Newbie question about multiplication and data types
Yokablasta
PostPosted: Wed Dec 13, 2017 10:07 pm    Post subject: Newbie question about multiplication and data types Reply with quote
I am a hardware engineer that's somewhat new to BASCOM. I have been working on a sensor project that calculates the center of mass of an object by using 16 force sensors. I am using the 10-bit ADC on an ATMEGA48P to scan 16 force sensors and record the readings in an array. The data type of the ADC readings is a word. That part of my program works fine. I run into issues when I try to multiply those readings by a scaling factor. I keep getting an assignment error, which I believe is due to me not using the correct data types. I'm having some difficulty finding a clear source of info about how to multiply and divide in Bascom AVR. If I have a 10-bit ADC reading, and I want to multiply it by something like .10, what data type should the result be? What data type should the .01 be? Any pointers would be appreciated.
-Y
PostPosted: Wed Dec 13, 2017 10:20 pm    Post subject: Reply with quote
the data types should be equal. if you really need floating point math, you need to use a single or a double.
but your data is in a word. is the a/d converter 1024 maximum?
If you want to multiply by 0.1 it is the same as dividing by 10
so it is best to keep everything in a word when the value fits, and otherwise a long or dword.
dim ar(10) as word
dim scale as word
scale=10
ar(1)=ar(1) / scale
this will multiply by .1
Yokablasta
PostPosted: Wed Dec 13, 2017 10:30 pm    Post subject: Reply with quote
Thanks Mark,
That makes sense. Let me give this a try. Hopefully that approach will give me the result I need. Thanks!
-Y
