Mrshilov
Posted: Wed Mar 12, 2014 4:52 pm Post subject: NOKIA-1100 library |
Library for NOKIA-1100, 1101, 1110, 1110i, 1112, 1116, 1200, 1202, 1203, 1280, 2300, 2660ext, 2760ext, 6085ext.
This displays has resolution 96х68 and has internal backlight. Controller is (or compatible with) PCF8814.
Interface is 9-bit SPI. CS & Reset pins are optional, so connection may be only 2 wires.
1100, 1101, 2300 has 9-pad connector:
NOKIA-1202, 1203, 1280 has 12-pad connector:
1110, 1110i, 1112, 1116, 1200, 2660ext, 2760ext, 6085ext has 10-pin connector:
Some NOT-original LCDs not supported hardware X-mirror, Y-mirror & Negative. I add this options in library with software.
Note: picture height must be multiple of 8 and because this LCD height is 68, so fullscreen pictures must be 96x72. For converting it to BGF checkbox "SED series" must be checked, and keep in mind - bottom 4 lines not will be visible. If used option "Mirror-Y" top 4 lines not will be visible.
Backlight voltage for not-original display may be vary (in real mobiles it work with current source), be careful.
Proteus models included. It works, but has many errors- vertical mirror ect... (This is not my product.)
Library and test examples in attachment. |
Paulvk
Posted: Thu Mar 13, 2014 11:16 pm Post subject: |
Hello Mrshilov
Your efforts are greatly appreciated
With all this work I think Mrshilov deserves to be member of the month ! Thats if we had one!
Regards Paul |
Posted: Fri Mar 14, 2014 3:21 pm Post subject: |
Hello Mrshilov,
Once again, thank you for sharing your work here.
It looks super. Yes i agree, if we had such an award, you would get it for sure.
Good option btw to be able to use multiple lcd ! _________________ Mark |
yahi92
Posted: Fri Mar 14, 2014 3:46 pm Post subject: |
Hello Mrshilov
thank you for sharing.
it works so great.
we are waiting for other lcds.  |
Posted: Fri Mar 14, 2014 4:17 pm Post subject: |
do not ask too much., At the rate Mr Mrshilov is delivering tested code/hardware, he either must have a clone of himself, or get problems with Mrs. Mrshilov because he is always working  _________________ Mark |
PeterM
Posted: Sat Mar 15, 2014 12:33 am Post subject: |
I think it may be the Mrs talking to much and wants to get away in the basement or his cave  _________________ Peter |
yahi92
Posted: Sat Apr 12, 2014 4:48 pm Post subject: |
Hello Mr Mrshilov
Could you please help me about this error?
only "byte" and "single" variables can be used?
thank you
bascom 2.0.7.6 |
Mrshilov
Posted: Sun Apr 13, 2014 5:38 am Post subject: |
You must convert it to a "string":
Code: | Lcdat 6 , 1 , Str(Pn) |
yahi92
Posted: Sun Apr 13, 2014 6:15 am Post subject: |
Mrshilov wrote: | You must convert it to a "string":
Problem solved
Thank you for your answering. |
NIMA_2000IR
Posted: Thu Mar 23, 2017 10:54 am Post subject: |
why
Pset 20 , 20 , 0
Line(0 , 0) -(239 , 127) , 255
Box(10 , 30) -(60 , 100) , 0
Boxfill(0 , 0) -(60 , 10) , 1
Circle(20 , 20) , 5 , 0
not work
error
Error : 222 Line : -1480 Illegal character [expected (, got '=' [_GLCD_MODE=8]] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\GLCD.LBX
Error : 222 Line : 4 Illegal character [expected (, got '' [_GLCD_MODE]] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\GLCD.LBX
Error : 222 Line : 19 Illegal character [expected (, got '' [_GLCD_COLS]] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\GLCD.LBX
Error : 61 Line : 29 Label not found [_SET_ADDRESS] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\GLCD.LBX
Error : 221 Line : 29 Backward jump out of range [_SET_ADDRESS [ 3575]] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\GLCD.LBX |
Mrshilov
Posted: Thu Mar 23, 2017 11:33 am Post subject: |
Graphic commands not supported. |
NIMA_2000IR
Posted: Thu Mar 23, 2017 10:42 pm Post subject: |
Mrshilov wrote: | Graphic commands not supported. |
thanks |
Posted: Mon Apr 03, 2017 5:21 pm Post subject: |
Sorry to use this way to contact you ,
but I listened in the radio, the subway crash in St-Peterburg. I See in your profil you are living in this city. so
- Are you safe ?
-I have a thought for each of your compatriots
We will visit St-Peterburg in june
with my friendship
JP |
Mrshilov
Posted: Mon Apr 03, 2017 8:37 pm Post subject: |
It's very sad. Thanks, I'm safe.
You are always welcome in St. Petersburg. Don't worry about your safety - our city is very peaceful. |
Mortezayavari1366
Posted: Sun Mar 19, 2023 11:44 pm Post subject: |
Mrshilov wrote: | It's very sad. Thanks, I'm safe.
Hello Mrshilov
i have a problem with nokia 1100 library in Atmega2560.
with mega8-16-32 every thing is ok.
can you help me? |
