ST7735R with XMEGA
boeseturbo
PostPosted: Tue Jun 28, 2016 9:28 am    Post subject: ST7735R with XMEGA Reply with quote
I tried to adapt Hkipnik`s ST7735 code to drive it with XMEGA....
I changed hardware SPI to:
 Config Spie = Hard , Master = Yes , Mode = 0 , Clockdiv = Clk2 , Data_order = Msb , Ss = none
 Open "SPIE" For Binary As #12
and also the pins for DC, CS and Reset...
Config PortE.0 = Output
Config PortE.2 = Output
Config PortE.1 = Output
Lcd_cs Alias PortE.0
Lcd_dc Alias PortE.2
Lcd_reset Alias PortE.1
PortE.0 = 1
and I changed "SPIOUT" command to "print #12" and have no luck.... With ATMEGA I had this display already running...
Has anybody an idea what I am doing wrong?
Cheers
brantb
PostPosted: Thu Aug 18, 2016 9:31 pm    Post subject: Reply with quote
Hello @boeseturbo,
Did you get your problem sorted out, or is it still unresolved?
If you are still having difficulty, I will try to help as much as I can. I don't have specific knowledge of the ST7735 controller, but I have recently done a fair amount of work with an Xmega and an ILI9341 controller.
The code example you include only tells part of the story. Your CONFIG SPIE line includes SS = NONE ... but you don't show any code to illustrate what you are doing (if anything) with the SS pin. Did you set it to output, so that SPI will be in master mode (as it should be)?
I realize this is an older post - but I also just noticed that no one else had tried to help, so I figured I would jump in. If it is already solved ... congratulations! Very Happy Otherwise, give a few more details, and I will see what I can do.
Cheers!
