Mega2560 R3 with ILI9341-TFT in 16-bit?
Kasch
PostPosted: Sat Jan 28, 2017 4:20 pm    Post subject: Mega2560 R3 with ILI9341-TFT in 16-bit? Reply with quote
Hi, I would like to use a Mega2560 R3 Bord with shield and an 3,2 ILI9341-Display in 16bit. I have found the ILI9341-Libary from http://mat.midlight.eu/index.php/ILI9341_Library, but I can not change the port for parallel-versions-port, because only one port is possible.
But according to the datasheet of the mega2560 R3 are G.0 G.1 G.2 and D.7 connected with Reset, RW, CS and WR....what can I do? Thank you
bzijlstra
Bascom Ambassador
PostPosted: Sun Jan 29, 2017 1:39 pm    Post subject: Search... Reply with quote
Start with a search in this forum. Plons did some work on SPI / 8-bit / 16 bit on ILI9341 displays.
Have fun
Ben Zijlstra
m_herr
PostPosted: Mon Jan 30, 2017 9:49 pm    Post subject: Reply with quote
i have searched and found nothing from mega2560 AND ili9341...and from Ili9341 only spi-version in 2,2"
what you mean with your last sentence? clons don't work complete nothing?
bzijlstra
Bascom Ambassador
PostPosted: Tue Jan 31, 2017 12:46 am    Post subject: Atmega2560 8-bit parallel Reply with quote
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12893&postdays=0&postorder=asc&highlight=ili9341&start=0
Atmega2560 8-bit parallel with pictures
m_herr
PostPosted: Tue Jan 31, 2017 7:55 pm    Post subject: Reply with quote
did you read my sentence? you quote my link, which I used and which the reason for THIS thread is...
bzijlstra
Bascom Ambassador
PostPosted: Tue Jan 31, 2017 10:02 pm    Post subject: Answer for the initial question.... Reply with quote
Have tried to answer the question of Kasch, the member that asked the initial question.
Have fun
Ben Zijlstra
m_herr
PostPosted: Tue Jan 31, 2017 11:12 pm    Post subject: Reply with quote
no, you don't....he explaind his problem with software of a link..and you send the same link as answere..you have not read the question of threadstarter..pleas3 be carefully on your answere..have fun
bzijlstra
Bascom Ambassador
PostPosted: Wed Feb 01, 2017 1:14 am    Post subject: Wrong link... Reply with quote
This is the link of the first item in this tread
Because of the comma I get a page without any contents.
After removing the comma I get indeed a very nice page with lots of information.
And you are right with a link to the page I have put in a answer.
So my 'fault'... or a wrong link. Solved. Good luck with your 'problem'.
Have fun
Ben Zijlstra
m_herr
PostPosted: Wed Feb 01, 2017 9:08 am    Post subject: Reply with quote
i repeat..again....you postet sincless the link which created the question of this thread...you can not post a solution-link which is the same link which just created the problem...nothing is solved..only you has not read the Main-question..again....good luck next time during reading and understanding...
PostPosted: Sat Feb 04, 2017 1:25 pm    Post subject: Reply with quote
Crying or Very sad
Once again! Before embarking on the purchase of equipment.
You should know if you have the skill to use it or if other users have already share their experiences.
The choice of display is very large here : http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13074
JP
PostPosted: Sat Feb 04, 2017 2:04 pm    Post subject: Reply with quote
That is indeed a great library. I do not understand what you mean with that only one port is possible?
The 16 bit mode needs just 3 ports : 2 for the 16 bit data, and 1 port for control. you can freely chose the pins.
The consts to define are explained on the page.
