Library for Nokia1616 display
Goto page 1, 2  Next
Mrshilov
Bascom LCD Guru
PostPosted: Mon Oct 13, 2014 9:06 pm    Post subject: Library for Nokia1616 display Reply with quote
NOKIA-1616 series color display has resolution 128x160, size 1,8". Controller is SPFD54124B
Library works on NOKIA displays:
100, 101, 112, 113, 1616, 1661, 1662, 1800, 5030с, С1-00, С1-01, С1-02, С1-03, С2-00, X1-01 (12-pin socket):
And 2865cdma, 5070, 5200, 6060, 6061, 6070, 6080, 6085, 6086, 6101, 6102, 6103, 6125, 6136, 6151, 7360 (22-pin socket DF23-22):
Backlight is 3V or 7V, be careful.
Library has "Portrait" & "Landscape" mode and "Rotate 180" function.
Example in attachment.
PostPosted: Tue Oct 21, 2014 9:48 pm    Post subject: Reply with quote
Thanks for sharing your excellent libs Mrshilov. As usual there is a lib, circuit and sample. Great Very Happy
shams_iqbal
PostPosted: Sat Apr 02, 2016 9:13 pm    Post subject: Reply with quote
it seems very interesting library got this nokia tft then i have tried your library but when i tried to change microcontroler with atxmega32a4u it give me follwing error
Error : 221 Line : 128 Backward jump out of range [_CLEAR_GRAPH1 [ 101]] , in File : C:\Users\Shams\Desktop\nokia c1 lcd display\Sources\xmega64a4u.bas
Error : 221 Line : 128 Backward jump out of range [_CLEAR_GRAPH2 [ 104]] , in File : C:\Users\Shams\Desktop\nokia c1 lcd display\Sources\xmega64a4u.bas
otherwise with selected avr (any mega avr) microcontrollers it compiles without any error
here is my code
'                     NOKIA-1616 display library                             '
'                         resolution 128x160                                 '
'                         BASCOM-AVR  2.0.7.7                                '
'                         Shilov Sergey 2014                                '
'                            St-Peterburg                                    '
'                               RUSSIA                                       '
$regfile = "xm32a4udef.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 64
$framesize = 64
'include the following lib and code, the routines will be replaced since they are a workaround
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
'First Enable The Osc Of Your Choice , make sure to enable 32 KHz clock or use an external 32 KHz clock
'Config Osc = Enabled , 32mhzosc = Enabled
'configure the systemclock
'Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1
'------------------------------- Setup -----------------------------------------
$lib "glcd-Nokia1616ap.lib"
Config Graphlcd = Color , Cs1 = Portd.7 , Si = Portd.4 , Sclk = Portb.1 , Rst = Portb.0
Const Portrait = 0                                          '1=Portrait, 0=Landscape
Const Rotate_180 = 0                                        '1=Rotated,  0=Not Rotated
'------------------- Variables & Constants -------------------------------------
Const Blue = &B00000011                                     ''predefined contants are making programming easier
Const Yellow = &B11111100
Const Red = &B11100000
Const Green = &B00011100
Const Black = &B00000000
Const White = &B11111111
Const Brightgreen = &B00111110
Const Darkgreen = &B00010100
Const Darkred = &B10100000
Const Darkblue = &B00000010
Const Brightblue = &B00011111
Const Orange = &B11111000
Const Violet = &B11100011
Dim I As Byte , N As Byte , M As Byte , P As Byte
'============================ Main prog ========================================
Initlcd
   Boxfill(0 , 0) -(127 , 159) , Green
   Boxfill(0 , 0) -(127 , 159) , Red
   Boxfill(0 , 0) -(127 , 159) , Violet
   Boxfill(0 , 0) -(127 , 159) , Yellow
   Boxfill(0 , 0) -(127 , 159) , Blue
   Line(0 , 0) -(127 , 0) , Yellow
   Line(0 , 0) -(0 , 159) , Yellow
   Line(0 , 159) -(127 , 159) , Yellow
   Line(127 , 0) -(127 , 159) , Yellow
   Pset 1 , 1 , Yellow
   Pset 126 , 1 , Yellow
   Pset 1 , 158 , Yellow
   Pset 126 , 158 , Yellow
   Box(2 , 2) -(125 , 157) , Yellow
   For I = 1 To 63 Step 4
      Circle(64 , 80) , I , Green
   Next I
   Setfont Color8x8
   Lcdat 76 , 12 , "  Nokia 1616  " , Orange , Blue
   Boxfill(0 , 0) -(127 , 159) , White
   Showpic 24 , 40 , Clock
Wait 2
$include "color8x8.font"
Clock:
$bgf "Clock.bgc"
can you plz help me that why this error is appearing wile compiling with any of atxmega controllers
Mrshilov
Bascom LCD Guru
PostPosted: Sat Apr 02, 2016 10:15 pm    Post subject: Reply with quote
Use virtual port:
Config Vport0 = B
Config Vport1 = D
Config Graphlcd = Color , Cs1 = Port1.7 , Si = Port1.4 , Sclk = Port0.1 , Rst = Port0.0
shams_iqbal
PostPosted: Mon Apr 04, 2016 8:39 pm    Post subject: Reply with quote
dear ,Mrshilov
thank you for quick reply and helping me out on the issue
now i am able to compile the code using atxmeg32a4u mcu but there is one last problem remained in the libraray that if i chose atxmega64a4u/arxmega128a4u it gives the same error as before this addition i am actually using atxmega128a4u but using
i can compile the code with out any errors and its running flawlessly while changing it to
$regfile = "xm64a4udef.dat"
or
$regfile = "xm128a4udef.dat"
gives me same previous error Sad as i mentioned earlier to this post any how great work thumbs up Applause
one more question if i want to use big fonts to display on lcd how this can be done thanks in advance
Mrshilov
Bascom LCD Guru
PostPosted: Mon Apr 04, 2016 11:10 pm    Post subject: Reply with quote
I checked
and
No errors.
endusa200
PostPosted: Thu Feb 02, 2017 9:09 pm    Post subject: mega128 Reply with quote
hello
when I change miro to mega128( $regfile = "m128def.dat" ) this erors seen :
bakward jump out of range
but it's working with atmega64
can you help me ? Crying or Very sad
endusa200
PostPosted: Thu Feb 02, 2017 9:14 pm    Post subject: mega128 Reply with quote
back ward jump out of rang [_SHOW PICTURE2 [68]]
back ward jump out of rang [_SHOW PICTURE1 [75]]
WHEN I use "Showpic" code with meg128 this eror seen
Mrshilov
Bascom LCD Guru
PostPosted: Fri Feb 03, 2017 12:10 am    Post subject: Reply with quote
Try this version.
endusa200
PostPosted: Fri Feb 03, 2017 8:27 am    Post subject: mega128 Reply with quote
thank you
it's working Smile
endusa200
PostPosted: Mon Feb 13, 2017 5:44 pm    Post subject: error Reply with quote
Hello
tanks for last code
It's working for atmega128 with port A,port B,port C,port D and port E , but when I use the port F for lcd , this error seen :
backward jump out of range[_Clear_Graph1[101]]
backward jump out of range[_Clear_Graph2[104]]
can you help me ?
Mrshilov
Bascom LCD Guru
PostPosted: Tue Feb 14, 2017 12:44 am    Post subject: Reply with quote
This is not library problem - M1281 with the same pinout works fine.
In M128 due to M103 compatibility PORTF & PORTG will not work.
endusa200
PostPosted: Wed Feb 15, 2017 4:52 pm    Post subject: Reply with quote
OK
thank you for answering
yahi92
PostPosted: Sat Mar 04, 2017 6:31 am    Post subject: Reply with quote
Hello Mrshilov
Do you have any sample for loading "BMP" files from sdcard for this display?
(or any suggestion for doing that?)
Thanks for your great works(we should name you "Display Man"!)
Mrshilov
Bascom LCD Guru
PostPosted: Sat Mar 04, 2017 6:04 pm    Post subject: Reply with quote
IMHO it's not good idea - it will be very slow (several seconds per picture). Better use for this LCD with parallel interface. For example NOKIA3110 - the same resolution & controller.
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13057&highlight=3110
Example of using SD-card BMP included.
Goto page 1, 2  Next
Page 1 of 2
