Printpix52
Posted: Sat Jan 07, 2017 4:24 am Post subject: ADC_PWM @ 16khz |
Hello everyone!
I made a buck converter circuit it takes an input voltage of C.C. And reduces it in an amount controllable with the switch action of the mosfet channel PWM 16Khz.
The code that works very well but I want to replace with an ADC potentiometer as I do?
Code: | $regfile = "m8adef.dat"
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
'-----------------------[Timer1 Configuration]
Config Timer1 = Pwm , Prescale = 1 , Compare_a_pwm = Clear_down , Compare_b_pwm = Clear_up
'WGM10 WGM11 WGM12 WGM13
Tccr1a.0 = 1 : Tccr1a.1 = 0 : Tccr1b.3 = 1 : Tccr1b.4 = 0 'Phase Correct PWM / 08-bit
'Tccr1a.0 = 0 : Tccr1a.1 = 1 : Tccr1b.3 = 0 : Tccr1b.4 = 0 'Phase Correct PWM / 09-bit
'Tccr1a.0 = 1 : Tccr1a.1 = 1 : Tccr1b.3 = 0 : Tccr1b.4 = 0 'Phase Correct PWM / 10-bit
'-----------------------[LCD Configuration]
Config Lcd = 16 * 2
Config Lcdbus = 4
Config Lcdpin = Pin , E = Portc.1 , Rs = Portc.0
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3
Config Lcdpin = Pin , Db6 = Portc.4 , Db7 = Portc.5
'-----------------------[GPIO Configuration]
Config Pind.2 = Input : Incr_key Alias Pind.2 : Portd.2 = 1
Config Pind.3 = Input : Decr_key Alias Pind.3 : Portd.3 = 1
'-----------------------[Single Configuration]
Config Single = Scientific , Digits = 2
Dim Duty_cycle As Single , Vout As Single
'--->[Main Program]
Cursor Off :
Ocr1a = 0 : Gosub Calculation
If Incr_key = 0 Then
If Ocr1a < 255 Then Incr Ocr1a '511 | 1023
Gosub Calculation
If Decr_key = 0 Then
If Ocr1a > 0 Then Decr Ocr1a
Gosub Calculation
'---<[End Main]
'--->[Sub-routine]
' Duty: 0 ~ 255 [0 = 0% / 255 = 100%]
Calculation:
Duty_cycle = Ocr1a / 255 : Duty_cycle = Duty_cycle * 100 '511 | 1023
Locate 1 , 1 : Lcd "Duty = " ; Duty_cycle ; " % "
Vout = Duty_cycle * 5 : Vout = Vout / 100
Locate 2 , 1 : Lcd "Vout = " ; Vout ; " V "
(BASCOM-AVR version : 2.0.7.5 , Latest : 2.0.7.8 ) |
Posted: Sat Jan 07, 2017 1:10 pm Post subject: |
Hello.
You must know that in Mega8 ADC is on PORTC pins so LCD take them all in your design
I decide reconect RS and EN pins of LCD to pins where switches was connected before but you can do whatever you like exept that you must have acces into one of ADC input pin.
Rest of code is simple. Shift 2 divide ADC value to fit it into 8Bit.
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
Config Lcd = 16 * 2
Config Lcdbus = 4
Config Lcdpin = Pin , E = Portd.2 , Rs = Portd.3 'unused switches used here
'-----------------------[ADC Configuration]
Dim Adc_read As Word , Old_read As Word
'-----------------------[Variables]
'--->[Main Program]
Cursor Off :
Adc_read = Getadc(0)
Shift Adc_read , Right , 2 'divide/4 so 1023 become 254
If Old_read <> Adc_read Then 'only if potentiometer was moved
Old_read = Adc_read
Ocr1a = Adc_read
Gosub Calculation 'LCD will be updated only if value was changed
'---<[End Main]
'--->[Sub-routine]
Calculation:
Duty_cycle = Adc_read / 255 : Duty_cycle = Duty_cycle * 100 '511 | 1023
Printpix52
Posted: Sat Jan 07, 2017 9:34 pm Post subject: |
EDC Thank you very much !! |
