46 = W_93c46
      Shift My_93c46 , Left , 6
      My_93c46 = My_93c46 + Count_x
      Shift My_93c46 , Left , 16
      My_data = 4000 + Count_x
      My_93c46 = My_93c46 + My_data                         ' as word
'sent
      Call Write_data_93c46()
      Waitms 4
      Print "W addr + data : " ; Bin(my_93c46)              '  1K: 64*16
      'W addr + data : 101 000001 (xxxxxxxxxxxxxxxx) is data sent
      'setup read data
      My_93c46 = R_93c46
'read
      Call Read_data_93c46()
      Print "R addr + data: " ; Bin(my_93c46) ; Bin(r_data(count))
     ' R addr + data: 011 0000001 (xxxxxxxxxxxxxxxx) is data read
      Waitms 4
   Wait 5
   CS = 1
' read data 2 bytes
   Shiftin Pin_in , Sck , R_data(count) , 1 , 16 , 40
   Cs = 0
   Waitms 10
End Sub
' write address and data 2 bytes
   Cs = 1
   Shiftout Pin_out , Sck , My_93c46 , 1 , 25 , 40          ' Send address and data
   Cs = 0
   Waitms 10
End Sub
Sub Setup_93c46()
' Enable serial EEPROM   1 byte
   Cs = 1
   Shiftout Pin_out , Sck , Read_enable , 1 , 9 , 40         ' Send write enable command
   Cs = 0
   Waitms 10
End Sub
/ Kim
PostPosted: Fri Feb 03, 2017 8:42 pm    Post subject: Reply with quote
9 bit-bytes?
As My_93c46 is a 32 bit signed integer, the code as shown shifts out My_93c46's bit 31 to 24:
I can't notice anywhere in the code how useful payload, opcode & address, gets into these positions after all.
kimmi
Moderator
PostPosted: Fri Feb 03, 2017 9:30 pm    Post subject: Reply with quote
Tnx MWS
MSB first right ! so shift all to left
Read_enable = &B1001100000000000
   For Count = 1 To 64                                      '128 Step 2                              '  1K: 64*16
     Count_x = Count - 1
     'setup sent data
      My_93c46 = W_93c46
      Shift My_93c46 , Left , 7
      ' Shiftout Pin_out , Sck , My_93c46 , 1 , 25 , 40
'sent
      Waitms 4
      'setup read data
      My_93c46 = R_93c46
      Shift My_93c46 , Left , 23
      '   Shiftout Pin_out , Sck , My_93c46 , 1 , 9 , 40
      ' Shiftin Pin_in , Sck , R_data(count) , 1 , 16 , 40
'read
      Waitms 4
   Wait 5
/ Kim
Bufalo
PostPosted: Mon Feb 06, 2017 5:52 am    Post subject: Reply with quote
Any news about posted code? does it work? JeezWonder?
jeezywonder
PostPosted: Mon Feb 06, 2017 10:04 am    Post subject: Reply with quote
Ok, sorry for late reply, i tested a code that KIMMI gave me with MWS corrections.
I post whole code firstly
$crystal = 8000000
$hwstack = 32
$swstack = 32
$framesize = 32
$baud = 9600
Cs Alias Portc.0
Sck Alias Portc.1
Dim My_data As Word
Dim R_93c46 As Byte
Dim W_93c46 As Byte
Read_enable = &B1001100000000000                                  '64x16
Cs = 0
Call Setup_93c46()
Waitms 50
     Count_x = Count - 1
     'setup sent data
      My_93c46 = W_93c46
'sent
      Waitms 4
      'setup read data
      My_93c46 = R_93c46
'read
      Waitms 4
   Wait 5
   CS = 1
' read data 2 bytes
   Cs = 0
   Waitms 10
End Sub
   Cs = 1
   Cs = 0
   Waitms 10
End Sub
Sub Setup_93c46()
   Cs = 1
   Cs = 0
   Waitms 10
End Sub
Want to admit that , as im new at bascom it was confusing to get into the code.
First of all, i tried to run a code without any changes, and i got a error during a compile, which was saying that:
does not fit into "Byte" because ,
contains 9 bit instead of 8, therefore i chaned Byte to Word. After compline i had a lof of numbers, there are confused me as hell. I attached the image named "The Code without changes".
The next step i did is to deal with "read data" function, i commented a "write data" part, and tried to compile(see the attached image "read data only"), after that i was puzzled why there are so many numbers, noticed that
"My_93c46" adds to "r_data(count))".
And i tried to separate them like this:
as i got it My_93c46 applies to EEPROM address, becouse when i compile it i get this( see the image " My93c46")
and what i get when tried to compile only "Bin(r_data(count))" - as i got its data that we read from EEPROM, what i get( again see the picture called "Data Read"
As we can see, i didnt get any data, while the code reads address. Any guesses why it doenst work?
Also i have a qestiuons about a code.
What does "4000" applies for? why 4000?
Why do we need to get our EEPROM ready with the codes that the same, as i got "110" its start bit + OP codes, and why in "&B1001100000000000" we needs "1" after "B"
Thank you guys for yout help, you make me better at BASCOM, the world would be better if it has more people like you Smile
Page 1 of 3
