Timer Counter Question
Goto page Previous  1, 2
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions
PostPosted: Fri Jul 28, 2017 11:11 pm    Post subject: Reply with quote
In my country we have a say "Rome was not build at once" Wink
Try understand how counters/timers can be configured to count/measure freq before you say ARM Wink
$regfile = "m8def.dat"
'CONNECT SIGNAL INTO THE PORTD.4 (T0 INPUT)
$Crystal=8000000
$hwstack=64
$swstack=32
$framesize=128
Config Timer0 = Counter , Edge = Rising                'no prescale
Enable Timer0                                          'enable counting 256 overflow
On Timer0 Timer0_isr                                   'when Time rich 256 jump Interrupt will be fired
Enable Timer0                                          'allow this interrupt
'now we need 1second timer
Config Timer1 = Timer , Prescale = 256 , Compare_a = Disconnect , Compare_b = Disconnect , Clear_timer = 1
 Compare1a = 31249                                     '1000ms @8MHz/256  =1s
Enable Compare1a : On Compare1a Timer1_isr
Dim Overflows As Byte , Copy_overflows As Byte , Copy_of_timer As Byte
Dim Its_time As Byte , Helpd As Dword
 If Its_time = 1 Then
  Helpd = Copy_overflows
   Shift Helpd , Left , 8                              'multiply overflows by 256x times quicly
  Helpd = Helpd + Copy_of_timer                        'add rest of pulses
  Print "Freq=" ; Helpd ; "Hz"
 Its_time = 0
Timer0_isr:                                            'timer count 256/overflow
 Incr Overflows                                        'count 256`s
Timer1_isr:                                            'every second
Copy_of_timer = Timer0
 Copy_overflows = Overflows
  Overflows = 0
    Its_time = 1
Goorman
PostPosted: Sat Jul 29, 2017 7:58 pm    Post subject: Reply with quote
Hi EDC
ARM is just a wish. Very Happy
A good way to measure, but I think with this method I will lose PWMs, isn’t it?
Thanks for your code.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions All times are GMT + 1 Hour
Page 2 of 2
