Some idea to make one file libs with labels and data
PostPosted: Tue Aug 16, 2016 2:24 pm    Post subject: Some idea to make one file libs with labels and data Reply with quote
I do not know which one of sections (Share code or this Arduino) forum will be better to show my Idea.
I like Arduino method to include one file at the beginning of main code.
In Bascom writing own library for some devices was not so easy because when you need some LABELS or DATA to be stored
then you must include them after END statement.
Yesterday bring me one idea.
Config Submode = New is a great future because you don`t need to declare subs and also unused subs are not compiled.
But Config Submode Help says one more thing. "Subs will be placed at the program end after END statement automatically"
I test Idea where LABEL and DATA statement is enclosed in dummy sub, then I force BASCOM compiler to attach this sub.
And gues what? Everything works exellent Very Happy
So for now I can add anything I want into INCL/LIB file even initialisations bytes for some devices or whatever. In one single file at the main code begining.
I attach simple code for PCF8583 where Labels Getdatetime, Setdatetime and Data must be attached if you want to use this chip with bullit in Bascom routines
$Time &Date etc.
I think this will be helpfull or maybe Mark add some future that will allow adding something after END statement
$regfile = "m32adef.dat"
$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 64
' I2C config
$lib "i2c_twi.lbx"
Config Scl = Portc.0
Config Sda = Portc.1
I2cinit
Config Twi = 100000
Const Language = 0
 $include "pcf8583.inc"
'-[SELECT LANGUAGE]-
'0 = PL
'1 = EN
'2 = DE
Config Lcdpin = Pin , Db4 = Porta.3 , Db5 = Porta.4 , Db6 = Porta.5 , Db7 = Porta.6 , E = Porta.2 , Rs = Porta.0 , Wr = Porta.1
Config Lcd = 20x4
Cursor Off , Noblink
#if Language = 0                                            'Polish
    Deflcdchar 1 , 12 , 4 , 4 , 6 , 12 , 4 , 14 , 32           ' ł
    Deflcdchar 2 , 2 , 4 , 14 , 16 , 16 , 17 , 14 , 32         ' ć
    Deflcdchar 3 , 2 , 4 , 14 , 16 , 14 , 1 , 30 , 32          ' ś
    Deflcdchar 4 , 32 , 32 , 14 , 1 , 15 , 17 , 15 , 1         ' ą
    Deflcdchar 5 , 32 , 32 , 14 , 17 , 31 , 16 , 14 , 1        ' ę
    Deflcdchar 6 , 2 , 4 , 14 , 17 , 17 , 17 , 14 , 32      ' ó
#endif
Cls
Config Porta.7 = Output : Led Alias Porta.7
Dim Lang As Byte , Day_nr As Byte , Day_str As String * 15
Dim Name_end_pos As Byte , Name_start_pos As Byte
Name_start_pos = 1
Lang = Language
   Locate 1 , 1 : Lcd Time$                                 'odczytuje czas - uzywac co jakiś czas a nie wkółko w petli
    Locate 1 , 11 : Lcd Date$
       Day_nr = Dayofweek()
       Select Case Lang
        Case 0
          Day_str = Lookupstr(day_nr , Dni_tygodnia)
        Case 1
          Day_str = Lookupstr(day_nr , Weekdays)
        Case 2
          Day_str = Lookupstr(day_nr , Dni_de)
       End Select
         'Locate 2 , Name_end_pos : Lcd Spc(5)
         Locate 2 , Name_start_pos : Lcd Day_str
    Waitms 500
    Toggle Led
pcf8583.incl
'*      INTEGRATING PCF8583 WITH $TIME and $DATE         *
'*      18.01.2016 BARTek niveasoft(at)tlen.pl           *
'* DECLARATION FILE SHOULD BE INCLUDED AFTER I2C CONFIG  *
'*      $include "pcf8583.inc"                *
'*      Dim ....                                         *
'*      Do                                               *
'*      Loop                                             *
'*      End                                              *
$nocompile
Config Clock = User
Config Date = Dmy , Separator = /
' adresy układu PCF8583
' jeżeli noga A0 układ PCF8583 jest podłączony do GND to:
' adres do odczytu = &HA1
' adres do zapisu = &HA0
' jeżeli noga A0 układ PCF8583 jest podłączony do VCC to:
' adres do odczytu = &HA3
' adres do zapisu = = &HA2
'Const Pcf8583w = &HA0                                       'PCF address for write
'Const Pcf8583r = &HA1                                       'PCF address for read
Const Pcf8583w = &HA2                                       'PCF address for write
Const Pcf8583r = &HA3                                       'PCF address for read
Dim Rtc_year_date As Byte , Rtc_weekdays_months As Byte , Temp_b As Byte
Dim Pcf8583_kalendarz_baza As Byte , Pcf8583_year_old As Byte
Sub Store_year
 I2cstart
  I2cwbyte Pcf8583w
  I2cwbyte 16
  I2cwbyte Pcf8583_kalendarz_baza
End Sub
Sub Read_year
 I2cstart
  I2cwbyte Pcf8583w
  I2cwbyte 16
  I2crbyte Pcf8583_kalendarz_baza , Nack
 I2cstop
End Sub
Sub Dummy_sub
   Getdatetime:
   'called when date or time is read
     I2cstart
     If Err = 0 Then
       I2cwbyte Pcf8583w
       If Err = 0 Then
         I2cwbyte 2
         If Err = 0 Then
           I2cstart
           If Err = 0 Then
            I2cwbyte Pcf8583r
            I2crbyte _sec , Ack                                'sec
            I2crbyte _min , Ack                                'min
            I2crbyte _hour , Ack                               'hour
            I2crbyte Rtc_year_date , Ack                       'date
            I2crbyte Rtc_weekdays_months , Nack                'date
            _sec = Makedec(_sec) : _min = Makedec(_min) : _hour = Makedec(_hour)
            Temp_b = Rtc_year_date                             ' rok
             Shift Temp_b , Right , 6
             Temp_b = Makedec(temp_b)
             _year = Pcf8583_kalendarz_baza + Temp_b           '  baza + wartość kalendarza czteroletniego
               If Pcf8583_year_old <> Temp_b Then              ' je&#380;eli zmieni&#322; si&#281; rok
                  If Temp_b = 0 And Pcf8583_year_old = 3 Then  ' je&#380;eli sko&#324;czy&#322; si&#281; kalendarz czteroletni
                     Pcf8583_kalendarz_baza = Pcf8583_kalendarz_baza + 4       ' zmie&#324; baz&#281; kalendarza
                   Pcf8583_year_old = Temp_b                   'dopiero tu mo&#380;e dosta&#263; nowa warto&#347;&#263;
                  'zapisz dane o aktualnym roku w uk&#322;adzie PCF8583
                    Call Store_year
               Temp_b = Rtc_year_date And &B0011_1111          ' dzie&#324;
               _day = Makedec(temp_b)
               Temp_b = Rtc_weekdays_months And &B0001_1111    ' miesi&#261;c
               _month = Makedec(temp_b)
      I2cstop
   Setdate:
      Rtc_year_date = Makebcd(_day)                            'w bajcie zapisz dzie&#324; w kodzie BCD
      Temp_b = _year Mod 4
      Temp_b = Makebcd(temp_b)
      Pcf8583_year_old = Temp_b                                'zapamietaj bo przyda sie kiedy rok w PCF si&#281; zmieni
      Pcf8583_kalendarz_baza = _year - Temp_b
      Shift Temp_b , Left , 6
      Rtc_year_date = Rtc_year_date Or Temp_b
      Rtc_weekdays_months = Makebcd(_month)                    ' dzie&#324; tygodnia i miesi&#261;c
      Temp_b = Dayofweek()
      Shift Temp_b , Left , 5
      Rtc_weekdays_months = Rtc_weekdays_months Or Temp_b
     I2cstart
      I2cwbyte Pcf8583w
      I2cwbyte 5
      I2cwbyte Rtc_year_date
      I2cwbyte Rtc_weekdays_months
      Call Store_year
     I2cstop
   Settime:
      _sec = Makebcd(_sec) : _min = Makebcd(_min) : _hour = Makebcd(_hour)
     I2cstart                                                  '
      I2cwbyte Pcf8583w
      I2cwbyte 2
      I2cwbyte _sec
      I2cwbyte _min                                            '
      I2cwbyte _hour
     I2cstop
   Dni_tygodnia:
   Data "Poniedzia{001}ek" , "Wtorek" , "Sroda" , "Czwartek" , "Pi{004}tek" , "Sobota" , "Niedziela"
   Weekdays:
   Data "Monday" , "Tuesday" , "Wednesday" , "Thursday" , "Friday" , "Saturday" , "Sunday"
   Dni_de:
   Data "Montag" , "Dienstag" , "Mittwoch" , "Donnerstag" , "Freitag" , "Samstag" , "Sonntag"
End Sub
Dim Dummy As Byte
'## THIS IS NEVER CALLED BUT FORCE BASCOM TO INCLUDE THIS SUBS ##
'## AND THEY WILL BE PLACED AT THE PROGRAM END AUTOMATICALLY   ##
If Dummy = 1 Then
 Call Dummy_sub
bzijlstra
Bascom Ambassador
PostPosted: Tue Aug 16, 2016 3:48 pm    Post subject: Nice work Reply with quote
config submode = new is real strong!!!
Nice work
Ben Zijlstra
PostPosted: Tue Aug 16, 2016 5:48 pm    Post subject: Reply with quote
Yes. One can look at this sample. Even interrupt service routine can be declared/added to code at the beginning Smile
$regfile = "m328pdef.dat"
$crystal = 11059200
$hwstack = 64
$swstack = 64
$framesize = 128
Config Submode = New                                        ' <-IMPORTANT!
$include "ticker.bas"
ticker.bas
$nocompile
'timer
Config Timer1 = Timer , Prescale = 64 , Compare_a = Disconnect , Compare_b = Disconnect , Clear Timer = 1
Enable Compare1a : On Compare1a Timer1_isr : Compare1a = 31249       '500ms @16MHz
Config Portb.0 = Output : Led Alias Portb.0
Dim Dummy As Byte
Sub Tim_dummy
 Timer1_isr:
  Toggle Led
End Sub
If Dummy = 1 Then Call Tim_dummy 'once Sub is called even in condition statement then will be attached to main code after END Razz
